电子发烧友论坛|
PIC18F26K42,我想知道,如果您(错误地)将一个外围引脚配置成一个未实现的端口。如果在原型和制造之间,一个函数从端口中的一个引脚移动到波尔塔的一个引脚,那么外围设备使用的SMT可以被配置为ACCE。从PORTB和POTC只输入PT。哦!别担心,我会在这方面工作,但出于好奇,在这种情况下应该发生什么?-我的赌注:输入被绑定到零,也是最安全的(我认为)解决方案,外围错误行为显然是工作的,但随机行为不端。
以上来自于百度翻译 以下为原文 PIC18F26K42, i'm wondering what is supposed to happen if you (by mistake) configure a peripheral pin to be one from an unimplemented port. between prototyping and manufacturing a function was moved from one pin in PORTB to a pin in PORTA. The peripheral used -SMT- , however, can be configured to accept input from PORTB and PORTC only. D'oh! don't worry, i'm going to work around this but, out of curiosity, what is supposed to happen in this case? -my bet: input is tied to zero, also the safest (i think) solution -peripheral mi***ehave -peripheral apparently works but randomly mi***ehaves |
3个回答
在与我的同事在Microchip这里相识之后。如果您继续认为该部分被配置为使用POTA作为输入,SMT模块将尝试从PIN获取值。由于这个模块没有连接到波尔塔的任何一个,所以它得到的输入可以是0到VDD之间的任何数字。
以上来自于百度翻译 以下为原文 After conferring with my colleagues here at Microchip. If you continue as though the part is configured to use PORTA for the input, the SMT module will try to obtain the value from the pin. Since there is no connection possible to any of PORTA with this module, the input it gets could be any number between 0 and Vdd. |
嗨,JAMUS,谢谢你花时间来看看这个:你说的暗示它在波动吗?或者它连接到一个稳定点,它既可以是GND也可以是VDD,但是我们不能知道哪个?
以上来自于百度翻译 以下为原文 Hi jamus, thank you for taking your time to look into this :) what you say suggsests it's fluctuating? or it is connected to a stable point which could be either be GND or VDD but we can't know which? |
我们在Microchip的一位建筑师已经教了我更多关于PPS模块的知识。他说,如果引脚被设置为数字引脚,它将读取0。他说,如果PIN被设置为模拟引脚,信号将是我在前一篇文章中所说的。
以上来自于百度翻译 以下为原文 One of our architects here at microchip has taught me a little bit more about the PPS module. He said if the pin is set up as a digital pin it will read 0. He said if the pin is set up as an analog pin the signal will be what I said in the previous post. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1122浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
872浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-1 22:43 , Processed in 0.844725 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1565
