电子发烧友论坛|
你好,
我有一个星云1 IOT开发套件,我试图连接到AWS板。我正在使用Waice Studio 6.1中的AWSIOT演示文件夹。我已经在AWS上建立了一个帐户,并创建了一个证书以及一个东西和策略。我所面临的问题是在资源& GT;Apple & GT;AWSUT.Go.AWS.CONtiON.HTML中发现的WORD AWS IOT服务不起作用。如何更新文件CeleT.CER、PrimKE.CER和ROOTCA.CER?我相信没有正确的文件给我这个MQTT打开连接失败的错误。 谢谢, 里克 以上来自于百度翻译 以下为原文 Hello, I have a Nebula 1.0 IoT development kit and I'm attempting to connect the board onto AWS. I am using the awsiot demo folder in WICED-Studio 6.1. I have already setup an account on AWS and created a certificate as well as a Thing and Policy. The problem I'm having is the WICED AWS IOT Service that is found in the resources>apps>awsiot>aws_config.html does not work. How do I update the files client.cer, privkey.cer, and rootca.cer? I believe not having the correct files is giving me this MQTT Opening Connection Failed Error. Thanks, Rick |
7个回答
感谢更新DV89991414111
你也应该接触到你的当地未来分支,因为他们可以为星云板提供额外的软件/硬件支持。 以上来自于百度翻译 以下为原文 Thanks for the update dv89_9_1490111 You should also reach out to your local Future branch as they can provide additional software/hardware support for the Nebula board. |
HI成功连接到AWS后,您如何配置。代码使终端能够显示来自不同扩展板的数据(例如温度等)。 以上来自于百度翻译 以下为原文 hi after successful connect to the aws, how do you config. the code at WICED to enable the terminal to show the data eg. temperature,etc from the different expansion boards. |
你好!你的意思是你想在未来的AWS项目中加入传感器板代码吗?您需要自己把驱动程序代码导入项目中。驱动程序和示例代码是由未来提供的。 以上来自于百度翻译 以下为原文 Hi mingyang.ang_3244646! Do you mean you want to add in the sensor board code that Future has written into the AWS project? You would need to bring the driver code into the project yourself. The drivers and example code is provided by Future. |
saber_miku 发表于 2018-10-18 10:30 用户手册 是的。 我在哪里可以找到代码?链接?谢谢您。 以上来自于百度翻译 以下为原文 user_341228818 YES INDEED. Where can I find the code? Link? Thank you. |
那个链接专门用于BLUMIX应用程序,对吗?还是用于AWS的代码相同? 以上来自于百度翻译 以下为原文 that link is specifically for bluemix application only right? or is it the same code used for aws? |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 04:54 , Processed in 0.838112 second(s), Total 85, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
934
