电子发烧友论坛|
你好,
我目前正在使用开环模式来调试我的硬件,当前读数等。 我通过反复试验找到了V / f曲线的偏移和斜率的最佳值,这样电机就可以在整个速度范围内工作。 但是,当我通过MCI_ExecSpeedRamp(MCI,Vel,time)设置负速度时,电机的行为与正方向的行为不同。 如果我用默认值替换偏移和斜率值,则电机在两个方向上的行为相似。 我是否错过了使用V / f曲线使Open循环工作的一些步骤? 关于另一个话题: 如何获取FOC SDK的机密分发? 我打电话给ST的销售,这导致我去当地的经销商。 我联系过我国的几家经销商。一对夫妇没有帮助,其他人不知道我在寻找什么。其他几个人说他们会将我的请求重定向到ST。 到目前为止,我找不到任何可以帮助我的人。 我如何联系ST以帮助我获取SDK? 最好的祝福 #开环 以上来自于谷歌翻译 以下为原文 Hello, I'm currently using Open loop mode for debugging my hardware, current readings and such. I have found by trial and error the best values for the offset and slope of the V/f curve, such that the motors work on the full range of speeds. However, when I set negative velocities through MCI_ExecSpeedRamp(MCI, Vel, time), the motors do not behave the same as in the positive direction. If I replace my offset and slope values by the default ones, the motors behave similarly in both directions. Am I missing some step to make Open loop work with my V/f curve? On another topic: How can I obtain the confidential distribution of FOC SDK? I've phoned ST's sales, which directed me to my local distributors. I've contacted several distributors on my country. A couple were unhelpful, others had no idea what I was looking for. A couple others said they would redirect my request to ST. So far I was not able to find anyone who could help me. How can I contact in ST to help me obtain the SDK? Best regards #openloop |
1个回答
再见
开环代码不是官方功能(它是一种实验性功能,您只能手动启用,如您所做的那样)。使用负速度时可能存在一些错误。 关于代码分发......就是这样。你必须向分销商的方向发出要求与他们的ST联系人核实的方向。 再见 梁咏琪 以上来自于谷歌翻译 以下为原文 Ciao The open loop code is not an official feature (it is an experimentally feature that you can enable only manually, as you probably did). It is possible that there is some bugs when you work with negative speeds. Regarding the code distribution... that is the way. You have to push in the direction of the distributors asking to verify with their ST contacts. Ciao Gigi |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 02:34 , Processed in 0.911056 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1400
