你好,
我们有几个Windows 10用户在teradici零客户端上使用双屏幕设置。 每当其中一个用户第一次登录时,右侧监视器立即进入休眠状态,并且在会话期间不会重新开启。 左侧监视器上的鼠标光标卡在屏幕右侧。 试图移动它会导致它跳回到屏幕的右侧。 我们当前的解决方法是断开会话(不注销),再次连接,问题在100%的时间内消失。 我们还可以断开“on”监视器上的dvi电缆并再次连接,然后弹出两个屏幕。 同样,这是100%的时间。 此问题也出现在地平线视图PC客户端,相同的症状和相同的修复,除了在这种情况下修复是简单地调整窗口大小,并出现第二个监视器。 注销后再次出现问题。 视图代理是版本7.0.3,零客户端版本是5.4。 视图客户端是版本4.3,网格驱动程序版本是21.21.13.6995。 ESXI是6.0版。 我们通过交换足够的零客户端和dvi电缆直到它停止来解决一些用户的问题,但是需要几个小时到几周才能找到有用的东西。 这是一个已知问题,是否有任何修复或方法强制第二台显示器在首次登录时连接? 以上来自于谷歌翻译 以下为原文 Hello, We have several windows 10 users with dual screen setups on teradici zero clients. Whenever, one of these users logs in for the first time, the right monitor immediately goes to sleep and does not come back on while in session. The mouse cursor on the left monitor gets stuck on the right side of the screen. Attempting to move it causes it to jump back to the right side of the screen. Our current fix is to disconnect the sessiont (not log off), the connect again and the issue goes away 100% of the time. We can also disconnect the dvi cable for the "on" monitor and connect it again and both screens pop up. Again, this is 100 percent of the time. This issue is also seen on horizon view pc clients, same symptoms and same fix, except that in this case the fix is to simply resize the window and the second monitor appears. Upon logoff and back on the issue appears again. The view agent is version 7.0.3 and the zero client version is 5.4. The view client is version 4.3 and the grid driver version is 21.21.13.6995. ESXI is version 6.0. We resolved the issue for some users by swapping enough zero clients and dvi cables until it stopped, but that takes hours to weeks to find something that works. Is this a known issue and is there any fix or way to force the second monitor to connect on first login? |
3个回答
None
以上来自于谷歌翻译 以下为原文 Hi Greg, did you open a ticket with VMWare? Doesn't sound to be a NV driver related issue. First of all I would recommend to test with the latest NV driver: GRID4.4. Your current confiuration is GRID4.2 so there are new drivers available. In addition you should most likely test with Horizon 7.3.1 to see if the issue is still reproducable. Regards Simon |
是。
我目前在VMware上打开了一张票。 到目前为止,它无处可去,所以我想我会在这里查看,直到我再次收到他们的回复。 谢谢回复。 我已经下载了最新的测试驱动程序,并将在明天回到办公室时应用它们。 我还将测试禁用vmware显示驱动程序,看看是否解决了任何问题。 以上来自于谷歌翻译 以下为原文 Yes. I currently have a ticket open with VMware. It's going nowhere fast so far, so I figured I would check here until I heard back from them again. Thanks for the reply. I have downloaded the latest drivers for testing and will apply them when I am back at the office tomorrow. I will also test disabling the vmware display driver and see if that resolves anything. |
弄清楚了。
我不得不重新安装没有svga适配器的vmware工具,然后重新安装nvidia驱动程序并重新组合。 很奇怪,因为安装指南中的图片显示了在设备管理器中安装了nvidia的驱动程序。 以上来自于谷歌翻译 以下为原文 Figured it out. I had to reinstall vmware tools without the svga adapter, then reinstall the nvidia driver and recompose. Weird, since the pictures in the installation guide shows the driver installed with the nvidia one in device manager. |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3008 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3426 浏览 4 评论
GMT+8, 2024-10-11 06:20 , Processed in 0.993471 second(s), Total 102, Slave 85 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
