使用Horizon 7和GRID许可证5.0.0
如果我退出VDI,我希望它能够发布许可证,但事实并非如此。 从不再使用的VDI中释放许可证的最佳方法是什么? 谢谢, -Ryan 以上来自于谷歌翻译 以下为原文 Using Horizon 7, and GRID license 5.0.0 If I log out of a VDI, I would expect it to release a license but it does not. What is the best way to release a license from a VDI that is no longer in use? Thanks, -Ryan |
4个回答
嗨RBae,
这不是预期的行为。 你等了多长时间才发布许可证? 通常,VM关闭后需要10-15分钟才能释放许可证。 请用ESP创建支持票。 最好的祝福 西蒙 以上来自于谷歌翻译 以下为原文 Hi RBae, this is not expected behavior. How long did you wait for the license to be released? In general it takes 10-15minutes to release the license after VM shutdown. Please create a support ticket with ESP. Best regards Simon |
谢谢西蒙 - 会这样做。
现在已超过24小时,许可证尚未发布。 这只是我的一个许可证的问题。 如果我关闭其他VM,它会释放许可证。 在这种情况下我唯一做的就是我将带有许可证的VM转换为模板。 这就像模板有许可证,不会发布它。 -Ryan 以上来自于谷歌翻译 以下为原文 Thanks Simon - will do. It's been well over 24 hours now with the license not being released. This is a problem with just one of my licenses. If I shut other VM's down, it does release the license. The only thing that I did differently in this case was that I converted a VM with a license to a template. It's like the template has the license and won't release it. -Ryan |
嗨RBae,
作为解决方法,您可以将VM租约时间(RegKey LicenseInterval)从7天默认值减少到例如1天,以确保在24小时后释放许可证。 问候 西蒙 以上来自于谷歌翻译 以下为原文 Hi RBae, as workaround you could reduce the VM lease time (RegKey LicenseInterval) from the 7 days default value to for example 1 day to make sure the license is released after 24 hours. Regards Simon |
西蒙非常感谢你的回答,我非常感激,因为我有同样的问题,但我想知道如果你不介意我是否可以问你一些其他的问题?
请? 再次感谢你! 以上来自于谷歌翻译 以下为原文 Simon thanks a lot for your answers, i really appreciate it a lot as i was having quite same questions, however i was wondering if i may ask you some other questions, if you don't mind? please? thank you again! |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
2994 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3409 浏览 4 评论
GMT+8, 2024-9-29 06:09 , Processed in 0.704536 second(s), Total 82, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
