你好
renard.benoit 请告诉我将风扇电机(最大100W)连接到T435-800T(原理图上标有BT138-V)三端双向可控硅的A1端子的潜在后果?在右图中,请找到我的预期操作。 感谢您, 纳兹穆尔 空值 以上来自于谷歌翻译 以下为原文 Hi renard.benoit Please let me know the potential consequences of connecting a fan motor (Max 100W) to the A1 terminal of T435-800T (BT138-V marked on schematics) Triac? On the right schematics, please find my intended operation. Thanking you, Nazmul null |
6个回答
嗨纳兹穆尔,
将负载连接到A1没有特别的功能问题,除了电路对EFT的抗扰度可能会大大降低,导致线路干扰情况下的杂散触发(最好将A1连接到线路的稳定电位)。 请注意,右侧的原理图是错误的,因为R13 / R12和Triac门并联负载(无法工作)。驱动电路必须直接参考A1(而不是通过负载的A1)。 如果您有任何其他问题,请与我们联系 最好的祝福 伯努瓦 以上来自于谷歌翻译 以下为原文 Hi Nazmul, There is no particular functionnal issue to connect the load to A1 except your circuit immunity to EFT could be highly reduced, resulting of spurious triggering in case of Line disturbances (it is better to connected A1 to a stable potential as Line). Note that your schematic on the right is wrong as R13/R12 and Triac gate are connected in parrallel of the load (no way to work). The driving circuit must be referenced directly to A1 (and not to A1 through the load). Let me know if you have any other question Best Regards Benoit |
嗨Benoit,
请注意,右侧的原理图是错误的,因为R13 / R12和Triac门并联负载(无法工作)。驱动电路必须直接参考A1(而不是通过负载的A1)。 是的,我没有通过我的眼睛看到它。感谢您的仔细观察。 我想控制我的两个房间灯,那些共用中性线。通过机械开关和负载的其他端子从开关板向负载供电,连接到负载附近的中性线。我看不到连接负载A2终端的方法,可以吗?如果不是,如果我将负载连接到A1端子,如何提高抗扰度?缓冲器或MOV有帮助吗? Vous remercier, 纳兹穆尔 以上来自于谷歌翻译 以下为原文 Hi Benoit, Note that your schematic on the right is wrong as R13/R12 and Triac gate are connected in parallel of the load (no way to work). The driving circuit must be referenced directly to A1 (and not to A1 through the load). Yeah, I didn't see it through my eyes. Thanks to your careful observation. I want to control two of my room lights, those share common neutral line. Power feed to the load from switch board via a mechanical switch and other terminal of the load connect to the neutral line nearby the load. I can't see a way to connect load A2 terminal, can you? If not, how can I improve immunity if I connect load to A1 terminal? Does a Snubber or MOV help? Vous remercier, Nazmul |
嗨Benoit,
+更新:我试图将负载连接到Triac的A1终端。正如您已经建议的那样,电阻R12 / R13和三端双向可控硅开关并联。因此,我将使用三端双向可控硅开关驱动器MOC3021,以便在Q-I和Q-III中发射三端双向可控硅开关。它工作正常,但我发现了“嘶嘶”的噪音。可能是电源电路的感应(附图)。对此有何建议? 无论如何,我在等你对''的评论'' 我想控制我的两个房间灯,那些共用中性线。通过机械开关和负载的其他端子从开关板向负载供电,连接到负载附近的中性线。我看不到连接负载A2终端的方法,可以吗?如果不是,如果我将负载连接到A1端子,如何提高抗扰度?缓冲器或MOV有帮助吗? ''谢谢! - /纳兹穆尔 以上来自于谷歌翻译 以下为原文 Hi Benoit, + Update: I tried to connect the load to Triac's A1 terminal. As you already suggested resistor R12/R13 and Triac gate are in parallel. So, I'd to use a Triac driver, MOC3021 in order to fire the Triac in Q-I and Q-III. It's working fine but I found a ''hissing'' noise. Probably it's from the induction of power supply circuit (attached image). Any suggestion regarding this? Anyway, I'm waiting for your comment on '' I want to control two of my room lights, those share common neutral line. Power feed to the load from switch board via a mechanical switch and other terminal of the load connect to the neutral line nearby the load. I can't see a way to connect load A2 terminal, can you? If not, how can I improve immunity if I connect load to A1 terminal? Does a Snubber or MOV help? '' Merci! -/Nazmul |
Bonjour Nazmul,
关于电感器噪声,由于您只将Triac控制器从直接控制更改为opto-Triac,因此SMPS电流变化是为Triac触发提供的电流。然后我的建议是检查你应用的光电三端双向可控硅LED电流是否远高于第一个电路的栅极电流。 关于负载与Triac的参考,t 这里没有特别的功能问题将负载连接到A1,除了你的电路对EFT的抗扰度会降低。而你是对的,Triac的parralel中的缓冲器可以安排这个。 10 nF / 51欧姆应该补偿。 如果您需要更多,请告诉我 伯努瓦 以上来自于谷歌翻译 以下为原文 Bonjour Nazmul, Regarding inductor noise, as you have only change the Triac controller from direct control to opto-Triac, the SMPS current change is the current provided for Triac triggering. Then my suggestion is to check if the opto-Triac LED current you apply is much higher than the gate current of the 1st circuit. Regarding the reference of the load versus Triac, t here is no particular functionnal issue to connect the load to A1 except that your circuit immunity to EFT will be reduce. And you're right, a snubber in parralel of the Triac could be arrange this. A 10 nF / 51 Ohm should compensate. Let me know if you need more Benoit |
Bonjour Benoit,
对不起,来晚了。 关于电感器噪声,由于您只将Triac控制器从直接控制更改为opto-Triac,因此SMPS电流变化是为Triac触发提供的电流。然后我的建议是检查你应用的光电三端双向可控硅LED电流是否远高于第一个电路的栅极电流。 是。你是对的。我改变了光电三端双向可控硅驱动器隔离侧的限流电阻值。现在它工作正常。请在使用光电三端双向可控硅驱动器触发三端双向可控硅开关时,是否应使用敏感逻辑电平三端双向可控硅开关(10mA栅极触发电流)或标准三端双向可控硅开关(25-35mA栅极触发电流)。 留言Merci 纳兹穆尔 以上来自于谷歌翻译 以下为原文 Bonjour Benoit, Sorry for being late. Regarding inductor noise, as you have only change the Triac controller from direct control to opto-Triac, the SMPS current change is the current provided for Triac triggering. Then my suggestion is to check if the opto-Triac LED current you apply is much higher than the gate current of the 1st circuit. Yes. you are right. I changed the value of current limiting resistor at isolation side of opto-Triac driver. Now it's working fine. Please let me know whether should I use sensitive logic-level triac (10mA gate trigger current) or standard triac ( 25-35mA gate trigger current) while firing the triac using a opto-triac driver. Merci Nazmul |
嗨纳兹穆尔,
回复晚了,请原谅。 如果您不必通过EMC标准(特别是传导噪声),请使用35 mA三端双向可控硅开关以确保更好的动态行为:更好的dV / dt耐受性和更好的关断能力(dI / dt)c。 如果您有更多问题,请与我们联系 最好的祝福 伯努瓦 以上来自于谷歌翻译 以下为原文 Hi Nazmul, Sorry for my late reply. If you dont have to pass EMC standard (especially versus conducted noise), please use a 35 mA Triac to ensure a better dynamic behavior: better dV/dt withstanding and better turn-off capability (dI/dt)c. Let me know if you have more questions Best Regards Benoit |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
2463 浏览 1 评论
3160 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1727 浏览 1 评论
3548 浏览 6 评论
5912 浏览 21 评论
885浏览 4评论
1264浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
529浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
1247浏览 3评论
1300浏览 3评论
GMT+8, 2024-10-3 07:38 , Processed in 1.224134 second(s), Total 88, Slave 72 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
