电子发烧友论坛扫一扫,分享给好友
您好,从今天开始,我在使用labview加载任意波形时出错。安捷伦33XXX系列发生错误-1074000000.lvlib:错误查询。可能的原因:仪器报告:+785,“指定的arb波形没有
存在“+ 0”,无错误“完整的调用链:Agilent 33XXX Series.lvlib:错误Query.vi Agilent 33XXX Series.lvlib:配置任意Waveform.vi BC_Test_2a_External_Trigger_Visa_Level_CSV_input.vMy Labview程序在工作情况方面没有改变 一个星期前。我也尝试过33220A,同样的错误,它拒绝将任意波形保存到本地内存中。 以上来自于谷歌翻译 以下为原文 Hello, Since today I've got an error while loading a arbitrary waveform with Labview.
My Labview program is not changed with respect to the situation when it worked, a week ago. I also have tried it with a 33220A, same error, it refuses to save the arbitrary waveform into local memory. |
6个回答
是否可以附上你的labview vi所以我可以看一下或者截图,这样我可以尝试重新创建它?
以上来自于谷歌翻译 以下为原文 Is it possible to attach your labview vi so I can have a look or maybe screenshots so I can try and recreate it? |
您好,唯一被改变的是我从1 33250A变为另一个。
这个“新的”清除了内存,因此没有用户波形存储在本机中。 当我创建一个新的并将其放入易失性存储器并将我的波形命名为“VOLATILE”时,它可以工作,但是当我关闭设备时不会保存。我可以通过清理另一个33250A来重现它,现在我无法存储 这个设备中的用户波形。如果你还需要vi,我可以发布它.Regards,BoudewijnCharité 以上来自于谷歌翻译 以下为原文 Hello, The only thing that was changed was that I changed from 1 33250A to an other one. This "new" one has cleared memory, so no user waveforms were stored in this machine. When I create a new one and put it into volatile memory and give my waveform the name "VOLATILE" it worked, but is not saved when I turn off the equipment. I could reproduce it by cleaning another 33250A and now I can't store user waveforms either in this piece of equipment . If you still need the vi, I can post it. Regards, Boudewijn Charité |
是的,看到vi会很有帮助,我想我知道很热,所以你可以保存你的波形。
以上来自于谷歌翻译 以下为原文 Yes it would be helpful to see the vi, I think I know hot to alter it so you can save your waveforms. |
您好,查找附加vi,如果您需要更多请告诉我.Regards,
以上来自于谷歌翻译 以下为原文 Hello, Find attached the vi, if you need more please let me know. Regards, 附件 |
我终于有了一份labview 2010的副本,所以我能够打开它并看一看。
您是否尝试过使用33522A的驱动程序而不是33220A驱动程序? 33522A有一个不同的驱动程序,但如果你使用的是33220A驱动程序,大多数东西都可以使用。 以上来自于谷歌翻译 以下为原文 I finally have a copy of labview 2010 so I was able to open this and take a look. Have you tried using the driver for the 33522A instead of the the 33220A driver? There is a different driver for the 33522A although most things will work if you are using the 33220A driver. |
我不知道有一个特殊的驱动程序,因为Labview驱动程序资源管理器告诉我从他们的网站使用33xxx驱动程序。
我会尝试找到这个新的驱动程序并尝试一下。 以上来自于谷歌翻译 以下为原文 I was not aware that there was a special driver because the Labview driver explorer told me to use the 33xxx driver from their website. I will try to find this new driver and give it a try. |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-2 00:44 , Processed in 0.801198 second(s), Total 82, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1957
