嗨,
是否允许将基于STmicro SDK的自定义inemo应用程序(sportmeter)的固件上传到sourceforge? WR 亚历克斯 以上来自于谷歌翻译 以下为原文 Hi, is it allowed to upload the firmware of my custom inemo application (sportmeter), which based on the SDK of STmicro to sourceforge ? WR Alex |
4个回答
嗨Alexander,
固件ST提供了以下许可证: STMicroelectronics(“ST”)授予您非全球性,全球性,不可转让性(无论是 通过转让,法律,从属许可或其他方式),可撤销,免版税的有限许可: (i)制作副本,准备衍生作品,在内部展示并在内部使用来源 代码版本的许可软件仅用于开发的唯一目的 此类许可软件的可执行版本仅用于产品; (ii)制作副本,准备衍生作品,在内部展示并使用内部目标代码 许可软件的版本仅用于设计,开发和 制造产品; (iii)制造,使用,出售,要约出售,进口或以其他方式分销产品。 据我所知,您可以发布源代码,该源代码是ST源代码的派生,用于ST微控制器。这些源代码示例仅供指导,旨在为客户提供有关其产品的编码信息,以便为他们节省时间。 我不是100%肯定这个许可证的确切界限。但是我看到很多人在GitHub上发布ST的源代码衍生产品,谷歌代码& SourceForge等.. 您可以查看附加的ST许可证文档文件以获取更多信息。 以上来自于谷歌翻译 以下为原文 Hi Alexander, The firmware ST provides has the following LICENSE: STMicroelectronics (“STâ€�) grants You a non-exclusive, worldwide, non-transferable (whether by assignment, law, sublicense or otherwise), revocable, royalty-free limited license to: (i) make copies, prepare derivatives works, display internally and use internally the source code version of the Licensed Software for the sole and exclusive purpose of developing executable versions of such Licensed Software only for use with the Product; (ii) make copies, prepare derivatives works, display internally and use internally object code versions of the Licensed Software for the sole purpose of designing, developing and manufacturing the Products; (iii) make, use, sell, offer to sell, import or otherwise distribute Products. As far as i understand, you can publish your source code which is derivative of ST source code to be used on ST microcontroller. These source code examples meant for GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME. I'm not 100% sure about the exact boundaries of this licence. But i saw many people publish Source code derivatives of ST on GitHub, Google code & SourceForge etc.. You can see the attached ST Licence document file for more info. |
谢谢!我对KEIL论坛的讨论很少,所以我发表了你的发言。
问题是我上传了基于SDK的IAR项目的项目。所以我在sourceforge上传了我的衍生物,keil论坛上的一些人对法律许可 - 版权协议 - 东西发疯了,因为它是ST的代码,发布在sourceforge上。 我真的不了解那里的人 - 制造这么多麻烦。 但非常感谢您的信息! 以上来自于谷歌翻译 以下为原文 thank you! i have little discussion on the KEIL forum , so i posted your statement. problem is i uploaded my project which based on the IAR Project of the SDK. So i uploaded my derivate on sourceforge and some people in the keil forum go crazy about the legal-licence-copyright-agreement-stuff because it is code of ST which is published on sourceforge. I dont really understand the people there - making so much trouble. but many thanks for your info! |
最后更新:我联系了ST关于我的腿版权问题。我在等待答案。
以上来自于谷歌翻译 以下为原文 last update: i contacted ST about my lega-copyright questions. I'm awaiting the answer. |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1468 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1521 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3668 浏览 1 评论
3860 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2477 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
747浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
680浏览 5评论
726浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
965浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
768浏览 5评论
/9
GMT+8, 2025-12-11 08:26 , Processed in 0.950480 second(s), Total 81, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
404
