嗨,我正在运行EMPro 2015.01,我在几个不同的模拟中遇到了同样的问题。
它们都是FEM模拟,我得到以下错误:网格边界重叠,重叠三角形对可以在design_mesh_overlaps.sat中找到。 我已经尝试从网格中排除各种模型,直到模拟运行,然后手动重新创建导致错误的几何,但没有运气。 我已经尝试查看design_mesh_overlaps.sat文件,但其中的信息对我没有意义。 我在PCB(集总端口,50欧姆电压源)上附加了一个模拟的图像,这是一个直角SMA连接器(波导端口,1W模态源)。 知道是什么导致了这个以及如何解决它? 谢谢,克里斯 以上来自于谷歌翻译 以下为原文 Hi, I'm running EMPro 2015.01 and I've been running into this same problem on a few different simulations. They're all FEM simulations where I get the following error while: Mesh boundary is overlapping, the pairs of overlapping triangles can be found in design_mesh_overlaps.sat. I've tried excluding various models from the mesh until the simulation will run, and then manually re-creating the geometries that are causing the error, but no luck. I've tried looking at the design_mesh_overlaps.sat file, but the information in it is not meaningful to me. I've attached an image of one of the simulations which is a right-angle SMA connector (waveguide port, 1W modal source) on a PCB (lumped port, 50ohm voltage source). Any idea what is causing this and how to fix it? Thanks, Chris 附件
2个回答
克里斯,这是一个导入的对象吗?
大多数情况下,当从CAD文件导入对象时,用于创建文件的机械工具不会产生足够“干净”的电模拟模型。 使用您的模型作为指导,您可能会更好地在EMPro中重绘它。 尝试在结果选项卡下的高级可视化窗口中查看失败的几何体。 从那里,转到工具,然后是对象统计。 有时您会在那里找到有价值的信息。 此外,我相信您应该为波导端口使用相同的电压源。 1W模态源对于模拟实际波导非常有用,但当存在与端口相关的特定阻抗时则较少。 应该在下一个版本中澄清何时使用以及何时不使用模态端口,但我认为这种情况下,电压端口会更合适。 此致,巴雷特 以上来自于谷歌翻译 以下为原文 Chris, Is this an imported object? Most of the time, when an object is imported from a CAD file, the mechanical tool used to create the file doesn't produce a "clean" enough model for electrical simulation. You may have better luck redrawing it in EMPro using your model as a guideline. Try looking at the failed geometry in the advanced visualization window, under the results tab. From there, go to tools, then object statistics. Sometimes you will find valuable information in there. In addition, I believe you should be using the same voltage source for your waveguide port. The 1W modal source is useful for modeling actual waveguide, but less so when there is a specific impedance associated with the port. There should be clarification of when to use and when to not use modal ports in the next release, but I think this case, a voltage port would be more appropriate. Regards, Barrett |
wangcong12138 发表于 2018-9-18 07:36 谢谢巴雷特,我会把它切换到电压源。 它不是一个导入的模型,我手工构建它。 我已经尝试重建它的部分(特别是它的地面外壳)。 我将查看高级可视化窗口,查找重叠的三角形...... Chris 以上来自于谷歌翻译 以下为原文 Thanks Barrett, I'll switch it over to a Voltage source. It's not an imported model, I build that one by hand. And I've tried re-building pieces of it (especially the ground housing of it). I'll take a look through the Advanced Visualization window, look for overlapping triangles... Chris |
只有小组成员才能发言,加入小组>>
1849 浏览 0 评论
2743 浏览 1 评论
2643 浏览 1 评论
2454 浏览 5 评论
3464 浏览 3 评论
1850浏览 0评论
424浏览 0评论
/9
GMT+8, 2025-12-4 11:12 , Processed in 0.719028 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3127
