嗨,大家好,
我现在正在这个论坛上写作,因为我在POC期间发现了一个问题。 在我的dell服务器(r730 + nvidia grid k2)上,我已经配置了esxi6 + horizon视图6.2,其中windows 7 64bit作为已部署的vms。 我已经安装了autodesk发明者2015,但我注意到无法启用视频硬件加速。 每次启动发明人时,软件图形“复选框”(在应用程序选项/硬件下)都会启用,如果我在下次打开软件时取消检查,则会再次启用。 我试过: 1 - 迫使应用程序使用nvidia卡trought nvidia控制面板 2 - 禁用集成的vmware视频卡(但在这种情况下dxdiag给我一个错误) 3修改发明人配置的文件,如本论坛所述http://www.arch-pub.com/Experien ... nment_10624911.html 在第三点之后可以禁用复选框但是如果我启动集成测试,它会报告正在使用的视频硬件是vmware 3d vga而不是nvidia网格。 有什么建议么..??? 以上来自于谷歌翻译 以下为原文 Hi guys, I'm now on this forum and I'm writing because i've find a problem during a POC. On my dell server ( r730 + nvidia grid k2) i've configured esxi6+horizon view 6.2 with windows 7 64bit as deployed vms. I've installed autodesk inventor 2015 but i've noticed that is impossible to enable the video hardware acceleration. Every time that i launch inventor the software graphics "checkbox" (under application options/hardware) is enabled and if I remove the check next time I open the software is enabled again. I've tried to: 1-force the application to use nvidia card trought nvidia control panel 2-disable integrated vmware video card (but in this case dxdiag gives me an error) 3-modify inventor configuration's file as suggested in this forum http://www.arch-pub.com/Experien ... nment_10624911.html after the third point is possible to disable the checkbox but if I launch the integrated test it report that the video hardware in use is the vmware 3d vga instead of the nvidia grid. Any suggestions..??? |
7个回答
您是否看过这个帖子:https://gridforums.nvidia.com/default/topic/699/autodesk-are-picking-the-wrong-gpu-when-connectint-with-xendesktop/其他可能有Autodesk经验的人
... Citrix和VMware论坛也是一个很好的信息来源:http://discussions.citrix.com/forum/523-gpu-technologies/虚拟机管理程序实现非常相似,因此如果它的应用程序特定值得检查两个VMware 和citrix。 如果他们知道具体的Autodesk发明者问题,我会问我们的解决方案团队。 以上来自于谷歌翻译 以下为原文 Have you seen this thread: https://gridforums.nvidia.com/default/topic/699/autodesk-are-picking-the-wrong-gpu-when-connectint-with-xendesktop/ there maybe others with Autodesk experience on it... The Citrix and VMware forums are also a good source of info: http://discussions.citrix.com/forum/523-gpu-technologies/ The hypervisors implementations are very similar so if it's application specific worth checking out both VMware and citrix. I'll ask our solutions team if they know of specific autodesk inventor gotchas too. |
谢谢你的回答,我试图找到有关链接的更多信息,但我还没有找到解决方案。
我试过这个建议 http://answers.microsoft.com/en-us/windows/forum/windows8_1-hardware/in-the-registry-appinitdlls-lists-the-same-dll/857afbe1-6b2b-40ff-b6e5-0a0ec01421a1?auth= 1 同 https://support.microsoft.com/en-us/kb/197571 但不是改变...... :( 一个非常奇怪的想法是,autodesk autocad 2015与网格卡的3D加速功能完美配合... 以上来自于谷歌翻译 以下为原文 Thanks for the answer, I've tried to find more information on the links but I haven't found a solution. i've tries this suggests http://answers.microsoft.com/en-us/windows/forum/windows8_1-hardware/in-the-registry-appinitdlls-lists-the-same-dll/857afbe1-6b2b-40ff-b6e5-0a0ec01421a1?auth=1 with https://support.microsoft.com/en-us/kb/197571 but nothig change... :( a very strange think is that autodesk autocad 2015 work perfectly with 3d acceleration enable with grid card... |
如果您确定其他应用程序可以使用GPU并且正在使用NVIDIA驱动程序,那么它确实具有发明特定性。
我已经看到这个在Citrix堆栈上运行,所以也许在VMware论坛上询问; 我没有很多View经验(我本月从Citrix的vGPU项目加入了NVIDIA,因此无法/不能使用View) 以上来自于谷歌翻译 以下为原文 It does sound inventor specific, if you are sure other apps can use the GPU and the NVIDIA driver is in use. I've seen this running on the Citrix stack so perhaps asking on the VMware forums; I haven't had a lot of View experience (I joined NVIDIA this month from the vGPU projects at Citrix so couldn't/didn't work on/with View) |
嗨,大家好,
在几乎相同的问题中运行。 ESX6,GRID K2,XenDesktop 7.9,Windows 7,Inventor 2015。 从DeviceManager中删除VMware Graphics。 Auto CAD使用Grid K240Q - 始终检查Inventor“软件图形”。 编辑hardwarelibrarydm并将所有Citrix-Values更改为50 - 无效。 任何意见,将不胜感激。 图形设备信息: 渲染器:SW 制造商:NVIDIA 芯片类型:GRID K240Q DAC类型:集成RAMDAC 图形硬件内存:892 MB 显示模式:1073741824 x 1073741824(1073741824位)(1073741824 Hz) 图形驱动程序文件:nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um 驱动程序文件版本:10.18.13.5480 司机日期:2016年2月17日0:00:00 UTC(世界协调时间) 图形驱动日志信息: 无法从适配器创建设备。 DXDIAG显示没有错误。 马尔科 以上来自于谷歌翻译 以下为原文 Hi guys, running in nearly the same problem. ESX6, GRID K2, XenDesktop 7.9, Windows 7, Inventor 2015. Di***aled VMware Graphics from DeviceManager. Auto CAD uses Grid K240Q - in Inventor "Software Graphics" is always checked. Edited hardwarelibrarydm and changed all Citrix-Values to 50 - no effect. Any advice would be appreciated. Graphics Device Information: Renderer: SW Manufacturer: NVIDIA Chip Type: GRID K240Q DAC Type: Integrated RAMDAC Graphics HW Memory: 892 MB Display Mode: 1073741824 x 1073741824 (1073741824 bit) (1073741824 Hz) Graphics driver file: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um Driver file version: 10.18.13.5480 Driver Date: 17 February 2016 0:00:00 UTC (Coordinated Universal Time) Graphics driver log information: Failed to create a device from the adapter. DXDIAG shows no errors. Marco |
..刚更新到最新的GRID驱动程序(ESX Host和Win7 VM),没有变化。
图形驱动程序文件:nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um 驱动程序文件版本:10.18.13.6256 发布日期:2016年5月10日0:00:00 UTC(世界协调时间) 图形驱动日志信息: 无法从适配器创建设备。 无法从适配器创建设备。 无法从适配器创建设备。 无法从适配器创建设备。 无法从适配器创建设备。 无法从适配器创建设备。 以上来自于谷歌翻译 以下为原文 .. just updated to the lastest GRID dirvers (ESX Host and Win7 VM), no change. Graphics driver file: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um Driver file version: 10.18.13.6256 Driver Date: 10 May 2016 0:00:00 UTC (Coordinated Universal Time) Graphics driver log information: Failed to create a device from the adapter. Failed to create a device from the adapter. Failed to create a device from the adapter. Failed to create a device from the adapter. Failed to create a device from the adapter. Failed to create a device from the adapter. |
嗨伙计,
您可以查看Inventor 2015补丁级别吗? Autodesk存在已知问题,并在SP2中发布了修复程序,因此您需要将VMware从基础升级到SP2 此修复程序在https://knowledge.autodesk.com/sites/default/files/file_downloads/INV19130_enu.htm中描述为“改进的VMWare GPU性能” 如果在基础发明者中是否禁用Windows设备管理器中的vmware适配器,那么也可能值得一看,这样可以为我提供可能发生的事情的线索。 非常感谢, 雷切尔 以上来自于谷歌翻译 以下为原文 Hi folks, Could you check the Inventor 2015 patch level. Autodesk has a known issue and issued a fix in SP2 so you need to upgrade for VMware from base to SP2 the fix is described as "Improved GPU performance for VMWare" in https://knowledge.autodesk.com/sites/default/files/file_downloads/INV19130_enu.htm It may also be worth seeing if on a base inventor whether disabling the vmware adapter inside Windows Device Manager works as that would give me a clue as to what might be happening. Many thanks, Rachel |
大家好,
我可以确认Rachels解决方案。 安装Inventor SP2已修复我的问题和硬件渲染已启用。 但是我必须完全重新安装Inventor - 只是在我现有的安装中添加SP2不起作用! 再次感谢Rachel - 在某种程度上,它很难在Citrix,VMware,NVidia和Autodesk之间跳转以获得解决方案。 希望将来会有所改善;) 以上来自于谷歌翻译 以下为原文 Hi all, I can confirm Rachels solution. Installing Inventor SP2 fixed my Problem and Hardware Rendering was enabled. However I had to reinstall Inventor completely - just adding SP2 to my existing Installation did not work! Thanks again Rachel - somehow its hard this times to jump between Citrix, VMware, NVidia and Autodesk to get a solution. Hope this will improve in future ;) |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
2836 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3227 浏览 4 评论
GMT+8, 2024-4-27 17:28 , Processed in 0.739118 second(s), Total 77, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
