电子发烧友论坛|
你好,
虽然“任务”列表显示上传二进制,我不明白的地方放一个。 所以我上传到这里。如果这不是一个合适的地方,请让我知道它放在哪里。 这是第一次演示样本二矿井,采用cy8ckit-044简单迷宫项目 AdfRuIT 2.8“TFT触摸屏”。 HTTPS://www. ADAFRUIT.COM/PROTECT/1651 它利用kxtj2加速度计在cy8ckit-044通过I2C和 2.8“TFT通过SPI。 起点是左上角,目标是右下角。 你可以通过编辑“迷宫.h”来修改迷宫。 摩托罗拉 MaZe180611Cyrj.CaseV01.Zip 2.4兆字节 以上来自于百度翻译 以下为原文 Hi, Although the "Mission" list suggests to upload binary, I could not figure out where to put one. So I upload it here. If this is not an appropriate place, please let me know where to put it. This is the first demo sample binary of mine, a simple maze project using CY8CKIT-044 and Adafruit 2.8" TFT Touch Shield. https://www.adafruit.com/product/1651 It utilizes the KXTJ2 accelerometer on CY8CKIT-044 via I2C and the 2.8" TFT via SPI. The start point is upper-left and the goal is lower-right. You can modify the maze by editing "maze.h." moto |
3个回答
精彩的!!!!!
这也是SPI TFT和I2C加速度计的一个很好的例子!!!!! 以上来自于百度翻译 以下为原文 Wonderful!!!! It's also a good example for SPI TFT and I2C accelerometer!!!! |
Motoo
谢谢你分享一个项目。 PSoC Creator提供了标准的方法来压缩和分享点击几下项目:(1)清洁项目:建立>;干净的。(二)创建共享文件:在资源管理器中单击项目名称(上)。现在在主菜单:文件- >;创建归档束>;最小。这将创建存档项目(*.zip)。(3)可以进一步缩小这个存档文件大小明显:文件夹生成源打开ZIP文件并删除。生成的存档将是lt;100K的大小。现在很容易共享/上传。 ODISSEY1 以上来自于百度翻译 以下为原文 Motoo, Thank you for sharing a project. PSoC Creator offers standard way to compress and share projects in few clicks: (1) Clean the project: Build->Clean. (2) Create shareable archive: In the Project Explorer click the Project Name (on top). Now in Main Menu: File->Create Archive Bundle->Minimal. This will create archived project (*.zip). (3) You can further shrink this archived file size dramatically: open ZIP file and delete folder Generated Source. The resulting archive will be <100k in size. It is easy to share/upload now. /odissey1 |
nvwuwy 发表于 2018-9-19 12:35 亲爱的/ ODISSEY1(?)- san, 非常感谢你的建议! 我试过了,存档现在是178KB。 最好的问候, 12-Jun-2018 莫太田纳卡 MZE180611CYDSN.ZIP 178.4 K 以上来自于百度翻译 以下为原文 Dear /oddissey1(?)-san, Thank you very much for your suggestion! I tried, and the archive is now 178KB. Best Regards, 12-Jun-2018 Motoo Tanaka
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2477 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2074 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7567浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 10:32 , Processed in 0.797358 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3406
