你好!
我目前的设置如下: 带有NVIDIA GRID K1的10x PowerEdge R730 2xE5-2650v3 @ 2.30Ghz 它运行的XenServer 6.5与Xendesktop 7.6及所有更新。 虚拟机配置如下: 4vcpu K120Q 4gbram 我知道deepcompressioncodecv2是在CPU上编码流,但是可以使用GPU吗? 就像影戏和家庭蒸汽流一样? 在我看来,这会给我们带来更好的体验。 只是为了好玩,我从上面发布的virutalmachine规范中安装了蒸汽和流半衰期2和60fps @ 720p。 这是非常顺利的经历。 来自Nvidia的任何人都有一些技巧吗? 是否可以禁用CPU编码? 我知道在Xendesktop 5.6中可以使用“DeepCompDisable”注册表修复。 以上来自于谷歌翻译 以下为原文 Hello! My current setup is the following: 10x PowerEdge R730 2xE5-2650v3 @ 2.30Ghz with NVIDIA GRID K1 Its running XenServer 6.5 with Xendesktop 7.6 with all updates. The Virtual Machine is configured the following: 4vcpu K120Q 4gbram I know the deepcompressioncodecv2 is encoding the stream on the CPU, but is it possible to use the GPU instead? Like the shadowplay and steam-in-home streaming is using? This would give a better experiance in my opinion. Just for fun i installed steam and streamed half-life2 with 60fps @ 720p from the virutalmachine spec posted above. It was totally smooth experience. Anyone from Nvidia have some trick up there sleve? Is it possible to disable the CPU encoding? I know this was possible in Xendesktop 5.6 with "DeepCompDisable" registry fix. |
9个回答
这是Citrix的一个问题......
他们确实在2015年GTC期间展示了这一特色,但你需要问他们如何...... 以上来自于谷歌翻译 以下为原文 That's a question for Citrix... They did demonstrate that very feature during GTC 2015, but you'll need to ask them how... |
谢谢,我在Xendesktop论坛上提出了一个新主题。
你知道演示是否记录了吗? 如果确实如此,你能指出我吗? 谢谢你的帮助。 以上来自于谷歌翻译 以下为原文 Thanks, I made a new topic in the Xendesktop forum. Do you know if the demonstration did get recorded? And if it did, can you point me to it? Thanks for any help. |
他们在他们的展台上展示了它,它没有在任何会议中报道。
以上来自于谷歌翻译 以下为原文 They had it demonstrated on their booth, it wasn't covered in any sessions. |
Synergy的任何东西都来自于此?
我们一直在争论这个问题,很高兴看到我们可能会有一个解决方案。 以上来自于谷歌翻译 以下为原文 Anything come from this at Synergy? We've been battling this for a bit now, nice to see we might have a solution on the horizon. |
你问Citrix了吗?
由于它是他们产品的一部分,尚未发布他们的计划属于NDA,他们只会在1:1的NDA讨论中分享他们的计划。 在宣布之前,我们无法告诉你任何细节。 以上来自于谷歌翻译 以下为原文 Have you asked Citrix? As it's part of their product, and not yet released their plans are under NDA, and they will only share their plans under a 1:1 NDA discussion. We wouldn't be able to tell you any detail until after it's been announced. |
我有同样的事情。
问题主要是正在进行压缩的CTXGFX.exe。 CPU使用率很高是正常的。 如果您想要它,请尝试禁用重压缩和“额外颜色压缩”。 我做了一个技巧,我给了(在我的情况下)AutoCAD只对Core 0/1/2和ctxcfg.exe的亲和力我只提供了对核心3的访问(GRID之后的压缩是否在通过线路发送之前进行了渲染等) , 这样他们就不会互相干扰。 我为它写了一个小工具,如果你想要它,请给我。 效果很好! 以上来自于谷歌翻译 以下为原文 I had the same thing. Problem is mostly CTXGFX.exe that is doing the compression. Big CPU usage is normal. Try disabled Heavy compression and "Extra colour compression" if you want it down. I did a trick where I give (in my case) AutoCAD only affinity to Core 0/1/2 and ctxcfg.exe I gave only access to core 3 (Does the compression after GRID did the rendering etc before sending it over the line), That way they don't interfer with eachother. I wrote a little tool for it, PM me if you want it. Works great! |
这是一个很好的方法,一个自动完成的工具对很多人来说都很有价值。
你应该在上面写一篇文章,我会帮助在整个社区推广它。 以上来自于谷歌翻译 以下为原文 That's a great approach, and a tool that will do it automatically would be valuable to a lot of people. You should write an article on it and I'll help promote it around the community. |
听起来非常有趣的jaccow。
我真的很想尝试你的软件。 我将查看您上面提到的其他两项政策。 谢谢。 以上来自于谷歌翻译 以下为原文 That sounds very interesting jaccow. I would really like to try your software if its possible. I will check out the two other policies you mentioned above. Thanks. |
是的我创建了一个接受参数并设置CPU亲和力的程序。
我将AutoCAD设置为核心#1,将CTXGFX设置为#234。 在我的情况下(2,2Ghz核心)它确实有帮助,因为AutoCAD有1个干净的核心可以使用,Citrix不是这样,并有足够的果汁来保持会话顺利。 任何有兴趣的人都告诉我你的电子邮件我会把你发给我的程序发给你。 使用风险自负,不建议在生产环境中使用。 这只是我为我的测试平台做的事情。 SetProcAffinity.exe用法: SetProcAffinity [processname] [亲和力值] - processname区分大小写! 即记事本,SearchIndexer - 亲和力值是处理器的按位表示 即1,2,4,8 ...... 或者像7,13这样的值的组合 例: SetProcAffinity记事本73 这将设置进程记事本与处理器0,3和6的亲和性。 如果你能欣赏这个工具,可以考虑比特币捐赠: 17RtdQU9A8UkHn***5h6opcNYQkypXq5BkN 以上来自于谷歌翻译 以下为原文 Yes I made a program that takes arguments and sets the CPU affinity. I set AutoCAD to core #1 and CTXGFX to #234. In my case (2,2Ghz cores) it does really help because AutoCAD has 1 clean core to work with and Citrix is not n the way and has enough juice to keep the session smooth. Anyone interested pm me your email I'll send you the program I made. use at own risk and would not recommend this in a production eviorment. it's just something I made for my testbed. SetProcAffinity.exe usage: SetProcAffinity [processname] [affinity value] - processname is case sensitive! i.e. notepad, SearchIndexer - affinity value is the bitwise representation of the processors i.e. 1, 2, 4, 8.... or a combination of values like 7, 13 Example: SetProcAffinity notepad 73 This will set the affinity of process notepad to processors 0, 3 and 6. If you can appreciate this tool, consider a bitcoin donation: 17RtdQU9A8UkHn***5h6opcNYQkypXq5BkN |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3398 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3819 浏览 4 评论
/9
GMT+8, 2025-12-2 11:51 , Processed in 0.947864 second(s), Total 90, Slave 73 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1837
