大家好,我是任意波形的新手,所以请原谅我,如果我问的话可能很明显。
我有一个33220A,想要使用自定义波形。 它是一个混合信号,总长度为250秒(用于测试设备)。 我在Keysight BenchLink Waveform Builder Pro中创建了该信号,然后将其发送到33220A。 现在我遇到了3个问题:1。在“发送波形”屏幕中,频率设置为4 mHz(250秒)。 我假设那是该信号的默认频率。 但事实并非如此。 每当我加载“Arb”信号时,我必须重置Frecuency和Amplitude。 我可以为信号指定默认频率或幅度。 或者是存储/召回状态的唯一方法吗? (因为它的可能性)2。如果我选择我的任意波形并经过102秒,当我关闭并再次打开“Arb”波形或输出时,波形不会从头开始,它会在102秒处继续。 有没有办法重新启动“Arb”波形? 或者我必须使用存储/调用状态吗? 3.我想将我的波形仅1次传递到我的设备,因为只有在信号为0Vdc时我才能断开设备。我可以在波形后添加一个很长的0Vdc信号,但是我需要一些方法来重启( 问题2)我的波形,当我想测试我的下一个设备。 我可以只运行一次任意波形吗? 我想我可以用存储/召回状态做任何事情,但我想知道是否有更好的解决方案。 最好的问候多利安 以上来自于谷歌翻译 以下为原文 Hello Guys, i'm new to the arbitrary waveforms, so so please excuse me if im asking something thats maybe obvious. I have a 33220A and want to use the a custom waveform. Its a mixed signal, and the total length is 250 seconds (to test a device). I created that signal in Keysight BenchLink Waveform Builder Pro and sendet it to the 33220A. Now i got 3 problems: 1. In the "Send Waveform" Screen the Frequency is set to 4 mHz (250sec). I assumed that would the the default frequency for that signal. But its not so. Everytime i load the "Arb" signal, i have to reset the Frecuency and Amplitude. Can i assign a default frecuency or amplitude to a signal. Or is the only way to do it with store/recall state? (because then its posible) 2. If i select my arbitrary waveform and 102 seconds passed, when i turn off and on again the "Arb" waveform or the output, the waveform doesnt start from beginning, it continuos at the 102 seconds. Is there a way to restart the "Arb" Waveform? Or do i have to do it with store/recall state? 3. I would like to pass my waveform just 1 Time to my device, because i can disconnect my device only when the signal is 0Vdc.I could add a very long 0Vdc signal after my waveform, but then i need some way to restart (question 2) my waveform, when i want to test my next device. Can i run the arbitrary waveform just 1 Time? I think i can do everything with store/recall state, but i would like to know if there is a better solution to this. Best regards Dorian |
2个回答
嗨,1-有效地,频率和幅度不会存储在波形存储器中,您必须设置频率和幅度。
我认为唯一的方法是通过STORE / RECALL按钮将设置保存在4个寄存器中的一个中,或者在LAST状态下将pwr设置为ON而不是DEFAUT,在接通电源时,您的设置就绪。 2-我认为启动后不能停止波形(* TRIG命令)。 3-如果需要,可以只运行一次波形,使用BURST并设置为1个周期,然后使用TRIG按钮启动。 如果波形以0Vdc(第一点)开始,则可以调用设置:波形将立即停止并返回波形的第一个点并等待触发信号。 关心Yves QC,加拿大 以上来自于谷歌翻译 以下为原文 Hi, 1- Effectively, frequency and amplitude aren't stored in memory with waveform, you must set frequency and amplitude. I think that the only ways is save your setup in one of 4 registers by STORE/RECALL button or set pwr ON on LAST state instead of DEFAUT, at power ON, your setup is ready. 2- I think it's not possible to stop a waveform after the startup (*TRIG command). 3- You can run your waveform just one time if you want, use BURST and set to 1 cycle, and use TRIG button to start. If your waveform start with 0Vdc (first point), you can recall your setup: waveform will stop immediately and will return to first point of waveform and wait for trigger signal. Regards Yves QC, Canada |
Tussi 发表于 2018-9-14 06:09 你好Tardz对不起我还没回答。 在此期间有不同的项目。 非常感谢您的明确和非常好的答案。 特别针对Point 3,这对我来说就像我预期的那样。 最好的祝福来自瑞士多利安编辑:多利安于2015年7月2日上午12:35编辑:多利安于2015年7月2日12:36 AM 以上来自于谷歌翻译 以下为原文 Hello Tardz sorry i didnt answer yet. Had different proyects in the meantime. Thank you very much for your clear and very good answer. Specially for the Point 3, that will work for me as i expected it. best wishes from switzerland Dorian Edited by: dorian on Jul 2, 2015 12:35 AM Edited by: dorian on Jul 2, 2015 12:36 AM |
只有小组成员才能发言,加入小组>>
1078 浏览 0 评论
2308 浏览 1 评论
2096 浏览 1 评论
1969 浏览 5 评论
2841 浏览 3 评论
845浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
618浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
719浏览 0评论
1404浏览 0评论
1078浏览 0评论
GMT+8, 2024-10-3 05:21 , Processed in 1.074672 second(s), Total 49, Slave 43 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
