电子发烧友论坛|
大家好
我正在使用STEVAL-MKI121V1板和Discovery-M1-Fw封装,试图摆脱USB接口并将其替换为配置为Slave的SPI。我对最终系统的意图是将iNEMO-M1通过SPI连接到嵌入式Linux机箱。 我可以看到iNEMO_Gatekeeper是外部世界和iNEMO之间的接口,通过使用USB作为传输介质的虚拟COM。 据我所知,有两种解决方案。一种是将虚拟COM更改为使用SPI而不是USB,但在考虑将标准USB-UART转换器配置为虚拟COM时,这在某种程度上没有意义。 另一个解决方案可能是删除虚拟COM并直接在Gatekeeper中设置SPI,但这样我觉得我缺少一些东西来完成集成。 我主要倾向于跳过整个虚拟COM并寻求集成的SPI解决方案,但我非常感谢你们的一些建议。 最好的祝福 RasmusKolds #4-wired-spi#inemo-m1-sample-code 以上来自于谷歌翻译 以下为原文 Hello Everyone I am working with the STEVAL-MKI121V1 board and Discovery-M1-Fw package, trying to get rid of the USB interface and replace it with SPI configured as Slave. My intention for the the final system is to have the iNEMO-M1 connected via SPI to an embedded Linux box. I can see that the iNEMO_Gatekeeper is the interface between the outside world and the iNEMO through a Virtual COM using the USB as the transport medium. As far as I can see, there are two solutions to this. One is to change the Virtual COM to use SPI instead of USB, but in some way this doesn't make sense when thinking of standard USB-UART converters also configured as a Virtual COM's. The other solution could be to remove the Virtual COM and setup the SPI directly in the Gatekeeper, but this way I feel that I am missing something to complete the integration. I am mostly leaning towards skipping the entire Virtual COM and go for the integrated SPI solution, but I would really appreciate some suggestions from you guys. Best Regards Rasmus Kolds� #4-wired-spi #inemo-m1-sample-code |
1个回答
你好。
你为什么要使用SPI? CAN更“标准化”,并且可以使用许多硬件/软件。 以上来自于谷歌翻译 以下为原文 Hi. Why do you want to use SPI? CAN is more ''standardized'' and a lot of HW/SW is available for that. |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 02:33 , Processed in 2.141835 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1753
