电子发烧友论坛|
Dear,all:
ST公司用于振动测量加速度传感器?要求如下: 频率响应超过1万 范围:0-40克 Power:低功耗 如果ST公司没有这些传感器,用于水泵,风机和其他工业现场,您能介绍其他公司的传感器吗? 以上来自于谷歌翻译 以下为原文 Dear,all: ST companies have used for vibration measuring acceleration sensor? Requirements are as follows: Frequency response: more than 1kh Range: 0-40 g Power:Low power consumption Used in water pump, fan and other industrial sites if ST companies have not these sensor,Can you introduce other company sensor? |
3个回答
你可以考虑一下
http://www.st.com/content/st_com/en/products/mems-and-sensors/accelerometers/h3lis331dl.html 范围是100/200 / 400g,但最大输出数据速率仅为1kHz。您确定需要测量高达40g的振动吗?如果16克足够你也可以考虑 http://www.st.com/content/st_com/en/products/mems-and-sensors/accelerometers/iis2dh.html 能够提供输出数据速率高达5376 Hz的数据。 以上来自于谷歌翻译 以下为原文 You can consider http://www.st.com/content/st_com/en/products/mems-and-sensors/accelerometers/h3lis331dl.html the range is 100/200/400g, but the maximum output data rate is only 1kHz.Are you sure you need to measure vibration up to 40g? If 16g would be enough you can also consider http://www.st.com/content/st_com/en/products/mems-and-sensors/accelerometers/iis2dh.html which is capable to provide data with output data rate up to 5376 Hz. |
谢谢你的回复!
IIS2DH的ADC是12位,我认为 http://www.baidu.com/link?url=v2jdow-y-YTs0lx5nEcKCRbQqaxRDiYl2wpTrC5nmp9yz4UsOkpjqqDStHEufS66GNFrqIV-eg6iCUQmqx4otIoZ9r17zsE8WK9qa85nUdG&wd=&eqid=ed2a45eb00007641000000065a2f4e47 http://www.baidu.com/link?url=v2jdow-y-YTs0lx5nEcKCRbQqaxRDiYl2wpTrC5nmp9yz4UsOkpjqqDStHEufS66GNFrqIV-eg6iCUQmqx4otIoZ9r17zsE8WK9qa85nUdG&wd=&eqid=ed2a45eb00007641000000065a2f4e47 以上来自于谷歌翻译 以下为原文 Thanks your response! The IIS2DH' ADC is 12bit,i think the http://www.baidu.com/link?url=v2jdow-y-YTs0lx5nEcKCRbQqaxRDiYl2wpTrC5nmp9yz4UsOkpjqqDStHEufS66GNFrqIV-eg6iCUQmqx4otIoZ9r17zsE8WK9qa85nUdG&wd=&eqid=ed2a45eb00007641000000065a2f4e47 http://www.baidu.com/link?url=v2jdow-y-YTs0lx5nEcKCRbQqaxRDiYl2wpTrC5nmp9yz4UsOkpjqqDStHEufS66GNFrqIV-eg6iCUQmqx4otIoZ9r17zsE8WK9qa85nUdG&wd=&eqid=ed2a45eb00007641000000065a2f4e47 |
您可以查看ST加速度计的概述。
http://www.st.com/content/st_com/en/products/mems-and-sensors/accelerometers.html?querycriteria=productId=SC444 以上来自于谷歌翻译 以下为原文 You can check this overview of ST accelerometers. http://www.st.com/content/st_com/en/products/mems-and-sensors/accelerometers.html?querycriteria=productId=SC444 |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1464 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1517 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3662 浏览 1 评论
3855 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2474 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
741浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
673浏览 5评论
720浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
959浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
760浏览 5评论
/9
GMT+8, 2025-12-8 08:50 , Processed in 0.921456 second(s), Total 77, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2443
