电子发烧友论坛|
你好,
我尝试使用特斯拉M10的passthrough功能,但我遇到了一些问题。 我有一台带特斯拉M10的DL380 G9。 我已在其上安装了VMware ESXi 6.0.0U2,并部署了Windows 7专业版虚拟机。 使用VSphere客户端,在“高级参数”上激活passthrough。 我在我的VM上分配GPU,然后重新启动它。 不幸的是,passthrough不起作用。 实际上,我有一个DL380的显示器插头,但我只看到ESXi接口,而不是Windows 7 VM的桌面。 我认为使用此功能或激活它需要NVidia许可证,但我不知道在哪里使用此许可证。 谢谢你提前帮助你 马蒂厄 以上来自于谷歌翻译 以下为原文 Hello, I try to use passthrough functionality with a Tesla M10 but I meet some issue. I have a DL380 G9 with a Tesla M10. I have installed VMware ESXi 6.0.0U2 on it and I deployed a Windows 7 pro virtual machine. With VSphere client, on "Advanced Parameter" I activate passthrough. I assign on GPU on my VM and I restart it. Unfortunately, the passthrough does not work. Indeed, I have a monitor plug to the DL380, but I only see ESXi interface, and not the desktop of Windows 7 VM. I think that a NVidia license is needed to use this functionality, or to activate it, but I don't know where use this license. Thanks id advance for your help Mathieu |
11个回答
所以,我有一些关于我的问题的消息。
我发现要在我的ESXi上安装好的.vib文件。 在此安装之后,在VSphere上可以很好地检测到Tesla M10卡。 现在,我尝试在Windows 7 VM上安装驱动程序,但未检测到兼容资料... 以上来自于谷歌翻译 以下为原文 So, I have some news about my issue. I found the good .vib file to install on my ESXi. After this installation Tesla M10 card is well detected on VSphere. Now, I try to install driver on Windows 7 VM but no compatible material is detected... |
嗨Matthieu,
首先,我建议仔细研究一下我们的部署指南。 你想要达到什么目的? Passthrough不需要vGPU管理器! 如果要部署vGPU,则需要GRID门户中正确的vGPU管理器/驱动程序组合。 请注意,这需要软件许可证,公共NV下载页面不提供。 如果您能描述您想要实现的目标,我很乐意指导您做什么以及从何处获得所需资源。 问候 西蒙 以上来自于谷歌翻译 以下为原文 Hi Matthieu, first of all I would recommend to have a closer look into our deployment guides. What are you trying to achieve? Passthrough doesn't require the vGPU manager! And if you want to deploy vGPU you need the correct vGPU manager/driver combination from the GRID portal. Please be aware that this requires a software license and is not available on the public NV download page. If you could describe what you want to achieve I'm happy to guide you what to do and where to get the required resources. Regards Simon |
西蒙你好,
操作的目的是将Windows 7 VM显示重定向到KVM,插入DL 380 VGA连接,这要归功于直通功能。 我已经在我的服务器上安装了.vib,我将新的PCIe组件分配给我的VM(使用VSphere客户端)但是当我尝试安装NVidia驱动程序时,我有错误消息告诉“没有检测到兼容的材料”。 问候, 马蒂厄 以上来自于谷歌翻译 以下为原文 Hello Simon, The aim of the manipulation is to redirect Windows 7 VM display to the KVM, plug on DL 380 VGA connection, thanks to passthrough functionality. I already installed .vib on my server, I assign new PCIe component to my VM (with VSphere client) but when I try to install NVidia driver, I have error message which tell that "no compatible material detected). Regards, Mathieu |
嗨Mathieu,
你试过哪个司机? 您需要为M10使用支持Tesla的驱动程序。 在此处创建一个帐户:http://www.nvidia.com/content/token-link/index.html并下载管理程序的驱动程序包。 正如我所说,您需要为您的用例购买软件许可证。 问候 西蒙 以上来自于谷歌翻译 以下为原文 Hi Mathieu, which driver did you try? You need to use a Tesla capable driver for M10. Create an account here: http://www.nvidia.com/content/token-link/index.html and download the driver package for your hypervisor. As I said you require to buy software licenses for your use case. Regards Simon |
西蒙你好,
总结一下情况: 我在ESXi上安装了NVIDIA-vGPU-VMware_ESXi_6.0_Host_Driver_367.106-1OEM.600.0.0.2494585 在我使用Windows 7的VM上,我安装了370.12_grid_win8_win7_server2012R2_server2008R2_64bit_international 在此之后,我在VM控制台上获得了黑屏。 我取消激活passthrough,重新启动VM,取消激活VMWARE SVGA驱动程序,关闭Windows并重新启动直通。 现在,我的控制台运行良好。 但是,要看Windows,我使用的是VSphere客户端。 监视器插在HP proliant上,我希望在此监视器上看到Windows。 关于许可证,我们在购买HP proliant时买了它们,所以我在上一个链接上输入:)。 以上来自于谷歌翻译 以下为原文 Hello Simon, To sum up the situation :
After this, I obtained a black screen on my VM console. I de-activate passthrough, relaunch the VM, de-activate VMWARE SVGA driver, shutdown Windows and re-put the passthrough. Now, my console work well. But, to see Windows, I use VSphere client. A monitor is plug on the HP proliant and I would like to see Windows on this monitor. Concerning the licence, we bought them when we buy the HP proliant so I enter them on the previous link :). |
那么这是预期的行为。
分配vGPU配置文件后,您将无法使用VMWare控制台管理VM。 您需要使用RDP或Citrix / VMWare等任何其他远程协议。 以上来自于谷歌翻译 以下为原文 Well this is expected behavior. As soon as the vGPU profile is assigned you won't be able to administer the VM with the VMWare console. You need to use RDP or any other remoting protocol like Citrix/VMWare. |
真??
你期望在那里看到虚拟机的控制台? 您真的了解虚拟化的工作原理吗? 甚至硬件如何工作 服务器上的VGA端口连接到板载GPU,与Tesla卡无关 说实话,你不会看到来自任何VM的视频输出 为什么你甚至想在那里看到它,有什么意义呢 以上来自于谷歌翻译 以下为原文 Really?? you expected to see there console of Virtual Machine?? Do you really understand how virtualization works? even how hardware works VGA port on server connected to onboard GPU, which has no relation to Tesla card to put it simple you will not see there video output from any VM why on earth you even want to see it there, what is the point |
你好蜘蛛侠,
是的我了解虚拟化的工作原理。 但对于非常具体的用途,我们需要通过图形卡查看VM。 在另一台使用quadro K2000 GPU的计算机上,我在VM上配置了passthrough(成功)并将我的显示器插在此卡上。 我看到了VM桌面。 但是对于特斯拉卡,由于没有办法在其上插上显示器,我想这是不可能的。 以上来自于谷歌翻译 以下为原文 Hello Spiderman, Yes I understand how virtualization works. But for one of very specific use, we need to see the VM through the graphic card. On another computer, with quadro K2000 GPU, I configure passthrough on the VM (with success) and plug my monitor on this card. And I see the VM desktop. But with tesla card, as there is no way to plug monitor on it, I suppose that is not possible. |
您好Mathieu_R
这是正确的,Tesla GPU无法接受物理监视器连接。 您所指的GPU(K2000)是Quadro GPU。 任何服务器都不支持它,因为它设计用于PC /工作站。 如果您想查看M10的输出,您需要使用您选择的远程协议。 稍微偏离主题,但如果您使用的是XenServer,则可以使用Hypervisor控制台,但ESXi不支持此功能。 问候 本 以上来自于谷歌翻译 以下为原文 Hi Mathieu_R This is correct, Tesla GPUs do not have the ability to accept a physical monitor connection. The GPU you are referring to (the K2000) is a Quadro GPU. It is not supported in ANY servers, as it is designed to work in a PC / Workstation. If you would like to see the output of the M10, you'll need to use a remoting protocol of your choice. Slightly off topic, but if you were using XenServer, you'd be able to use the Hypervisor console, but ESXi does not support this functionality. Regards Ben |
嗨西蒙,
我一直在使用与Nvidia GRID K1的直通来基本上将4个GPU链接到4个VM。 然后使用VMware Horizon(Blast协议)连接到VM。 它工作正常,我得到3D渲染等。我从来没有需要任何GRID许可来做到这一点。 好吧,我选择使用vDGA,因为vGPU不是带有GRID K1的Linux VM的选项,然后我有点喜欢使用vDGA,因为我认为它提供了更好的性能。 我正在计划硬件刷新,根据快速搜索,GRID K1的最佳替代品是Tesla M10(4GPU和32Gb内存)。 是否可以使用M10复制相同的设置而无需许可证? 基本上,将GPU PCI设备添加到VM,安装通用Nvidia驱动程序并渲染3D对象。 谢谢, 莫 以上来自于谷歌翻译 以下为原文 Hi Simon, I have been using passthrough with Nvidia GRID K1 to basically link the 4 GPUs to 4 VMs. Then connect to the VMs using VMware Horizon(Blast protocol). It was working fine and I get 3D rendering etc.. I have never needed any GRID licencing to do this. Well, I have opted to use vDGA since vGPU was not an option for Linux VMs with GRID K1, then I kind of liked using vDGA since I think it provides better performance. I am planning a hardware refresh, and according to a quick search, the best alternative for the GRID K1 is the Tesla M10 (4GPU and 32Gb memory). Is it possible to replicate the same setup using M10 without the need for a licence? Basically, add the GPU PCI device to the VM, Install the generic Nvidia driver and render 3D objects. Thanks, Mo |
你好Medalibi,
您可以使用M10复制用例,但是对于在Passthrough中运行的每个VM,您还需要QvDWS许可证。 最好的祝福 西蒙 以上来自于谷歌翻译 以下为原文 Hi Medalibi, You can replicate the use case with M10 but you need QvDWS licenses in addition for every VM running in Passthrough. Best regards Simon |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3396 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3819 浏览 4 评论
/9
GMT+8, 2025-12-2 07:21 , Processed in 1.063765 second(s), Total 92, Slave 75 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1454
