我们正在测试Win 10和XenDesktop 7.6,当我连接到VDA时,一切正常,您可以使用GPU-Z看到它使用vGPU配置文件(180Q),但是当我启动AutoCad Arch时。
2015年它选择“Citrix Display Only适配器”,结果是AutCad报告它没有使用硬件加速。 我有一个非常丑陋的解决方法,包括从HKCU regkey等删除NTFS权利,这不是我希望的正确方法...... 有没有其他人看到这种行为,也许有一个解决方案让AC选择GPU而不是默认的驱动程序? 以上来自于谷歌翻译 以下为原文 We are testing Win 10 and XenDesktop 7.6 and when I connect to the VDA Everything works and you can see, using GPU-Z, that it uses the vGPU profile (180Q) but when I start AutoCad Arch. 2015 it picks the "Citrix Display Only adapter" and a consequence is that AutCad reports that it is not using hardware acceleration. I have a really ugly workaround which includes removing NTFS rights from a HKCU regkey etc and that can't be the correct way I hope... Has anyone else seen this behaviour and perhaps have a solution to getting AC to pick the GPU instead of the default driver?? |
1个回答
看到这个帖子
https://gridforums.nvidia.com/default/topic/669/after-driver-update-some-autocad-lt-fails-to-use-hardware-driver/ 以上来自于谷歌翻译 以下为原文 See this thread https://gridforums.nvidia.com/default/topic/669/after-driver-update-some-autocad-lt-fails-to-use-hardware-driver/ |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
2896 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3316 浏览 4 评论
GMT+8, 2024-7-3 15:35 , Processed in 0.806979 second(s), Total 76, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
