扫一扫,分享给好友
嗨,
我想在一台机器上运行多个smartXplorer运行,即我有两个不同的项目,并希望在同一台机器上运行SmartXplorer。 但是,当试图启动第二个SmartXplorer运行时,我被告知它已经在运行。 有什么方法吗? 谢谢, 斯蒂芬 以上来自于谷歌翻译 以下为原文 Hi, I'd like to run multiple smartXplorer runs on a single machine, i.e. I have two different projects and would like to run SmartXplorer for both on the same machine. However, when trying to start the second SmartXplorer run I get told that it is already running. Any way around this? Thanks, Stephan |
5个回答
这是ISE GUI告诉你SmartXplorer已经在运行吗?
您应该能够在命令行上运行第二个SmartXplorer来解决这个问题。 如果您不喜欢这样,ISE的第二个实例可能会起作用。 Linux还是Windows? 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Is that the ISE GUI telling you SmartXplorer is already running? You should be able to run a second SmartXplorer on the command line to get around that. If you don't like that, a second instance of ISE would probably work. Linux or Windows? View solution in original post |
您应该能够在命令行上运行第二个SmartXplorer来解决这个问题。 如果您不喜欢这样,ISE的第二个实例可能会起作用。 Linux还是Windows? 以上来自于谷歌翻译 以下为原文 Is that the ISE GUI telling you SmartXplorer is already running? You should be able to run a second SmartXplorer on the command line to get around that. If you don't like that, a second instance of ISE would probably work. Linux or Windows? |
这是在Linux上。
我正在运行两个ISE实例,但仍然收到相同的消息。 这12.3顺便说一句。 但13.x也是如此。 我将继续使用命令行,如果它修复它。 以上来自于谷歌翻译 以下为原文 This is on Linux. I am running two instances of ISE and still get the same message. This 12.3 btw. But 13.x does the same. I will go ahead and use the command line if that fixes it. |
每次运行的目录不同?
我......这个工作是从一个完全独立的目录开始的 - 而不仅仅是通过smartexplorer -wd开关的单独目录? 我们在同一台(linux)机器上同时运行了几十个smartxplorer运行(每个机器都运行在一个单独的FPGA上)。 完成至少10.3,因此工具版本应该不是问题。 我敢打赌,在同一目录中的两次运行会相互踩踏,并导致问题。 Xilinx工具往往有一个病理问题...... - 标记 以上来自于谷歌翻译 以下为原文 Different directories for each run? i..e the job's started in a completely seperate directory - not just a seperate directory via the smartexplorer -wd switch? We've run dozens of smartxplorer runs concurrently, on the same (linux) machine (each working on a seperate FPGA). Done so since at least 10.3, so tool version shouldn't be an issue. I would bet that two runs in the same directory would step on each other, and cause problems. Xilinx tools tend to have a pathological problem with that... --Mark |
不。
完全不同的目录。 工具设置来自同一终端,然后从那里产生多个ISE GUI。 但即使我通过不同的终端设置工具,我也会遇到问题。 无论是登录还是我们如何进入远程机器,都有可能做些什么。 这不是一个严重的问题,因为我可以通过make文件模拟smartXplorer。 谢谢, 斯蒂芬 以上来自于谷歌翻译 以下为原文 Nope. Totally different directories. The tool setup is sourced from the same terminal and then multiple ISE GUIs spawned from there. But even if I setup the tools through different terminals I get the problem. More than likely something to do either with the login or how we ssh into the remote machine. Not a serious issue, since I can emulate smartXplorer via make files. Thanks, Stephan |
只有小组成员才能发言,加入小组>>
2321 浏览 7 评论
2729 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2217 浏览 9 评论
3295 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2368 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
652浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
460浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
220浏览 1评论
667浏览 0评论
1859浏览 0评论
GMT+8, 2024-9-29 00:39 , Processed in 1.271791 second(s), Total 85, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
