电子发烧友论坛|
我正在研究电感器和电容器的无源滤波项目,其设计规格对于2 MHz及更低频率的频率具有至少40 dB的衰减。
该规范还要求测量衰减,同时滤波器具有高达17安培的高直流电流。 有人建议在施加高电流时如何连接Agilent E5071C VNA进行电路的传输测量(S21或S12)?另一个要测量的参数是电路的电感值,同时施加高电流。 我有一台用于测量的Agilent 4263B LCR测量仪,但是:有人建议在施加高电流时如何将LCR测量仪连接到电路吗?我首先想到的是在滤波器的输入端使用偏置T型接头, 输出导致进行这些测量,但我不知道制造商是如何制造这么高的电流。感谢任何帮助和建议。 以上来自于谷歌翻译 以下为原文 I am working on a passive filtering project of inductors and capacitors which has a design spec with a minimum of 40 dB attenuation for frequencies at 2 MHz and lower. The spec also calls for measuring the attenuation while the filter has a high DC current of up to 17 amps applied to the circuit. Does anybody have a suggestion for how to connect an Agilent E5071C VNA for a transmission measurement (S21 or S12) of the circuit while the high current is applied? Another parameter to be measured is the circuit's inductance value while the high current is applied. I have an Agilent 4263B LCR meter for the measurement, but again: does anybody have a suggestion for how to connect the LCR meter to the circuit while the high current is applied? My first thought was to use bias-Tees on the filter's input and output leads to do these measurements, but I don't know of a manufacturer who makes them for such a high current. Thanks for any help and suggestions. |
相关推荐 |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 12:39 , Processed in 0.503845 second(s), Total 40, Slave 33 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4168
