所以我可以看到有添加自定义IE的SoftAP模式支持。
有没有支持接收传入的信标帧解析自定义IE的? 以上来自于百度翻译 以下为原文 So I can see that there is support for adding custom IE's to SoftAP mode. Is there any support for receiving and parsing custom IE's in incoming beacon frames? |
2个回答
你好:
我们必须分析数据包,数据包过滤器收到,请检查您是否可以从下面的信息得到你的答案。 这个应用程序演示了无线局域网的数据包过滤器结合使用监控模式。*数据包筛选器允许应用程序指定究竟是哪种*包要通过设置模板,所有传入的数据包会被匹配对。*每个过滤器已决定匹配数据包传递到应用程序处理器或掉了一个选项,定义包容或排斥的过滤器。*过滤器也可用于无监督模式(即没有收到的数据包)只有*的数量相匹配的一个给定的过滤器是必要的,没有实际的数据。**注意:如果没有安装有过滤和监控模式,所有传入的数据包会*送回调。但使用过滤器来减少数据包捕获数量*建议为了减少系统资源的使用,**一些数据包进行分析来显示使用但并不意味着要明确详尽也*。*两IEEE802.11层2包(802.11)和3层数据包(IP,ARP,等)过滤*这里展示。**特征演示了*定义过滤器。*添加、启用/禁用,上市&;清除过滤器*设置回调监控模式。*从过滤器中接收数据包。*演示各种802.11和IP过滤器。*检查过滤器的统计数据。*解析层2个802.11个分组。*解析第3层IP数据包。 以上来自于百度翻译 以下为原文 Hello: we have a packet filter to parse the packet received, please have a check if you can get your answer from below info. * This application demonstrates usage of WLAN packet filters combined with monitor mode. * * Packet filters allow an application to specify exactly which kind of * packets it wants by setting templates that all incoming packets will * be matched against. * * Each filter has an option that determines whether matching packets are passed * up to the app processor or dropped, defining inclusive or exclusive filters. * * Filters can also be used without monitor mode (ie without recieving the packets) when only * the number of matches to a given filter is needed, without the actual data. * * Note that if no filters are installed and monitor mode is on, all incoming packets wll be * sent to the callback. But using filters to cut down the number of packets captured is * recomended in order to cut down on system resource usage, * * Some packet parsing is done here to show usage but is not meant to be definitive nor * exhaustive. * * Both IEEE802.11 layer 2 packets (802.11) and layer 3 packets (IP, ARP, etc) filtering * is demonstrated here. * * Features demonstrated * - Defining filters. * - Adding, Enabling/Disabling, Listing & removing filters * - Setting up monitor mode with callbacks. * - Recieving packets from the filters. * - Demonstrates various 802.11 and IP filters. * - Examining stats from filters. * - Parsing layer 2 802.11 packets. * - Parsing layer 3 IP packets. |
你正在分享的信息,我在几天前找。谢谢您
VEX 3 以上来自于百度翻译 以下为原文 The information you are sharing I'm looking for a few days ago. thank you vex 3 |
只有小组成员才能发言,加入小组>>
743个成员聚集在这个小组
加入小组2016 浏览 1 评论
1775 浏览 1 评论
3569 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1711 浏览 6 评论
1477 浏览 1 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
395浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
280浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
368浏览 2评论
310浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
512浏览 2评论
GMT+8, 2024-10-5 20:59 , Processed in 0.625993 second(s), Total 47, Slave 41 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
