我使用进化板CY8CKIT-042与CasSoIP按钮。现在我想使用新版本CSD 5测试我们的触摸系统,我需要调谐助手包括在内。我看到在5版本中没有调试帮助的调谐器。我在版本CSD 2.6中探索所有的工作。但是我需要测试版本CSD 5(FRQ.HOP和其他新版本的好东西)。最简单的方法是用EZI2C使用调试工具调谐器?
以上来自于百度翻译 以下为原文 I use evolution board CY8CKIT-042 with Capsense buttons. Now I want to use new version CSD 5.0 to test on our touch system and I need tune helper included. I see that there is no tune helper for debuging in 5.0 version. I probe in version CSD 2.6 threre is all working. But I need to tested version CSD 5.0 (freq. hop and other good things that include new version). And the simplest way is to use debuger tool tune helper with EZI2C? |
6个回答
尝试阅读与CSD调谐助手相关的其他线程:尝试运行PSoC 4先锋工具包的调谐器GUI
以上来自于百度翻译 以下为原文 Try reading some of the other threads relate to CSD tune helper: try to run tuner gui for psoc 4 pioneer kit |
嗨,西蒙,
CSD 5的调谐器助手不同于CSD 2.6,但更容易。 附件是FYI。 谢谢, 赖安 CY8C4245AXI-48 3CCSD50.CYWRK.SARVEVE01.ZIP 659.9 K 以上来自于百度翻译 以下为原文 Hi Simon, Tuner helper of CSD 5.0 is different with but easier than CSD 2.6. Attached is FYI. Thanks, Ryan |
嗨,瑞兹, 谢谢,现在开始工作了。但我还有另一个问题,我想改变别针的位置,因为我用我自己的箔。我用10个按钮,我编译和编程到芯片,但在调谐器,我得到错误,… 谢谢你的回复。 西蒙 以上来自于百度翻译 以下为原文 Hi rzzh, thanks, now is working. But I have another problem, I want to change the positions of pins, because I use my own foil. I use 10 buttons, i compile and program to chip, but in tuner i get error,... Thanks for reply. Simon |
60user162 发表于 2018-10-11 08:14 CAPSENSE组件用于与调谐器GUI交互的I2C缓冲器可以大于256字节。可以将I2C从子地址设置为EZI2C组件中的16位和子地址大小到调谐器软件工具中的2-BES - GT;调谐器通信设置-GT;子地址。 以上来自于百度翻译 以下为原文 The I2C buffer that the CapSense component uses to interact with the Tuner GUI may be greater than 256 bytes. Can you Set the I2C slave sub-address to 16-bits in EzI2C component and sub-address size to 2-byes in Tuner Software Tools->Tuner Communication setup->Sub-address. |
fbele456 发表于 2018-10-11 08:26 是的,我设置了16位。问题是当我改变引脚从滑块到按钮,并设置其他引脚,… 以上来自于百度翻译 以下为原文 Yes, I set 16 bits. The problems comes when I change pins from slider to buttons and set other pinout,... |
现在的工作,奇迹般的,没有任何变化,…谢谢Ryan补充项目,… 当做, 西蒙 以上来自于百度翻译 以下为原文 now works miraculously, without any changes,...Thanks Ryan for added project,... Regards, Simon |
只有小组成员才能发言,加入小组>>
754个成员聚集在这个小组
加入小组2111 浏览 1 评论
1858 浏览 1 评论
3673 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1792 浏览 6 评论
1540 浏览 1 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
579浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
432浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
442浏览 2评论
391浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
979浏览 2评论
GMT+8, 2024-12-29 12:53 , Processed in 1.109126 second(s), Total 86, Slave 70 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
