电子发烧友论坛|
我使用的是2X S25FL512S QSPI闪存芯片。在CyPress数据表中,它提到了几个读取命令的地址之后的模式位。我无法在DS中找到这些值的任何解释,而不是0x5A来扩展连续的读周期。这些模式位是什么?还有其他的值吗?
以上来自于百度翻译 以下为原文 I am using 2x S25FL512S QSPI flash chips. In the Cypress data sheet, it mentions mode bits following the address for several of the read commands. I couldn't find any explanation of values for these bits in the DS other than 0x5a to extend continuous read cycles. What are these mode bits for and what other values are there? |
2个回答
当我在S25FS512S数据表中遇到同样的事情时,我也在想同样的事情。这两个设备(和数据表)是足够相似的。
在“双I/O读”和“四I/O读”命令部分下,数据表表示暗示下一个命令指令与当前命令相同,模式位必须等于“AXH”。为了澄清,“AXH”是指上半字节(位7- 4)必须等于“AH”,而下半字节(位3-0)可以是任何东西。 在“DDR双IO Read”和“DDR Quad I/O读取”命令部分下,数据表说明模式位类似地使用,除了要求上下刻蚀必须互补。 注意,模式位的值取决于您使用的哪一组指令。 以上来自于百度翻译 以下为原文 I was wondering the same thing when I encountered the same thing in the S25FS512S datasheet. The two devices (and datasheets) are similar enough. Under both the 'Dual I/O Read' and 'Quad I/O Read' command sections, the datasheet states that to imply the next command instruction is the same as the current one, the mode bits must equal 'Axh'. To clarify, 'Axh' means the upper nibble (bits 7-4) must equal 'Ah' and the lower nibble (bits 3-0) can be anything. And under the 'DDR Dual IO Read' and 'DDR Quad I/O Read' command sections, the datasheet states that the mode bits are similarly used except with the requirement that the upper and lower nibbles must be complementary. Note that the values of the mode bits differ depending on which set of instructions you are using. |
脑洞大赛5 发表于 2018-10-18 10:15 如果这是模式位的唯一用途,我会很惊讶(失望)。我确实读了一个ISSI DDR部分的数据表,它说了几乎相同的事情——“如果模式位=AXH(X不关心),它可以执行AX读取模式(没有命令)。当模式位与AXH不同时,该装置退出AX读取操作。微米甚至没有提到模式位。 以上来自于百度翻译 以下为原文 I'd be really surprised (and disappointed) if that is the only use of the mode bits. I did read the data sheet for an ISSI DDR part and it says pretty much the same thing - "If the mode bits=AXh (where X is don’t care), it can execute the AX read mode (without command). When the mode bits are different from AXh, the device exits the AX read operation". Micron doesn't even mention mode bits |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7102 浏览 0 评论
2477 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2074 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7585浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6134浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7980浏览 2评论
/9
GMT+8, 2025-12-3 06:48 , Processed in 0.733942 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
616
