你好。
我叫马里奥。 我的问题是,我需要将接收器校准到相位? 我要解决的问题是,如果我已经激活了接收器(in)并且我使用功率校准接收器进行了校准,并且它们是R1_1或R3_1,我怎么知道它们与源1同相。 设置我有(PORT1)和OUT(PORT2)中的双向耦合器(in)。 耦合和术语终止在R3_1和c_1中,之前使用我之前使用的方法进行校准。 我的问题是,我怎么知道R3_1和C_1与port1中的source1同相。 感谢您最好的时间。 对不起我的英语不好。 这不是我的第一语言编辑:Vai11于2015年9月10日下午1:37 以上来自于谷歌翻译 以下为原文 Hi. My name is Mario. My question is about, what I need to calibrate the receivers to the phase?. The problem i wan to resolve is , if I have the receivers (in) activated and I calibrated with the power calibration receivers and they are as R1_1 or R3_1 how may i know they are in phase with the source one. The set up I have Is the bidirectional coupler (in) in the (PORT1) and the OUT (PORT2). The couple and term terminiations are in R3_1 and c_1 that previously are calibrated with the method I use before. My question is, how may I know the R3_1 and C_1 are in phase with source1 in port1. Thanks for the time Best regard. Sorry for my English. It is not my first language Edited by: Vai11 on Sep 10, 2015 1:37 PM 附件 |
1个回答
我对你的测试有点不清楚:你在测试耦合器吗?
或者您是否正在使用耦合器来测试其他内容? 如果进行4端口引导功率校准,所有源和所有测试端口接收器(相对于测试端口,而不是接收器输入)将以磁场和相位进行校准。 如果您有更详细的问题,请绘制您想要的设置和测量图表,以便我们更清楚。 以上来自于谷歌翻译 以下为原文 I'm a little unclear on your test: Are you testing the coupler? Or are you using the couplers to test something else in between? If you do a 4 port guided-power calibration, all the sources and all the test port receivers (relative to the test port, not to the receiver input) will be calibrated in mag and phase. If you have a more detailed question, please sketch a diagram of your desired setup and measurement to be more clear to us. |
只有小组成员才能发言,加入小组>>
1296 浏览 0 评论
2377 浏览 1 评论
2199 浏览 1 评论
2068 浏览 5 评论
2955 浏览 3 评论
1131浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
759浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
939浏览 0评论
1296浏览 0评论
GMT+8, 2024-12-27 05:04 , Processed in 1.431378 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
