大家好,我正在尝试测量光信号,并提出一些问题。
- 我的DUT(LED)连接到VNA(8753ES)的端口1,并接收直流偏置+ VNA信号 - DUT发出光电探测器收集的光信号(光电二极管+跨阻放大器,50欧姆终端) 连接到端口2 - 我测量S21的幅度作为接收的光信号*首先,我想知道在校准S21的端口2是否有任何意义(至少对于幅度),如果是,我应该如何继续。 *其次,我不确定如何解释S21信号。 原则上S21是比率功率测量,但我在这里测量的是绝对光功率。 我接着看哪个单位? *最后,光电探测器将光功率转换为电压,这是我想要的。 但VNA测量功率。 那么光电探测器的电压是否与VNA的S21信号的sqrt成正比呢? 谢谢,对不起,如果这里有愚蠢的问题! 以上来自于谷歌翻译 以下为原文 Hi all, I am trying to measure an optical signal and have a few questions. - my DUT (an LED) is connected to port 1 of the VNA (8753ES), and receives a DC bias + the VNA signal - the DUT emits an optical signal collected with a photodetector (photodiode + transimpedance amplifier, with 50ohm termination) which is connected to port 2 - I measure the amplitude of S21 as the received optical signal * First, I am wondering if there is any sense in calibrating port 2 for S21 (at least for amplitude), and if so how I should proceed. * Second, I am not sure how to interpret the S21 signal. In principle S21 is a ratioed power measurement, but what I am really measuring here is an absolute optical power. What unit am I then looking at? * Finally, the photodetector converts optical power to voltage, which I want to emasure. But the VNA measures power. Is it then correct that the photodetector's voltage is proportional to the sqrt of the VNA's S21 signal? Thanks, and sorry if there are dumb questions here! |
2个回答
您可能需要查看一个HP / 8702D光波组件网络分析仪的手册。
我相信它基本上是一个带有一些额外光学位的8753。 VNA用于测量S参数。 S参数根据电压比而非功率来定义。 S21具有幅度和相位。 戴夫。 以上来自于谷歌翻译 以下为原文 You might want to look at the manual of a for one HP /8702D Lightwave Component Network analyzer. I believe it is basically an 8753 with some extra optical bits. VNAs are used to measure S parameters. The S-parameters are defined in terms of ratios of voltages, not powers. S21 has both a magnitude and a phase. Dave. |
嗨戴夫,谢谢你的想法。 1)我应该补充一些细节。 我在测量光学响应的同时测量DUT的S11参数(电反射) - 因此首先使用VNA。 DUT发射400-450nm的光,这使事情复杂化。 我研究了Lightwave组件分析仪; 它们会很棒,因为集成光学探测器在幅度和相位方面都经过校准,但它们似乎都专用于红外电信波长。 因此,我相信我唯一的选择是使用插在VNA第二个端口上的“标准”光电探测器进行仅振幅S21测量。 我现在正在做这个并且正在接收信号,但是没有任何校准步骤(我只校准了S11),频率响应具有寄生效应。 我想知道一些(振幅)校准步骤是否有意义。 或者,是否有人知道可见光范围内的光电探测器带有校准数据(在HF寄生效应的意义上)? 2)是的,S-params =电压测量,没有问题,谢谢! 以上来自于谷歌翻译 以下为原文 Hi Dave, thanks for the thoughts. 1) I should have added a few more details. I am measuring the DUT's S11 parameter (electrical reflection) at the same time as its optical response - hence the use of a VNA in the first place. The DUT emits light at 400-450nm which complicates things. I looked into Lightwave component analyzers; they would be great, as the integrated optical detectors are calibrated in both amplitude and phase, but they appear to all be dedicated for infrared telecom wavelengths. So, I believe my only option is to use a "standard" photodetector plugged on the VNA's second port for an amplitude-only S21 measurement. I am doing this now and am getting a signal, but without any calibration step (I only calibrated S11) the frequency response has parasitics. I'm wondering if some (amplitude) calibration step makes sense. Alternately, does anyone know of a photodetector in the visible range with calibration data (in the sense of HF parasitics)? 2) Yes, S-params = voltage measurements, no problem there, thanks! |
只有小组成员才能发言,加入小组>>
2091 浏览 1 评论
1850 浏览 1 评论
1707 浏览 5 评论
2577 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1558 浏览 4 评论
497浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
355浏览 0评论
1405浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
268浏览 0评论
2254浏览 0评论
GMT+8, 2024-4-19 18:43 , Processed in 1.082790 second(s), Total 70, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
