电子发烧友论坛|
嗨,我沉浸在C编程中(那是很远),我有2-3个小问题要问你。我下载了一个版本的MPLAB(8.92),我想为PIC18F创建程序,我必须下载一个特定的编译器(我看到XC18编译器适合PIC18F)还是在那里?E直接与MPLAB集成?如何将其设置为MPLAB上的默认编译器?我还看到有一个新版本的MPLAB(MPLABX),你使用它吗?有什么好处?与旧版本相比有什么变化?抱歉,所有这些问题,但我从来没有太多与MPLAB。谢谢你提前。祝大家好!!
以上来自于百度翻译 以下为原文 Hi all Immersing myself in the programming in C (that is far), I had 2-3 small questions to ask you. I downloaded a version of MPLAB (8.92), with which I want to create programs for PIC18F; Do I have to download a specific compiler (I saw that the XC18 compiler was suitable for PIC18F) or is there one directly integrated with MPLAB? How to set it as the default compiler on MPLAB? I also saw that there is a new version of MPLAB (MPLABX); Do you use it? What are the benefits? What changes compared to older versions? Sorry for all these questions but I have never worked much with MPLAB. Thank you in advance. Good day to all!! |
4个回答
对不起,延迟回答…MPLAB 8.92过时了,不推荐用于新项目。MPLABX是一个建立在NETBESE上的现代IDE。建议和XC8:www. McCHIP.COM/MPLABXwww. MICCHIP.COM/XC8HTH
以上来自于百度翻译 以下为原文 Sorry for the delay in answering... MPLAB 8.92 is obsolete and not recommended for new projects. MPLABX is a modern IDE built on NetBeans. Recommend that and xc8: www.microchip.com/mplabx www.microchip.com/xc8 HTH |
您应该使用LestestMPLABX IDE和最新的XC8编译器。XC8是所有8位PIC微控制器的编译器:所有PIC10F、PIC12F、PIC16F和PIC18F系列。XC16是16位PIC模型:PIC24和DSPIC,而XC32是32位PIC模型:PIC32。对于初学者,可以从8位开始,开始下载并安装MPLAB X IDE,而不是XC8编译。R.
以上来自于百度翻译 以下为原文 You should use the latest MPLABX IDE with the latest XC8 compiler. XC8 is the compiler for all 8-bit PIC microcontrollers: All PIC10F, PIC12F, PIC16F and PIC18F series. XC16 is for 16-bit PIC models: PIC24 and dsPIC while XC32 is for 32-bit PIC models: PIC32. For beginners you can start with 8-bit, start by downloading and install the MPLAB X IDE than the XC8 compiler. |
嗨,MPLAB X:HTTP://www. MyCHIP.COM/MPLABX编译器:HTTP://www. McCHIP.COM/CimuleStutoReals:HTTP://www. McChIPPosir.com
以上来自于百度翻译 以下为原文 Hi, MPLAB X : http://www.microchip.com/MPLABX Compilers : http://www.microchip.com/compilers tutorials : http://www.microchipdeveloper.com Regards |
XC8是PIC18(它不是唯一一个)可以在MPLAB 8上工作的正确的微芯片编译器,但需要额外的步骤。
以上来自于百度翻译 以下为原文 XC8 is the Correct Microchip Compiler for the PIC18 (it is not the only one) It can be made to work on MPlab 8, But will require additional Steps. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
475 浏览 0 评论
5795 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1126浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1098浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-3 13:17 , Processed in 0.581353 second(s), Total 49, Slave 42 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1714
