电子发烧友论坛扫一扫,分享给好友
我无法通过pip在终端上获得sklearn和xlrs。
有什么建议么? 以上来自于谷歌翻译 以下为原文 I can't get the sklearn and xlrs on terminal though pip. Any sugestions? |
3个回答
嗨Taisa,
感谢您与我们联系。 请按照下面提到的步骤来简化您的安装: 1.如果您已经创建了conda环境并将其激活,则可以使用conda install进行直接安装。 conda install scikit-learnconda install xlrd(假设你所需的包是xlrd而不是xlrs) 有关使用conda环境的信息,请参阅以下链接:https://communities.intel.com/docs/DOC-112294 2.如果要在没有conda环境的情况下直接安装软件包,建议使用--user开关将pip安装到本地或主目录中 pip install scikit-learn --userpip install xlrd --user 如果有帮助,请告诉我们。 如果您遇到任何问题,请退回。 谢谢& 问候,Sandhiya 以上来自于谷歌翻译 以下为原文 Hi Taisa, Thanks for reaching out to us. Kindly follow the below mentioned steps to ease your installations: 1. If you have already created a conda environment and activated it, you can do a direct installation using conda install. conda install scikit-learn conda install xlrd (Assuming your required package is xlrd and not xlrs) For information regarding using conda environments, refer the following link : https://communities.intel.com/docs/DOC-112294 2. If you want to install the package directly without a conda environment, it is recommended to use the --user switch for pip to install in your local or home directory pip install scikit-learn --user pip install xlrd --user Please do let us know if it helps. Kindly get back in case you face any issues. Thanks & Regards, Sandhiya |
嗨Taisa,希望解决方案提供有用吗? 请确认它是否适合您。谢谢& 问候,Sandhiya 以上来自于谷歌翻译 以下为原文 Hi Taisa, Hope the solution provided was helpful? Kindly confirm if it worked for you. Thanks & Regards, Sandhiya |
嗨Taisa,希望它有效。 我们正在关闭这个帖子。 如果你遇到任何其他问题,请提出一个新的线程。请注意,Sandhiya 以上来自于谷歌翻译 以下为原文 Hi Taisa, Hope it worked. We are closing this thread. Please raise a new thread incase you face any other issue. Regards, Sandhiya |
只有小组成员才能发言,加入小组>>
/9
GMT+8, 2025-12-8 08:50 , Processed in 1.082504 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4620
