嗨,
我在Fujitsu工作站R940(驱动程序346.68和348.27)中安装了Grid K2卡有问题。 一切都很好,除非我选择GPU从Pass-Through到vGPU(从K200到K280Q),VM(Win7 64位)变得非常慢 - 慢启动,非常糟糕的交互,没有鼠标箭头指针。 我已经以某种方式安装了nvidia(用于VM)的驱动程序,但没有任何变化。 VM上安装了4个vCPU,16Gb内存,安装在SSD上。 有人能指出我正确的方向,在哪里寻找解决问题的方法。 以上来自于谷歌翻译 以下为原文 Hi, I have an issue with Grid K2 card installed in Fujitsu workstation R940 (drivers 346.68 with 348.27). Everything works great except when I select GPU from Pass-Through to vGPU (from K200 to K280Q), VM (Win7 64 bit) becomes very slow - slow boot, very bad interaction, no mouse arrow only pointer. I have somehow installed drivers for nvidia (for VM) but nothing changes. VM with 4 vCPU, 16Gb ram, installed on SSD. Can someone point me to the right direction, where to look to solve the problem. |
6个回答
您是否在自己的服务器版本上安装了相应的NVIDIA驱动程序?
就资源使用情况而言,nvidia smi.exe在该VM上报告的是什么? 以上来自于谷歌翻译 以下为原文 Did you install the corresponding NVIDIA driver on your to match the server version? What does nvidia_smi.exe report on that VM as far as resource usage goes? |
这是否意味着您在选择passthrough选项时遇到问题?
或者这是否意味着每当您连接GPU(passthrough或vGPU)时都会遇到问题 你在哪里遇到这个问题? 在XenCenter控制台中或通过ICA连接? 以上来自于谷歌翻译 以下为原文 Does this mean that you have problems when you select the passthrough option? Or does it mean that you have a problem whenever you attach a GPU (passthrough or vGPU) Where do you get the problem? In the XenCenter console or via an ICA connection? |
如果我在VM属性中选择vGPU(K200到K280Q),则VM变慢(慢速win7安装,慢速启动,......),如果VM GPU设置为none或直通,则一切运行顺利。
希望现在很清楚。 我正在使用XenCenter控制台进行检查。 它在我看来问题是在XenServer方面,有些东西正在使用CPU,我现在不知道是什么。 我将从USB重新安装XenServer到SSD,看看是否有任何变化...... 谢谢 以上来自于谷歌翻译 以下为原文 If I select vGPU (K200 to K280Q) in VM properties then VM becomes slow (slow win7 install, slow boot,...) and if VM GPU is set to none or passthrough everything is running smoothly. Hope it is clear now. I am checking this with XenCenter console. It looks to me that problem is in XenServer side, something is using CPU and I dont now what. I am going to reinstall XenServer from USB to SSD and will see if anything changes... Thanks |
None
以上来自于谷歌翻译 以下为原文 I had no luck. Everything works the same. Please check CPU usage when VM (with K280Q) is booted and no app is running. https://www.imageupload.co.uk/images/2015/10/07/CPU_usage.png Bios is up to date. Patches for Xenserver 6.2 installed #lsmod | grep nvidia nvidia 7547799 50 i2c_core 20294 1 nvidia #dmesg | grep -E "NVRM" [ 23.982887] NVRM: loading NVIDIA UNIX x86 Kernel Module 346.68 Sun Apr 26 20:17:20 PDT 2015 [ 37.166450] NVRM: Your system is not currently configured to drive a VGA console [ 37.166452] NVRM: on the primary VGA device. The NVIDIA Linux graphics driver [ 37.166453] NVRM: requires the use of a text-mode VGA console. Use of other console [ 37.166454] NVRM: drivers including, but not limited to, vesafb, may result in [ 37.166455] NVRM: corruption and stability problems, and is not supported. #dmesg | grep -E "nvidia" [ 23.537816] nvidia: module license 'NVIDIA' taints kernel. [ 23.982172] nvidia 0000:04:00.0: enabling device (0000 -> 0003) [ 23.982180] nvidia 0000:04:00.0: PCI INT A -> GSI 32 (level, low) -> IRQ 32 [ 23.982263] nvidia 0000:04:00.0: setting latency timer to 64 [ 23.982456] nvidia 0000:05:00.0: enabling device (0000 -> 0003) [ 23.982461] nvidia 0000:05:00.0: PCI INT A -> GSI 32 (level, low) -> IRQ 32 [ 23.982477] nvidia 0000:05:00.0: setting latency timer to 64 [ 23.982702] nvidia 0000:06:00.0: PCI INT A -> GSI 40 (level, low) -> IRQ 40 [ 23.982714] nvidia 0000:06:00.0: setting latency timer to 64 [ 35.089524] nvidia 0000:04:00.0: get owner: 7ff0 [ 35.089599] nvidia 0000:04:00.0: irq 835 (291) for MSI/MSI-X [ 35.910299] nvidia 0000:05:00.0: get owner: 7ff0 [ 35.910341] nvidia 0000:05:00.0: irq 834 (290) for MSI/MSI-X [ 36.587080] nvidia 0000:06:00.0: get owner: 7ff0 [ 36.587107] nvidia 0000:06:00.0: irq 833 (289) for MSI/MSI-X [ 66.857972] nvidia 0000:06:00.0: get owner: 7ff0 [ 69.746824] nvidia 0000:06:00.0: get owner: 7ff0 [ 69.746877] nvidia 0000:06:00.0: irq 833 (289) for MSI/MSI-X [ 1977.700175] nvidia 0000:06:00.0: get owner: 7ff0 [ 1980.545937] nvidia 0000:06:00.0: get owner: 7ff0 [ 1980.545987] nvidia 0000:06:00.0: irq 833 (289) for MSI/MSI-X [ 4408.935784] nvidia 0000:06:00.0: get owner: 7ff0 [ 4411.846006] nvidia 0000:06:00.0: get owner: 7ff0 [ 4411.846059] nvidia 0000:06:00.0: irq 833 (289) for MSI/MSI-X [ 6489.225152] nvidia 0000:06:00.0: get owner: 7ff0 [ 6492.103800] nvidia 0000:06:00.0: get owner: 7ff0 #nvidia-smi Wed Oct 7 21:23:56 2015 +------------------------------------------------------+ | NVIDIA-SMI 346.68 Driver Version: 346.68 | |-------------------------------+----------------------+----------------------+ | GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC | | Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. | |===============================+======================+======================| | 0 GRID K2 On | 0000:04:00.0 Off | Off | | N/A 35C P8 29W / 117W | 11MiB / 4095MiB | 0% Default | +-------------------------------+----------------------+----------------------+ | 1 GRID K2 On | 0000:05:00.0 Off | Off | | N/A 32C P8 28W / 117W | 3787MiB / 4095MiB | 0% Default | +-------------------------------+----------------------+----------------------+ | 2 Quadro 2000 Off | 0000:06:00.0 Off | N/A | | 30% 58C P8 N/A / N/A | 3MiB / 1023MiB | 0% Default | +-------------------------------+----------------------+----------------------+ +-----------------------------------------------------------------------------+ | Processes: GPU Memory | | GPU PID Type Process name Usage | |=============================================================================| | No running processes found | +-----------------------------------------------------------------------------+ |
嗨,
这里http://www.nvidia.com/object/grid-certified-servers.html表示富士通工作站R940power已通过Nvidia GRID认证。 可以请有人告诉我GRID和vGPU认证的管理程序和版本(XenServer,vSpere Esxi ....)。 以上来自于谷歌翻译 以下为原文 Hi, here http://www.nvidia.com/object/grid-certified-servers.html it is stated that Fujitsu workstation R940power is certified for Nvidia GRID. Can please somebody tell me with which hypervisor and version it is certified (XenServer, vSpere Esxi....) for GRID and vGPU. |
http://hcl.xenserver.org/
不列出R940只有R920& R930 我会向Fujitsu查询他们的认证,因为我找不到任何关于在XenServer上使用该服务器的信息。 以上来自于谷歌翻译 以下为原文 http://hcl.xenserver.org/ Does not list the R940 only R920 & R930 I would check with Fujitsu on their certification as I can't find anything regarding using that server with XenServer. |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
2994 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3409 浏览 4 评论
GMT+8, 2024-9-30 02:57 , Processed in 0.613621 second(s), Total 83, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
