28035芯片,总共要用到8个PWM端口输出,当PWM频率设置为20KHz时,TBPRD设置为1500,那么实际可调占空比的数值范围为0-1500,如何在频率不变的情况下,提高占空比数值范围?
下面是PWM设定程序 void InitEPWM_AQ_DB(void) [ char i; volatile struct EPWM_REGS *PWMDef[] = [&EPwm1Regs,&EPwm2Regs,&EPwm3Regs,&EPwm4Regs]; InitEPwm1Gpio(); //PWM1AB 引脚配置 InitEPwm2Gpio(); //PWM2AB 引脚配置 InitEPwm3Gpio(); //PWM3AB 引脚配置 InitEPwm4Gpio(); //PWM4AB 引脚配置 for(i=0;i<4;i++) [ EALLOW; //T_PWM =2 x TBPRD x T_TBCLK PWMDef->TBPRD = 1500; //频率20KHz //EPwm1Regs.TBCTL.bit.PRDLD = TB_SHADOW; PWMDef->CMPA.half.CMPA = 0; //占空比 PWMDef->CMPB = 0; //PWMxB占空比 PWMDef->TBPHS.half.TBPHS = 0x0000; // Phase is 0 PWMDef->TBCTR = 0x0000; // Clear counter // Setup TBCLK PWMDef->TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count up down,中间对其计数模式 PWMDef->TBCTL.bit.PHSEN = TB_DISABLE; // Disable phase loading PWMDef->TBCTL.bit.SYNCOSEL = TB_SYNC_DISABLE; PWMDef->TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT; PWMDef->TBCTL.bit.CLKDIV = TB_DIV1; PWMDef->AQCTLA.bit.CAU = AQ_SET; PWMDef->AQCTLA.bit.CAD = AQ_CLEAR; PWMDef->AQCTLB.bit.CBU = AQ_SET ; PWMDef->AQCTLB.bit.CBD = AQ_CLEAR; PWMDef->DBCTL.bit.OUT_MODE = DB_DISABLE; //S1 = 0; S0 = 0 关闭死区控制 EDIS; ] ] |
5 个讨论
28035芯片,总共要用到8个PWM端口输出,当PWM��率设置为20KHz时,TBPRD设置为1500,那么实际可调占空比的数值范围为0-1500,如何在频率不变的情况下,提高占空比数值范围?
Eric: 使用高精度PWM。 C:ticontrolSUITEdevice_supportf2803xv130DSP2803x_examples_ccsv5hrpwm C:ticontrolSUITEdevice_supportf2803xv130DSP2803x_examples_ccsv5hrpwm_duty_sfo_v6 - ERIC |
按照例程的做法,分辨率只能比原来提高1倍,不知道有没有更好的方法实现更高的分辨率 // Some useful Period vs Frequency values // SYSCLKOUT = 60 MHz // --------------------------- // Period Frequency // 1000 60 kHz // 800 75 kHz // 600 100 kHz // 500 120 kHz // 250 240 kHz // 200 300 kHz // 100 600 kHz // 50 1.2 Mhz // 25 2.4 Mhz // 20 3.0 Mhz // 12 5.0 MHz // 10 6.0 MHz // 9 6.7 MHz // 8 7.5 MHz // 7 8.6 MHz // 6 10.0 MHz // 5 12.0 MHz void HRPWM1_Config(Uint16 period) [ // ePWM1 register configuration with HRPWM // ePWM1A toggle low/high with MEP control on Rising edge EPwm1Regs.TBCTL.bit.PRDLD = TB_IMMEDIATE; // set Immediate load EPwm1Regs.TBPRD = period-1; // PWM frequency = 1 / period EPwm1Regs.CMPA.half.CMPA = period / 2; // set duty 50% initially EPwm1Regs.CMPA.half.CMPAHR = (1 << 8); // initialize HRPWM extension EPwm1Regs.CMPB = period / 2; // set duty 50% initially EPwm1Regs.TBPHS.all = 0; EPwm1Regs.TBCTR = 0; EPwm1Regs.TBCTL.bit.CTRMODE = TB_COUNT_UP; EPwm1Regs.TBCTL.bit.PHSEN = TB_DISABLE; // EPwm1 is the Master EPwm1Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_DISABLE; EPwm1Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; EPwm1Regs.TBCTL.bit.CLKDIV = TB_DIV1; EPwm1Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO; EPwm1Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO; EPwm1Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW; EPwm1Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW; EPwm1Regs.AQCTLA.bit.ZRO = AQ_CLEAR; // PWM toggle low/high EPwm1Regs.AQCTLA.bit.CAU = AQ_SET; EPwm1Regs.AQCTLB.bit.ZRO = AQ_CLEAR; EPwm1Regs.AQCTLB.bit.CBU = AQ_SET; EALLOW; EPwm1Regs.HRCNFG.all = 0x0; EPwm1Regs.HRCNFG.bit.EDGMODE = HR_REP; //MEP control on Rising edge EPwm1Regs.HRCNFG.bit.CTLMODE = HR_CMP; EPwm1Regs.HRCNFG.bit.HRLOAD = HR_CTR_ZERO; EDIS; ] |
只有小组成员才能发言,加入小组>>
MSP430F249TPMR出现高温存储后失效了的情况,怎么解决?
404 浏览 0 评论
对于多级放大电路板,在PCB布局中,电源摆放的位置应该注意什么?
930 浏览 1 评论
537 浏览 0 评论
普中科技F28335开发板每次上电复位后数码管都会显示,如何熄灭它?
413 浏览 1 评论
969 浏览 0 评论
63浏览 3评论
CC3100BOOST使用CC3200lunchXL进行烧录
912浏览 2评论
156浏览 2评论
197浏览 2评论
175浏览 2评论
GMT+8, 2024-9-29 07:07 , Processed in 0.975507 second(s), Total 74, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
