电子发烧友论坛|
全部,我正在使用的.csa文件没有我需要的所有痕迹。
我想通过SCPI添加一些新的用于自动测试目的。 例如,csa文件每个通道只有一个跟踪:CH1_S11_1,S21 CH2_S21_2,S21 CH3_S12_3,S21。 。 。 CH18_S12_18,S21每个通道都有一个完整的2端口校准,用于多路复用器路径和相关的calpod。 加载.csa文件后,我遍历每个通道并启用/重新启动活动的calpods。 此时所有的calpods都被重新检测。 现在,假设我正在使用通道1.如果我添加以下迹线,我将不得不再次重新校正calpods,以便新的迹线能够提供准确的结果吗? “CALCulate1:PARameter:DEFine 'PNA_S11 ',S11”“CALCulate1:PARameter:DEFine 'PNA_S22 ',S22”“display:window1:trace19:feed 'PNA_S11 '”“display:window1:trace20:feed ''PNA_S22 '“谢谢, - 比尔 以上来自于谷歌翻译 以下为原文 All, The .csa file I'm working with doesn't have all the traces I need. I'd like to add some new ones via SCPI for automatic test purposes. For example, the ,csa file has only one trace per channel: CH1_S11_1, S21 CH2_S21_2, S21 CH3_S12_3, S21 . . . CH18_S12_18, S21 Each of those channels has a full 2-port cal for the multiplexer path and associated calpods. After I load the .csa file I loop through each channel and enable/recorrect the active calpods. At this point all the calpods are recorrected. Now, say I'm working with channel 1. If I add the following traces will I have to recorrect the calpods again in order for the new traces to provide accurate results? "CALCulate1:PARameter:DEFine 'PNA_S11',S11" "CALCulate1:PARameter:DEFine 'PNA_S22',S22" "display:window1:trace19:feed 'PNA_S11'" "display:window1:trace20:feed 'PNA_S22'" Thanks, -Bill |
4个回答
在您描述的情况下,您添加的那些跟踪应该自动具有与该通道上的S21跟踪相同的2端口校准,因此不需要在该点再次重新校准。
以上来自于谷歌翻译 以下为原文 In the situation you describe, those traces you are adding should automatically have the same 2-port cal applied as your S21 trace on that channel, so should be no need to recorrect again right at that point. |
谢谢。 这就是我所希望的。 -BillEdited:WDrago于2015年6月7日上午11:01 以上来自于谷歌翻译 以下为原文 Thank you. That's what I was hoping for. -Bill Edited by: WDrago on Jun 7, 2015 11:01 AM |
我可以在不丢失calpod重新校正的情况下将痕迹添加到新窗口吗? 例如://在通道1上创建测量值(这些应该保留现有的2端口校准信息)“CALCulate1:PARameter:DEFine 'PNA_S11 ',S11”“CALCulate1:PARameter:DEFine 'PNA_S22 ',S22”/ /创建一个新窗口显示:window2:state on //向窗口2添加跟踪“display:window2:trace1:feed 'PNA_S11 '”“display:window2:trace2:feed 'PNA_S22 '”当使用calpods时 我可以采取哪些编程预防措施,以避免在执行初始重新校正后必须重新校准? (例如,不要使用XYZ命令,因为这会吹掉记录。)谢谢,-BillEdited:WDrago于2015年6月7日上午11:02 以上来自于谷歌翻译 以下为原文 Can I add traces to a new window without losing calpod recorrection? For example: // Create measurements on channel 1 (these should retain existing 2-port cal info) "CALCulate1:PARameter:DEFine 'PNA_S11',S11" "CALCulate1:PARameter:DEFine 'PNA_S22',S22" // Create a new window display:window2:state on // Add traces to window 2 "display:window2:trace1:feed 'PNA_S11'" "display:window2:trace2:feed 'PNA_S22'" When working with calpods what programming precautions can I take to avoid having to recorrect once the initial recorrection has been performed? (e.g. don't use XYZ command because that will blow away the recorrect.) Thanks, -Bill Edited by: WDrago on Jun 7, 2015 11:02 AM |
derek88 发表于 2018-9-20 21:07 窗口编号选择对测量的校准状态没有任何影响。 您可以在频道中创建跟踪并将其提供给您想要的任何窗口编号(最大窗口编号)。 您甚至可以将现有迹线从一个窗口移动到另一个窗口。 以上来自于谷歌翻译 以下为原文 the window number selection does not have any impact on the calibration state of a measurement. you can create a trace in your channel and feed it to any window number that you want (up to the maximum window number). you can even move existing traces from one window to another. |
只有小组成员才能发言,加入小组>>
1854 浏览 0 评论
2749 浏览 1 评论
2651 浏览 1 评论
2471 浏览 5 评论
3475 浏览 3 评论
1855浏览 0评论
427浏览 0评论
/9
GMT+8, 2025-12-9 07:15 , Processed in 0.627625 second(s), Total 47, Slave 40 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
520
