大家好!
我正在使用我的Keysight VNA ENA 5072进行声道探测。 如何计算接收器的噪声水平,假设在接收器侧我有天线+同轴电缆+ VNA端口? 先谢谢你。 以上来自于谷歌翻译 以下为原文 Hi everyboy! I'm using my Keysight VNA ENA 5072 for channel sounding. How can I compute the noise level at the receiver assuming that at the receiver side I have antenna+coax cable+VNA port? Thank you in advance. |
1个回答
取决于您使用的参数。
如果您使用带有一对天线的S21,则测量是相对测量,您需要将距离损失归一化(根据您拥有的天线增益)。 所以通常你会使用一些标准增益天线并测量S21。 假设范围损耗为30 dB,那么本底噪声将是您所选带宽下VNA的动态范围减去范围损耗。 假设VNA的动态范围规格为140 dBc。 这通常是10 Hz BW和最大功率。 将噪声基底的变化计算为10 log(IFBW / 10),因此,如果您处于100 kHz IF BW,则会有10log10(10e4)或40 dB更差,因此100 dB,减去30的范围损失并结束 最高-70 dB本底噪声(通常表示为rms)。 以上来自于谷歌翻译 以下为原文 Depends upon what parameter you are using. If you are using S21 with a pair of antennas, then the measurement is a relative measurement and you need to normalize out the range-loss (according the antenna gain that you have). So normally you would use some standard gain antennas and measure S21. Suppose the range loss is 30 dB, then the noise floor will be the dynamic range of the VNA at your chosen bandwidth minus the range loss. Suppose the VNA has a dynamic range spec of 140 dBc. This is typically at a 10 Hz BW and max power. Compute the change in noise floor as 10 log (IFBW/10) so if you are at 100 kHz IF BW, you would have 10log10(10e4) or 40 dB worse, so 100 dB, subtract off the range loss of 30 and you end up with -70 dB noise floor (typically expressed as rms). |
只有小组成员才能发言,加入小组>>
1231 浏览 0 评论
2351 浏览 1 评论
2161 浏览 1 评论
2026 浏览 5 评论
2910 浏览 3 评论
974浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
707浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
808浏览 0评论
1231浏览 0评论
GMT+8, 2024-11-27 01:04 , Processed in 1.421785 second(s), Total 77, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
