电子发烧友论坛|
我打破了全新的八核Cyberpower PC。
从第一次启动时,每次计算机启动时,桌面上都会出现一个弹出窗口,显示“Intel Turbo Boost Max Technology 3.0”应用程序。 这个弹出窗口应该从未出现过。 附上截图。 我希望它背后的任何程序运行,但然后关闭它自己的窗口并在后台运行未事先通知。 如何轻松配置才能这样做? 谢谢。 Intel Turbo Boost cropped.png 956.7 K. 以上来自于谷歌翻译 以下为原文 I'm breaking in a brand new, eight-core Cyberpower PC. From the first time it was turned on, each and every time the computer starts, a pop-up window appears over the desktop showing an "Intel Turbo Boost Max Technology 3.0" app. This pop-up should have never appeared. Screenshot attached. I want whatever program is behind it to run but then close its own window and run unannounced in the background. How can that be easily configured to do so? Thank you.
3个回答
您好The1stSoulRider,感谢您在我们的英特尔®社区发布。在这种情况下,请尝试安装最新版本的英特尔®睿频加速技术3.0驱动程序,以摆脱弹出窗口。另外,为了我
为了更好地为您提供帮助,请向我提供系统支持实用程序将生成的.txt文件。 要附加文件,您必须单击响应框右下角的“附加”选项。我希望尽快收到您的回复。注意,Diego Sanchez Campos.Intel(R)客户支持技术人员与英特尔签订合同( R)公司 以上来自于谷歌翻译 以下为原文 Hello The1stSoulRider, Thank you for posting in our Intel ® Community. In this case, please try to install the latest version of the Intel® Turbo Boost Max Technology 3.0 driver in order to get rid of the pop up. Also, in order for me to assist you better, please provide me with the .txt file that the System Support Utility will generate. To attach a file, you must click the “Attach” option on the bottom right-hand corner of the response box. I hope to hear from you soon. Regards, Diego Sanchez Campos. Intel (R) Customer Support Technician Under Contract to Intel (R) Corporation |
jerry1978 发表于 2018-10-12 07:52 谢谢Campos先生。 我卸载了“Intel Turbo Boost Max Technology 3.0软件的1.0.0.1033版本,并在安装1.1.0.1005之前重新启动。在第一个和(到目前为止)只重新启动弹出窗口没有出现。这很有希望,我 将继续测试一段时间。如果烦恼得到解决,则不需要上传日志。 您的支持很有价值(虽然合理预期),因为此实例所需的任务超出了CyberpowerPC的意愿或技能。 我给他们发了一封没有回复的电子邮件。 以上来自于谷歌翻译 以下为原文 Thank you, Mr Campos. I uninstalled the version 1.0.0.1033 of the "Intel Turbo Boost Max Technology 3.0 software and rebooted before installing version 1.1.0.1005. On the first and (so far) only restart the pop-up window did not appear. This is promising and I will continue to test for a time. If the annoyance is solved an upload of the log will be unnecessary. Your support was valuable (although reasonably expected) as the tasks required in this instance were beyond either the willingness or skillset of CyberpowerPC. I'd sent them an e-mail which has received no response. |
cd340823 发表于 2018-10-12 08:00 你好The1stSoulRider感谢你的回复。请监控结果,这样我就会密切关注你的线程,万一发生了什么事情。我会在5天内跟进,以确保一切顺利。我希望这有帮助.Regards,Diego Sanchez Campos.Intel(R)客户支持技术人员与英特尔(R)公司签订合同 以上来自于谷歌翻译 以下为原文 Hello The1stSoulRider Thank you for your response. Please monitor the results so I will keep an eye in your thread in case that something happens. I will follow up in around 5 days to make sure that everything went well. I hope this helps. Regards, Diego Sanchez Campos. Intel (R) Customer Support Technician Under Contract to Intel (R) Corporation |
只有小组成员才能发言,加入小组>>
/9
GMT+8, 2025-12-2 04:11 , Processed in 1.974327 second(s), Total 98, Slave 81 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
7448
