我正在尝试让VL53L1X GUI与Windows 10上的VL53L1X评估板配合使用,并且遇到了障碍。我已经成功安装了STSW-IMG008软件,用STSW-link009安装了驱动程序,并使用STSW-link007更新了Nucleo的固件。
但是,我在GUI程序中收到“无法连接到Nucleo Board:未检测到Com端口”错误。当我尝试使用“Flash Fw”按钮对设备进行编程时,我收到“未检测到传感器.COM84连接:请确保传感器已连接,然后按Nucleo上的黑色重置按钮。”按下黑色复位按钮不会执行任何操作 - 按下时,电路板上的所有LED都不会发生变化。 在设备管理器下,该设备被列为STMicroelectronics STLink虚拟COM端口,该设备显示为标有NODE_F401RE的USB存储设备,因此我相信我已正确安装驱动程序。 我可以将VL53L1X_RangingExample bin文件拖到设备上并通过TeraTerm读取传感器的串行输出,因此我知道传感器本身正在工作。 希望我只是遗漏了一些非常明显的东西,但我想让这个工作正常,以便我们可以继续在我们的应用程序中测试这个传感器的性能。谢谢! 以上来自于谷歌翻译 以下为原文 I'm trying to get the VL53L1X GUI to work with the VL53L1X evaluation board on Windows 10 and have hit a roadblock. I've successfully installed the STSW-IMG008 software, installed the drivers with STSW-link009, and have updated the Nucleo's firmware with STSW-link007. However, I get a "Failed To Connecto to Nucleo Board: Com Port Not Detected" error in the GUI program. When I try to program the device with the "Flash Fw" button, I get "Sensor Not Detected. COM84 Connected: Please ensure sensor connected then Press Black Reset Button on the Nucleo." Pressing the black reset button doesn't do anything - none of the LEDs on the board change at all when pressing it. Under the Device Manager, the device is listed as STMicroelectronics STLink Virtual COM Port and the device shows up as a USB storage device labeled NODE_F401RE, so I believe I have the drivers correctly installed. I can drag the VL53L1X_RangingExample bin file onto the device and read the serial output from the sensor via TeraTerm, so I know the sensor itself is working. Hopefully I'm just missing something super obvious, but I would like to get this working so we can move forward with testing the performance of this sensor in our application. Thanks! |
1个回答
更新:我在Windows 7笔记本电脑上尝试了GUI软件,它成功刷新了固件并正在运行。这是我做的事情的顺序:
插入Nucleo boardInstall STSW-link009安装STSW-IMG008(以管理员身份)点击“Flash Fw”(由于某种原因,这之前必须完成几次?) 我也禁用了自动播放,不确定它是否与它有任何关系,但每次都弹出大容量存储设备很烦人。 所以在这一点上它似乎不能在Windows 10中运行 - 我回到我的主计算机并删除并重新安装了设备驱动程序,它仍然无法在那里工作。现在,至少在一台电脑上工作,这并不是什么大不了的事。 以上来自于谷歌翻译 以下为原文 Update: I tried the GUI software on a Windows 7 laptop and it successfully flashed the firmware and is working. Here's the order I did things in:
I also disabled AutoPlay, not sure if that had anything to do with it but it was annoying having it pop up with the mass storage device every time. So at this point it would appear that it's not working in Windows 10 - I went back to my main computer and removed and reinstalled the device drivers, it still doesn't work there. That's not as big of a deal now with it working on at least one computer though. |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-1 23:56 , Processed in 0.546684 second(s), Total 76, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
439
