我使用ADS中的耦合线电路元件(CLIN)设计了一个滤波器。
在电路模拟器中对其进行了优化。 创建一个布局,然后使用EMPro和Momentum模拟布局。 而且(当然)结果不同......所以自然而然就是在2.5 / 3D EM求解器中开始优化会话,让我的电脑在周末出汗。 这似乎不可行。 我已经看到一些使用Momentum描述优化的Web内容,但那是几个版本之前。 据我所知(现在),我无法以参数化方式将过滤器传输到Momentum或EMPro并从那里运行优化。 所以我的问题是,如果有一种方法可以在Keysight产品中完成,或者我必须重新绘制结构并在竞争产品中对其进行参数化,然后从那里完成设计...... 以上来自于谷歌翻译 以下为原文 I have designed a filter using the coupled lines circuit element (CLIN) in ADS. Optimized it in the circuit simulator. Created a layout and then simulated the layout using EMPro and also Momentum. And (of course) the results differ... So the natural thing would be to start an optimizing session in a 2.5/3D EM solver and let my computer sweat during the week-end. This seems not doable. I have seen some web content descriping optimization using Momentum, but that was several releases ago. As far as I can see (now) there is no way I can transfer the filter in a parameterized way to Momentum or EMPro and run an optimization from there. So my question is if there is a way to do it within Keysight products, or if I have to redraw the structure and parameterize it in a competing product and then finalize the design from there... |
3个回答
> {quote:title = Uky写道:} {quote}>所以很自然的事情就是在2.5 / 3D EM求解器中启动优化会话>让我的电脑在周末结束时出汗。
>>这似乎不可行。 一旦了解了工作流程,就很容易了。 请参阅我的应用说明:http://muehlhaus.com/support/ads-application-notes/em-parameters-momentum 以上来自于谷歌翻译 以下为原文 > {quote:title=Uky wrote:}{quote} > So the natural thing would be to start an optimizing session > in a 2.5/3D EM solver and let my computer sweat > during the week-end. > > This seems not doable. It's easy once you understand the workflow. See my application note: http://muehlhaus.com/support/ads-application-notes/em-parameters-momentum |
嗨,您可以使用模型编辑器并基于动量模拟创建“自己的”CLIN模型。
之后,您可以像在CLIN中一样在原理图视图中多次使用该模型。 创建模型需要一些时间,但它比扫描参数更快。 另外,参数范围可以设置为连续的。 使用两个以上连续参数时会出现警告,但您可以忽略此参数。 以上来自于谷歌翻译 以下为原文 Hi, you could use the model composer and create your "own" CLIN model based on the momentum simulation. afterwards you can use the model multiple times in the schematic view as you do with CLINs. It take some time to create a model but it is way faster than just sweeping parameters. additionally, the parameter range can bet set to be continuous. there will be a warning when using more than two continuous parameters but you can ignore this one. |
只有小组成员才能发言,加入小组>>
1089 浏览 0 评论
2310 浏览 1 评论
2100 浏览 1 评论
1974 浏览 5 评论
2843 浏览 3 评论
850浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
622浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
722浏览 0评论
1411浏览 0评论
1089浏览 0评论
GMT+8, 2024-10-5 06:11 , Processed in 1.274338 second(s), Total 82, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
