大疆无人机都在用的CW2015 1-2节电池电量计芯片,指定芯片,原因是简单易用,没有ti那么复杂,电池一次采集数据,使用终身,精度1-3%
The CW2015 is an ultra‐compact, low‐cost, host‐side/pack‐side, sensing resistor free, fuel gauging system IC for Lithium‐ion(Li+) based batteries in handheld and portable devices. CW2015 tracks Li+ battery’s operational condition and uses state‐of‐art algorithm to report the relative State‐of‐Charge (SOC) of very different battery chemistry systems (LiCoOx, polymer Li‐ion, LiMnOx etc.). CW2015 includes a 14‐bit Sigma‐Delta ADC, a precision voltage reference and build‐in accurate temperature sensor. The IC allows the end‐user to eliminate the expensive sensing resistor which occupies large board area. And the IC also sends out the alarm signal if the battery SOC level reaches pre‐programmed threshold. Quick start function offers the possibility to make an initial estimation of the battery’s SOC, which also enables the IC to be located on system side or pack side, giving the flexibility to system maker on pack choice. CW2015 uses a 2‐wire I2C compatible serial interface that operates in standard (100 kHz), fast (400 kHz). Features • System‐Side or Pack‐Side Fuel Gauging • 3% Maximum Total SOC Measurement Error • 14‐bit Delta Sigma ADC for Temperature and Cell Voltage Measurement • Precision Voltage Measurement • No Offset Accumulation During Life Time • No Full‐to‐Empty Battery Learning Cycles Necessary • No Sense Resistor Required • SOC and RRT available • External Alarm/Interrupt for Low‐Battery Warning Available • Patented “FastCali” gas gauging algorithm • Very Low Active and Sleep Power Consumption - Normal mode 15uA - Sleep mode <1uA • General I2C interface • Tiny, Lead(Pb)‐Free, 8‐Pin TDFN Package Applications • Smartphone • Tablet PCs • Handheld and Portable Applications Typical Application |
相关推荐 |
BP86211D 12V/0.5A家用电器方案DEMO资料分析(电路原理图及BOM)
1499 浏览 0 评论
PD诱骗取电芯片_PD_Sink端芯片之XSP05实战应用电路
2514 浏览 1 评论
BLDC、PMSM电机智能栅极驱动芯片之TMC6140知识分享
1258 浏览 0 评论
国产电源芯片DP4054 软硬件兼容TP4054 规格书资料
1720 浏览 0 评论
3531 浏览 3 评论
/9
GMT+8, 2025-12-12 03:50 , Processed in 0.642747 second(s), Total 46, Slave 34 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4445
