我试图找到低/高功率模式的SSOC(二次振荡器)时,使用外部的32 kHz晶体,似乎是没有详细的家庭数据表(PIC24F16KA101),也没有RTCC/OSC参考数据表。
以上来自于百度翻译 以下为原文 I am trying to find details of the Low/High power modes for the SOSC (secondary oscillator) when using an external 32KHz crystal, seems to be no details in the Family data sheet (PIC24F16KA101) nor the RTCC / OSC reference datasheets. |
1个回答
嗨,关于晶体和连接元件的一些应用注意事项,理论和实际实验都有特定的晶体产品和元件价值。但是它们都结束了,你们必须在最低和高度上自己做测试和/或测量。在产品预期工作的温度下,WW1.MICCHIP.CON/LIPSHON/En/AppNoSe/90001798A.PDF-现代音叉“手表”晶体在晶体和小值电容器之间循环非常小的功率水平工作。封装引脚、键合线和PCB迹线的电容,按具有电容器,并可能足以晶体振荡。PIC振荡器放大器的早期版本,与一个串联电阻在大约220千欧的范围内与驱动引脚串联。在PIC中的振荡器放大器有自动增益控制。试图保持晶体OS。在现代PIC24器件中采用极低的功耗,MICROCSCLE似乎设计了一种不用串联电阻的放大器。在晶体振荡器驱动引脚上的电压电平将小于1伏峰到峰值,即使在高功率模式下,也很难测量,因为C任何示波器探头的电容都会改变电路中的条件。我用1/100探针来观察晶体是如何工作的,但这是电路的高功率配置。在一些产品中,在PIC32 MZ器件中,似乎已经过低功耗设计。次级晶体振荡器根本不工作。迈西尔
以上来自于百度翻译 以下为原文 Hi, There have been several Application Notes on the subject of Crystals and connected components, both theoretical, and practical experiments with specific crystal products and component values. but they all end up saying that you have to do tests and/or measurements yourself, at the lowest and highest temperature where product is expected to work. ww1.microchip.com/downloads/en/AppNotes/00001798a.pdf Modern tuning fork "watch" crystals work with very small power levels circulating between the crystal and small value capacitors. Capacitance of package pins, bonding wires and PCB traces, act in perallell with capacitors, and may be sufficient for crystal to oscillate. Earlier versions of PIC oscillator amplifiers, work with a series resistor in the range around 220 kOhm in series with the drive pin. There is Automatic Gain Control in the oscillator amplifier in the PIC. Trying to keep Crystal oscillating with extreme low power consumption in the PIC, in modern PIC24 devices, Miccrochip seem to design amplifier to be used without a series resistor. Voltage level on crystal oscillator drive pin, will be less than 1 volt peak to peak, even in high power mode, it is difficult to measure, since capacitance of any oscilloscope probe will change conditions in the circuit. I have used a 1/100 probe to get a impression of how the crystal is working, but that is with circuits in High-power configuration. In some products, it may seem the Low-power design have been taken too far, in PIC32MZ devices, the Secondary Crystal Oscillator do not work at all. Mysil |
只有小组成员才能发言,加入小组>>
5170 浏览 9 评论
2001 浏览 8 评论
1931 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3176 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2228 浏览 5 评论
737浏览 1评论
622浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
509浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
635浏览 0评论
531浏览 0评论
GMT+8, 2024-11-25 19:08 , Processed in 1.161455 second(s), Total 79, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
