电子发烧友论坛|
我已经购买了带有UHD605显卡的NUC7PJYH,因为我们的新50“UHD电视对于我的旧Acer Revo 3610来说非常大,而Nvidia ION是Mythtv的前端。
我在NUC上安装了Xubuntu 18.04和Mythtv-frontend,并通过HDMI-1连接电视。 1,错误是,当我启动NUC时,电视说HDMI端口没有输入。 如果我拔出HDMI并重新插入,我就会得到桌面。 我得到了POST屏幕,但是在电视上说“没有输入”之后。 我试图通过在grub引导中设置“nomodeset”来修复丢失的桌面。 它修正了丢失的桌面,但是当我在GRUB中设置的nomodeset时,我没有声音通过HDMI。 Pavucontrol表示有一个HDMI输出,但即使插上它也不插电。 如果我删除grub中的nomodeset参数我有声音通过HDMI但我需要在每次启动后拔下并重新插入HDMI以获得电视上的桌面。 我在3680x2160和1024x768之间尝试了许多不同的屏幕分辨率,但问题仍然存在。 我还尝试使用命令video = 1920x1080在grub中设置分辨率。 Grub命令为ind / etc / default / grub,在GRUB_CMDLINE_LINUX_DEFAULT =下,然后运行update-grub。 我需要在grub中设置什么参数来同时拥有图片和声音。 有什么好建议吗? 电视是飞利浦50PUS6262 以上来自于谷歌翻译 以下为原文 I have bought a NUC7PJYH with UHD605 graphics because our new 50" UHD tv was to big a mouthfull for my old Acer Revo 3610 with Nvidia ION as a Mythtv frontend. I installed Xubuntu 18.04 and Mythtv-frontend on the NUC and connected the TV via HDMI-1. 1,st error was, when I boot the NUC the tv says no input at the HDMI port. If I pull out the HDMI and plug it in again, I get the desktop. I get the POST screen though but after taht the TV says "no input". I startet out trying to fix the missing desktop by setting the "nomodeset" in the grub boot. It corrected the missing desktop but when nomodeset i set in GRUB I have no sound through HDMI. Pavucontrol states that there is a HDMI output but it is unplugged even though it is plugged in. If I remove the nomodeset parameter in grub i have sound over HDMI but I need to unplug and replug the HDMI after every boot to get a desktop on the TV. I have tried many different screen resolutions between 3680x2160 and 1024x768 but the problem persists. I have also tried to set the resolution in grub with the command video=1920x1080. Grub commands as ind /etc/default/grub and under GRUB_CMDLINE_LINUX_DEFAULT= and running update-grub afterwards. What parameter do I need to set in grub to have both picture and sound. Any good suggestions? The TV is a Philips 50PUS6262 |
12个回答
Hellojknuc感谢您加入英特尔®社区。虽然英特尔尚未在您的Linux版本上测试和验证英特尔®NUC,但我们知道其他客户已成功安装它。英特尔建议您检查您的Linux发行版网站和论坛:// www
.ubuntu.com / support / community-支持同行协助解决这个问题。 您也可以参考https://01.org/linuxgraphics/downloads获取潜水员帮助。 希望这可以帮助。 此致Leonardo C.Intel客户支持技术人员与英特尔公司签订合同 以上来自于谷歌翻译 以下为原文 Hello jknuc Thank you for joining the Intel® community. While Intel has not tested and validated Intel® NUC on your Linux version, we know that other customers have successfully installed it. Intel suggests you check your Linux distro's website and forums at https://www.ubuntu.com/support/community-support for peer assistance with this the issue. You could also refer to https://01.org/linuxgraphics/downloads for diver assistance. Hope this helps. Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation |
jerry1978 发表于 2018-10-18 16:49 嗨莱昂纳多 谢谢您的回复。 我已通过此ppa更新到最新的201801版本的intel图形驱动程序/ set: 更新的开放图形驱动程序:Oibaf 当我通过HDMI连接到我的飞利浦电视时,我仍然可以选择视频或声音 我看到问题与manyl用户在这些主题中提到的相同: NUC7PJYH:HDMI 2.0支持不佳。 寻找兼容的电视(4K-60Hz-4:4:4)。 NUC7PJYH - 当HDMI UHD颜色为ON时,三星4K电视上没有信号 NUC7PJYH HDMI在特定显示屏上出现问题。 NUC7CJYH Linux / HDMI问题 英特尔NUC7PJYH:没有视频信号 所有这些线程都表明在NUC7xJYH系列中有一个带有HDMI 2.0a实现的设计缺陷,并且在将电视显示器连接到NUC7xJYH系列时会出现此错误。 此观察与OS(Windows或Linux)无关。 你/英特尔能否用bios版本来解决这个问题? 问候 Jens K. 以上来自于谷歌翻译 以下为原文 Hi Leonardo Thank you for your reply. I have updated to the latest 201801 version of the intel graphics drivers/set through this ppa: Updated Open Graphics Drivers : Oibaf Still i can choose to have either video or sound when i connect to my Philips TV through HDMI I see that the issue is the same as mentioned by manyl users in these threads: NUC7PJYH: Poor HDMI 2.0 support. In search of a compatible TV (4K-60Hz-4:4:4). NUC7PJYH - No signal on Samsung 4K TV when HDMI UHD Color is ON NUC7PJYH HDMI Issue on particular display. NUC7CJYH Linux/HDMI issues Intel NUC7PJYH: no video signal All of these threads indicate that there is a designflaw with the HDMI 2.0a implementation in the NUC7xJYH series and that this error is showing itself when connecting a TV display to the NUC7xJYH series. This observation is independent of the OS (Windows or Linux). Could you/Intel please address the error with a bios release to fix it? Regards Jens K |
嗨PeterNUC。 我想你是对的。 我决定将我的UHD电视设置为非UHD模式 - 现在运行1920x1080非UHD。 我认为英特尔营销和销售的产品无法利用英特尔自己为客户指定的规格,这是一种耻辱。 如果英特尔发布了尽快修复此问题的BIOS更新,那将是适当的 以上来自于谷歌翻译 以下为原文 Hi PeterNUC. I think you are right. I have resolved to setting my UHD TV to non UHD mode - now running 1920x1080 non UHD. I think it's a shame that Intel markets and sells a product that is not able to utilize the specification that Intel it self has specified to the customer. It would be apropriate if Intel released a BIOS update that fixed this problem ASAP |
我发现了一个新错误。 如果我在失败的模块后看起来我dmesg: dmesg | grep失败了 我发现 [2.160352] i915 0000:00:02.0:i915 / glk_dmc_ver1_04.bin的直接固件加载失败,错误-2 我已经找到了Gemini lake blob,它应该在哪里 - 在/ lib / firmware / i915中为glk_dmc_ver1_04.bin 所以文件在那里但由于某种原因它不会在启动时加载。 也许构建blob的英特尔工程师可以解决这个问题 以上来自于谷歌翻译 以下为原文 I have found a new error. If i looked i dmesg after failed modules: dmesg | grep failed i find
I have looked for the Gemini lake blob and it is where it should be - in /lib/firmware/i915 as glk_dmc_ver1_04.bin so the file is there but for some reason it does not load under boot. Maybe the Intel engineers who have build the blob can solve this issue |
我想我找到了这个问题的答案。 我为Ubuntu安装了UKUU ppa并使用它来尝试不同的内核,如果一个较新的内核将加载gemini湖的i915 glk_dmc_ver1_04.bin文件 这个问题在最新的内核4.18中得到了解决 有了这个内核,Gemini lake blob就会被加载,而HDMI输出到电视的工作在UHD和非UHD模式。 我现在可以毫无问题地运行UHD 4.4.4。 接下来是让VAAPI在mythtvfrontend中工作。 Preresently我只能运行OpenGL高品质。 如果我尝试使用VAAPI,我会收到视频输出错误。 以上来自于谷歌翻译 以下为原文 I think I have found the answer to this problem. I installed the UKUU ppa for Ubuntu and used it to try out different kernels to se if a newer kernel would load the i915 for Gemini lake the glk_dmc_ver1_04.bin file The problem got solved in the newest kernel 4.18 With this kernel the Gemini lake blob gets loaded and the HDMI output to the TV works in UHD and non-UHD mode. I now can run UHD 4.4.4 without problems. Next up is getting VAAPI to work in mythtvfrontend. Pfresently i can only run run OpenGL High quality. If I try to use VAAPI i get a video output error. |
子璇ALICE 发表于 2018-10-18 17:29 嗨Jens, 很高兴听到你碰巧解决了这个问题。 如果我理解你的话,你可以在飞利浦50PUS6262电视上以60Hz运行UHD 4.4.4。 那是对的吗? 如果是,你能说出你是如何在电视上启用4:4:4和HDMI 2.0的(默认情况下4K电视通常支持4:2:2和HDMI 1.4)。 谢谢,彼得 以上来自于谷歌翻译 以下为原文 Hi Jens, Good to hear that you happened to resolve the problem. If I understand you right, you can run UHD 4.4.4 at 60Hz now on Philips 50PUS6262 TV. Is that correct? If yes, could you tell how did you enable 4:4:4 and HDMI 2.0 on your TV (by default 4K TVs usually support 4:2:2 and HDMI 1.4). Thanks, Peter |
嗨彼得 是的我有我的电视(飞利浦50PUS6262 / 12)的选项。 最大分辨率为3840x2160 60Hz 在我的电视上,我选择:设置 - 所有设置 - 常规设置 - HDMI Ultra - - UHD 4:4:4/4:2:2 - 正常 NUC7PJYH运行Xubuntu 18.04(uname -a) Linux NUC-FE-Stuen 4.18.12-041812-generic#201810032137 SMP Thu Oct 4 01:39:48 UTC 2018 x86_64 x86_64 x86_64 GNU / Linux lsmod的一部分: 的i915 1740800 7rtsx_pci_sdmmc 24576 0i2c_algo_bit 16384 1 i915drm_kms_helper 172032 1 i915syscopyarea 16384 1 drm_kms_helpersysfillrect 16384 1 drm_kms_helpersdhci_pci 36864 0rtsx_pci 65536 2 rtsx_pci_sdmmc,rtsx_pci_mssysimgblt 16384 1 drm_kms_helperpsmouse 151552 0cqhci 24576 1 sdhci_pcifb_sys_fops 16384 1 drm_kms_helperr8169 86016 0mii 16384 1 r8169sdhci 53248 1 sdhci_pcidrm 458752 8 drm_kms_helper,i915ahci 40960 2libahci 32768 1 ahcii2c_hid 20480 0wmi 24576 1 wmi_bmofhid 126976 3 i2c_hid,u***hid,hid_genericvideo 45056 1 i915pinctrl_geminilake 24576 0pinctrl_intel 20480 1 pinctrl_geminilake vainfo: libva info:VA-API版本1.1.0 libva info:va_getDriverName()返回0 libva info:试图打开/usr/lib/x86_64-linux-gnu/dri/i965_drv_video.so libva info:找到init函数__vaDriverInit_1_1 libva info:va_openDriver()返回0 vainfo:VA-API版本:1.1(libva 2.1.0) vainfo:驱动程序版本:用于Intel(R)Gemini Lake的Intel i965驱动程序 - 2.1.0 vainfo:支持的配置文件和入口点 VAProfileMPEG2Simple:VAEntrypointVLD VAProfileMPEG2Main:VAEntrypointVLD VAProfileH264ConstrainedBaseline:VAEntrypointVLD VAProfileH264ConstrainedBaseline:VAEntrypointEncSlice VAProfileH264ConstrainedBaseline:VAEntrypointEncSliceLP VAProfileH264主要:VAEntrypointVLD VAProfileH264主要:VAEntrypointEncSlice VAProfileH264主要:VAEntrypointEncSliceLP VAProfileH264High:VAEntrypointVLD VAProfileH264High:VAEntrypointEncSlice VAProfileH264High:VAEntrypointEncSliceLP VAProfileH264MultiviewHigh:VAEntrypointVLD VAProfileH264MultiviewHigh:VAEntrypointEncSlice VAProfileH264StereoHigh:VAEntrypointVLD VAProfileH264StereoHigh:VAEntrypointEncSlice VAProfileVC1Simple:VAEntrypointVLD VAProfileVC1Main:VAEntrypointVLD VAProfileVC1Advanced:VAEntrypointVLD VAProfileNone:VAEntrypointVideoProc VAProfileJPEGBaseline:VAEntrypointVLD VAProfileJPEGBaseline:VAEntrypointEncPicture VAProfileVP8Version0_3:VAEntrypointVLD VAProfileVP8Version0_3:VAEntrypointEncSlice VAProfileHEVCMain:VAEntrypointVLD VAProfileHEVCMain:VAEntrypointEncSlice VAProfileHEVCMain10:VAEntrypointVLD VAProfileHEVCMain10:VAEntrypointEncSlice VAProfileVP9Profile0:VAEntrypointVLD VAProfileVP9Profile0:VAEntrypointEncSlice VAProfileVP9Profile2:VAEntrypointVLD 以上来自于谷歌翻译 以下为原文 Hi Peter Yes i have alle the options my TV (Philips 50PUS6262/12) has. The max resolution is 3840x2160 60Hz On my TV i choose: Settings - All settings - General settings - HDMI Ultra - The NUC7PJYH is running Xubuntu 18.04 with (uname -a) Linux NUC-FE-Stuen 4.18.12-041812-generic #201810032137 SMP Thu Oct 4 01:39:48 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux Part of lsmod:
vainfo: libva info: VA-API version 1.1.0 libva info: va_getDriverName() returns 0 libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/i965_drv_video.so libva info: Found init function __vaDriverInit_1_1 libva info: va_openDriver() returns 0 vainfo: VA-API version: 1.1 (libva 2.1.0) vainfo: Driver version: Intel i965 driver for Intel(R) Gemini Lake - 2.1.0 vainfo: Supported profile and entrypoints VAProfileMPEG2Simple : VAEntrypointVLD VAProfileMPEG2Main : VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice VAProfileH264ConstrainedBaseline: VAEntrypointEncSliceLP VAProfileH264Main : VAEntrypointVLD VAProfileH264Main : VAEntrypointEncSlice VAProfileH264Main : VAEntrypointEncSliceLP VAProfileH264High : VAEntrypointVLD VAProfileH264High : VAEntrypointEncSlice VAProfileH264High : VAEntrypointEncSliceLP VAProfileH264MultiviewHigh : VAEntrypointVLD VAProfileH264MultiviewHigh : VAEntrypointEncSlice VAProfileH264StereoHigh : VAEntrypointVLD VAProfileH264StereoHigh : VAEntrypointEncSlice VAProfileVC1Simple : VAEntrypointVLD VAProfileVC1Main : VAEntrypointVLD VAProfileVC1Advanced : VAEntrypointVLD VAProfileNone : VAEntrypointVideoProc VAProfileJPEGBaseline : VAEntrypointVLD VAProfileJPEGBaseline : VAEntrypointEncPicture VAProfileVP8Version0_3 : VAEntrypointVLD VAProfileVP8Version0_3 : VAEntrypointEncSlice VAProfileHEVCMain : VAEntrypointVLD VAProfileHEVCMain : VAEntrypointEncSlice VAProfileHEVCMain10 : VAEntrypointVLD VAProfileHEVCMain10 : VAEntrypointEncSlice VAProfileVP9Profile0 : VAEntrypointVLD VAProfileVP9Profile0 : VAEntrypointEncSlice VAProfileVP9Profile2 : VAEntrypointVLD |
延, 谢谢(你的)信息。 看起来很有希望。 你碰巧在电视上重现了真正的4:4:4色吗? 我的意思是,您确认使用4:4:4测试图像吗? 此外,你在POST期间看到NUC标志吗?当HDMI端口配置为HDMI 2.0时你能进入BIOS吗? 我问这样愚蠢的问题,因为我仍然找不到可以用作这个NUC的监视器的电视。 不幸的是,我正在运行Windows,所以我不能使用你的Linux相关信息。 谢谢,彼得 以上来自于谷歌翻译 以下为原文 Jens, Thanks for the info. It looks promising. Did you happen to reproduce true 4:4:4 color on your TV? I mean, did you verify that using a 4:4:4 test image? Besides, do you see NUC logo during POST and can you enter BIOS when the HDMI port is configured as HDMI 2.0? I am asking such stupid questions because I still cannot find a TV, which could be used as a monitor with this NUC. Unfortunately, I'm running Windows, so I cannot use the your Linux-related info. Thanks, Peter |
嗨彼得。 NUC显示了POST中通常显示的内容并在linux中启动 - 一切都在那里 - 并且功能通常没有错误发生。 我不认为我有4:4:4的图片来测试。 我只是假设,因为电视显示视频和一切看起来(几乎)如预期的那样是4:4:4 你能给我发一个这样的视频或图片的网址吗? 当我写(几乎)时,使用VAAPI时的CPU使用率有点高。 我在Mythtv中由VA模块引起的事情并没有编译为NUC的正确VA lib版本。 我用: 0.29:“Mythbuntu团队”团队 我读到的一些正常的ubuntu多元宇宙Mythtv是为我的VA模块编译的。 以上来自于谷歌翻译 以下为原文 Hi Peter. The NUC shows what is normally shown on POST and boot in linux - everything is there - and functions normally with no errors occurs. I do not think that i have a 4:4:4 picture to test with. I just assumed that since the TV shows the videos and everything looks (almost) as expected that it is 4:4:4 Can you send me a url for such a video or picture? When i write (almost) i se that the CPU usage when using VAAPI is a bit to high. I thing that it is caused by VA module in my Mythtv is not compiled for the right VA lib version for the NUC. I use the: 0.29 : “Mythbuntu Team” team Somewhre i read that the normal ubuntu multiverse Mythtv is compiled for my version of VA module. |
嗨彼得。 我可以下载图片并显示全屏我的Ristretto(Xubuntu Paint替代品)。 我可以清楚地阅读所有的线条,在粉红色的三角形中,我可以阅读4:2:2和4:4:4。 4:2:2浅粉色,4:4:4浅粉色。 我试图用我的手机拍照,但手机没有屏幕正义。 IMG_20181007_191505.jpg 5.1 MB 以上来自于谷歌翻译 以下为原文 Hi Peter. I can have downloadad the picture and have display'ed it fullscreen i Ristretto (the Xubuntu Paint alternative). I can clearly read all the lines and in the pink triangle i can read both 4:2:2 and 4:4:4. 4:2:2 in a lighter pink and 4:4:4 in a darker pink. I have tried to take a photo with my mobile but the mobile doesn't do the screen justice.
嗨Jens, 您的图像被拉伸到全屏。 关键部分是像素到像素或100%渲染图像。 由于图像是817x720,因此它只占据3840x2160屏幕的一小部分(垂直1/3)。 参见附4:4:4,4:2:2和4:2:0的照片作为参考 最好, 彼得 DSCF3109.JPG 7.2 MB DSCF3101.JPG 7.1 MB DSCF3096.JPG 7.2 MB 以上来自于谷歌翻译 以下为原文 Hi Jens, Your image is stretched to the full screen. The critical part is to render the image pixel-to-pixel, or at 100%. Since the image is 817x720 it will occupy only a small of the 3840x2160 screen (1/3 vertically). See attached photos of 4:4:4, 4:2:2 and 4:2:0 for reference Best, Peter
只有小组成员才能发言,加入小组>>
/9
GMT+8, 2025-12-11 00:57 , Processed in 0.970157 second(s), Total 64, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2013
