电子发烧友论坛|
我在三台Cisco UCS主机上安装了3个Tesla M10 GPU。
它们被用于Horizon 7中的一个池中,覆盖80多个独立的VM。 我的任务是看看GPU的使用量。 当我运行nvidia-smi时,它显示100%的所有内容,但我很难相信考虑到许多VM当前没有运行。 有什么我想念的吗? 以上来自于谷歌翻译 以下为原文 I have 3 Tesla M10 GPUs on three Cisco UCS hosts. They are being used in one pool in Horizon 7 across 80+ separate VM's. I have been tasked with seeing how much the GPU's are being utilized. When I run nvidia-smi it show's everything at 100% but I have a hard time believing that considering many of the VM's are not currently running. Is there something I'm missing? |
6个回答
你在哪里经营nvidia-smi?
主持人还是客人? 您使用的是哪种配置文件? 我不相信你的所有GPU都在100%运行... 以上来自于谷歌翻译 以下为原文 Where do you run nvidia-smi? Host or guest? Which profile are you using? I don't believe that all of your GPUs are running at 100% all the time... |
您是否尝试过安装并运行不错的免费实用程序GPUprofiler?
以上来自于谷歌翻译 以下为原文 Have you tried installing and running the nice free utility, GPUprofiler ? |
当您运行VMware时,如果您查看GRID软件门户(您从中添加软件),请在产品信息> 5.2> ...下面找到“用于vRealize Operations的NVIDIA虚拟GPU管理包”。
如果您正在运行vROP,这将为您提供一些出色的监控功能。 否则,正如Tobias所提到的,GitHub上的GPUProfiler也非常好! 问候 以上来自于谷歌翻译 以下为原文 As you're running VMware, if you look in the GRID Software Portal (where you doenloaded the software from), under Product Information > 5.2 > ... There's an "NVIDIA Virtual GPU Management Pack for vRealize Operations". This will give you some great monitoring capabilities if you're running vROPs. Otherwise as Tobias mentions, GPUProfiler on GitHub is very good as well! Regards |
你有没有想过这个?
我的P40卡在做同样的事情时遇到了问题。 以上来自于谷歌翻译 以下为原文 Have you figured this one out? I am having problems with my P40 cards doing the same thing. |
让我猜你正在使用Horizon运行PCoIP?
请参阅发行说明: http://docs.nvidia.com/grid/5.0/grid-vgpu-release-notes-vmware-vsphere/index.html#bug-1735009-high-gpu-use-active-horizon-sessions 这是VMWare的一个已知问题,现已开放3年。 他们只是不会解决它,因为他们似乎不再投资PCoIP了。 问候 西蒙 以上来自于谷歌翻译 以下为原文 Let me guess you are running PCoIP with Horizon? See release notes: http://docs.nvidia.com/grid/5.0/grid-vgpu-release-notes-vmware-vsphere/index.html#bug-1735009-high-gpu-use-active-horizon-sessions This is a known issue from VMWare and open for 3 years now. They just won't fix it as they seem to not invest in PCoIP any more. Regards Simon |
是的,我们正在使用PCoIP。
听起来像您链接的那些发行说明中的条目可能是问题。 以上来自于谷歌翻译 以下为原文 Yes, we are using PCoIP. Sounds like that entry in those release notes you linked could be the issue. |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3396 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3818 浏览 4 评论
/9
GMT+8, 2025-12-1 21:00 , Processed in 1.308654 second(s), Total 83, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2369
