我有一个处理I2C消息的中断例程。正常情况下工作,无噪音。然而,如果我引入足够的噪声导致总线冲突,则SDA线被检测到总线碰撞的设备保持低。我已经通过使用中断检测BUS碰撞并清除BCL2IF、释放CKP、禁用和重新启用EnabLink SpEN来修复它。SDA线可能在公共汽车碰撞时保持低位?在SCL中引入噪声导致器件释放SDA。这表明设备正在期待一个时钟信号?在PIC16F1586数据表(对于我正在使用的设备):32.5.3.1从模式总线冲突,从属设备空闲,等待再次被寻址。我可能需要一点澄清来理解设备进入空闲模式时所做的工作。当跳转到空闲模式时,设备是否突然退出中断?
以上来自于百度翻译 以下为原文 I have an interrupt routine handling I2C messages. Works as expected under normal conditions with no noise. However, if I introduce enough noise to result in a bus collision, the SDA line is held low by the device that detects the bus collision. I have fixed it by detecting the bus collision using an interrupt and clearing BCL2IF, releaseing CKP, and disabling and then re-enabling SSPEN. I'm curios as to why the SDA line might be held low during a bus collision? Introducing noise into SCL results in the device releasing SDA. This suggests that the device is expecting a clock signal? In the PIC16F15386 datasheet (For the device i'm using) : 32.5.3.1 Slave Mode Bus Collision the slave goes idle and waits to be addressed again. I might just need a bit of clarification to understand what the device does when it goes into idle mode. Does the device abruptly exit the interrupt when jumping into idle mode? |
4个回答
你从来没有提到你的PIC是一个主还是奴隶。在一个读事务中间的SCL上的噪声可能会导致一个奴隶开始发送一个主不想要的额外字节。这可能会导致奴隶保持SDA低,等待事务继续进行。从中恢复的干净方式是让主控器释放SDA,并在手动输出停止条件之前手动切换SCL九次。
以上来自于百度翻译 以下为原文 You never mention if your PIC is a Master or a Slave. Noise on SCL in the middle of a read transaction could cause a slave to start sending an extra byte that the Master did not want. THAT could cause the slave to hold SDA low, waiting for the transaction to proceed. The clean way to recover from that is for the Master to release SDA, and manually toggle SCL nine times before manually outputting a STOP condition. |
很抱歉,PIC设备处于从模式。当PIC进入空闲模式时,这会导致代码执行退出中断程序,像往常一样继续,还是冻结?我确实有其他的定时器中断,所以我假设这些也会把它从空闲状态中恢复过来。
以上来自于百度翻译 以下为原文 Sorry about that, the PIC device is in slave mode. When the PIC goes into IDLE mode would this result in the code execution to exit the interrupt routine, continue as usual, or freeze? I do have other timer interrupts so i'm assuming those would also bring it back from the IDLE state. |
HI检测总线碰撞通常是主机的责任,如果一个主机在从一个从属器读取时检测到总线冲突,则主机可以停止时钟,并释放总线。如果没有从从属设备检测到,则I2C从机可以持续等待剩余的时钟信号,包括AC。我认为这是SMBus设备规定的10毫秒超时的原因之一。SSP I2C外围空闲状态和PIC CPU空闲模式是完全不同的现象。I2C在总线碰撞中的外围空闲,意味着MSSP硬件应该放弃它正在做的任何事情,应该是Read。简化SDA和SCL线,并设置Bclif标志。它对指令执行不起作用。ISR和固件的责任是适当地对Bclif作出反应。当PIC在普通的SSP中断的ISR中时,其他中断源被禁用,因此可能有可能您的代码尝试在硬冲突检测到冲突后发送数据。但是,只要设置了Bclif,I2C硬件就应该忽略它。当检测到问题时,所有SSP寄存器的状态是什么?如果你已经确定了一个硬件问题,那么解决僵局的方法对我来说似乎是合理的。你有一个可以用来挑起或验证问题的测试程序吗?如果这个问题可以反复演示,那么它可能是一个理由来支持一个支持票。迈西尔
以上来自于百度翻译 以下为原文 Hi, Detecting Bus collision is ordinarily a responsibility of the Master. If a Master detect a Bus collision during a Read from a Slave, then the Master may stop clocking, and release the Bus. If this is Not detected by the Slave, I2C slave may wait forever for remaining clock signals, including the ACK clock. I think this is one of the reasons for the 10 millisecond timeout prescribed for SMBus devices. SSP I2C peripheral idle state and PIC CPU IDLE mode are completely different phenomena. I2C peripheral idle on Bus collision, means that MSSP hardware shall give up whatever it is doing, should release SDA and SCL lines, and set BCLIF flag. It do nothing with instruction execution. It is responsibility of ISR and firmware to react to BCLIF as appropriate. When PIC is in ISR for ordinary SSP interrupt, other interrupt sources are disabled, so it may be possible that your code have tried to send data after collision was detected by hardware, but that should be ignored by I2C hardware as long as BCLIF is set. When problem is detected, what is state of all SSP registers? If you have actually identified a hardware problem, then the workaround to resolve the stalemate seem reasonable to me. Do you have a test program that may be used to provoke or verify the problem? If the problem can be demonstrated repeatedly, then it may be reason to raise a support ticket. There is nothing about anything like this in Errata document for the device. Mysil |
谢谢你的回复!!!!解决方案并不简单,但Qub在解决方案的正确轨道上,MysIL帮助识别了一个我的情况的边缘情况。主设备似乎已经失去了仲裁,停止了SCL线的时钟,使从设备在某种程度上处于等待状态,同时保持从设备。ICE持有SDA线低。我们必须编辑Linux I2C内核驱动程序,并添加IOCTL调用来控制IMX6处理器(主控器)上的I2C引脚。为了快速解决方案,我们只使用9个时钟控制IO内存位置。后来我们把它改为16个时钟,因为9个时钟不会总是解决锁定问题。我们仍然需要添加一个停止条件,但是这对我们来说是有效的。谢谢。
以上来自于百度翻译 以下为原文 Thank you for the replies!!! The solution was not simple but QUB was on the right track for the solution and Mysil helped identify an edge case for my situation. The master device seems to have lost arbitration and stopped clocking the SCL line leaving the slave device in some sort of a waiting state while holding the slave device held the SDA line low. We had to edit the Linux I2C kernel drivers and add an IOCTL call to control the I2C pins on the IMX6 processor (The Master). For a quick solution we just controlled the IO memory locations using 9 clocks. We later changed it to 16 clocks since 9 clocks would not always solve the lock up issue. We still need to add a stop condition but this is working for us now. Thank you |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1097浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 08:47 , Processed in 0.751463 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2082
