电子发烧友论坛|
技嘉Z30 Aorus Gaming 5
I7 -8086 16 GB DDR4 3000内存 三星960 Pro M.2 512 NVMe PCIe SSD(主驱动器,Windows安装) 2TB Seagate BarraCude(二级驱动器,Drive我想用Optane加速) 32GB Intel Optane MEMPEK1W032GAXT 正如标题所说我试图用我的英特尔optane驱动器加速我的辅助硬盘驱动器。 我在主PCIe SSD上安装了Windows,但想要加速硬盘。 我知道我无法加速PCIe驱动器并且不想。 在我的BIOS中,我有CSM支持Dissabled。 我已禁用RST Legacy OROM。 我禁用了积极的LPM支持。 我将Port 21上的PCIe Storage Dev设置为RST Controlled(这是安装Optane的M.2插槽的正确端口,M2P_32G) 当我运行SetupOptane.Memory.exe时,我收到错误“intel optane memory不支持在PCIe磁盘上安装的系统” 我还有新安装的窗口,当我使用diskpart将我的硬盘格式化为GST驱动器时。 然后我在Windows中使用磁盘管理器在驱动器上创建一个分区,以便它在Windows中显示为一个卷。 为了澄清,我的PCIe SSD上安装了Windows,但是我有一个干净的空白GST格式的硬盘驱动器,我想用optane来提升,而且我的生活中无法弄清楚我做错了什么。 以上来自于谷歌翻译 以下为原文 Gigabyte Z30 Aorus Gaming 5 I7 -8086 16 GB DDR4 3000 Memory Samsung 960 Pro M.2 512 NVMe PCIe SSD (Primary Drive, Windows Installed) 2TB Seagate BarraCude (Secondary Drive, Drive I would like to accelerate with Optane) 32GB Intel Optane MEMPEK1W032GAXT As the title Says I am trying to accelerate my secondary HDD with my intel optane drive. I have Windows installed on my primary PCIe SSD but would like to accelerate the HDD. I know I cannot accelerate the PCIe drive and have no desire to. In my BIOS I have CSM Support Dissabled. I have Use RST Legacy OROM disabled. I have Aggressive LPM Support Disabled. I have PCIe Storage Dev on Port 21 set to RST Controlled (this is the correct port for the M.2 slot the Optane is installed to, M2P_32G) When I run SetupOptane.Memory.exe I get the error "intel optane memory does not support system installed on PCIe disk" I have also fresh installed windows and when I did i used diskpart to format my HDD as a GST drive. I then used disk manager in windows to create a partition on the drive so it would show up as a volume in windows. To clarify again windows is installed on my PCIe SSD but i have a clean blank GST formatted HDD that i want to boost with optane and for the life of me can not figure out what i'm doing wrong. |
2个回答
更新:我能够使用英特尔快速存储技术应用程序获得英特尔硬件以加速我的辅助硬盘驱动器。
但是,对我来说这不是一个解决方案,因为我仍然无法使用官方支持的主软件enableOptaneMemory.exe来获取驱动器。 我很好奇,如果我卸载IRST而不解除我的optane和硬盘驱动器然后使用enableOptaneMemory.exe如果链接将被识别但我不愿意测试并找出因为我不想打破已经工作的东西 。 如果有人能确认这确实是我应该采取的路线,我将继续。 以上来自于谷歌翻译 以下为原文 UPDATE: I was able to get the intel optane to accelerate my Secondary HDD using the Intel Rapid Storage Technology application. HOWEVER, to me this is not a solution because I still cannot get the drives to link using the official supported and primary software enableOptaneMemory.exe. I am curious if I uninstall IRST without de-linking my optane and HDD and then use the enableOptaneMemory.exe if the link will then be recognized but I am not willing to test and find out because I do not want to break what have got working. If someone can confirm this is indeed the route I should take I will proceed. |
脑洞大赛1 发表于 2018-10-17 12:41 您好TheSquigglyLine,感谢您联系英特尔技术支持。据我们了解,您需要有关英特尔®Optane™内存的帮助。 如果我们正确推断您可以使用RST软件加速您的辅助硬盘驱动器。让我向您提供以下信息,其中包括哪些软件可以加速使用英特尔®Optane™内存? 基于这些信息的文章,我们可以得出结论,您可以使用一个软件或另一个软件,具体取决于您的配置。由于您可以使用RST软件加速您的系统,我们建议您保留当前配置。我们希望您发现这些信息有用 .Best表示,Josh B.Intel客户支持技术人员与英特尔公司签订合同 以上来自于谷歌翻译 以下为原文 Hello TheSquigglyLine, Thank you for contacting Intel Technical Support. As we understand, you need assistance with your Intel® Optane™ Memory. If we infer correctly you were able to accelerate your secondary HDD using the RST software. Let me provide you with the following information included in the What Software Enables Acceleration with Intel® Optane™ Memory? article based on this information we can conclude that you can use one software or the other depending on your configuration. Since you were able to accelerate your system using the RST software we recommend you to keep your current configuration. We hope you find this information helpful. Best regards, Josh B. Intel Customer Support Technician Under Contract to Intel Corporation |
只有小组成员才能发言,加入小组>>
/9
GMT+8, 2025-12-1 20:38 , Processed in 0.622905 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
5778
