电子发烧友论坛|
大家好!MUDSPIC只接收BYTE0(8字节数据字段)小于0x80。7FXX-XXX-XXXX-XXXX数据字段的包被成功接收。80xXXXX-XXXX-XXXX数据字段未被接收。接收到的IDS和其他所有的东西。JPG显示了CAN总线上的流量。TX包有ID1C1 190 191。应答包有ID 18Fi,使用来自Cicrochip的CE129的例子。关于,卢卡。
以上来自于百度翻译 以下为原文 Hi to all!. I have a problem with receiving standard packets. Mu dspic receives only if byte0 (8 bytes DATA FIELD) is less than 0x80. Package with 7FXX-XXXX-XXXX-XXXX data field is received successfully. Package with 80XX-XXXX-XXXX-XXXX data field is not received. With byte0 from 0x80 to 0xFF the packets are not received. The ids and everything else are ok. the jpg show the traffic on can bus. The tx packets have id 1c1 190 191. The reply packets have id 18f I use the examples from CE129 from microchip. Regards, luca. Attached Image(s) |
1个回答
是否有人试图查看CAN RX中断是否在TBX包上以BYTE0为0B100000接收?DSPI3F
以上来自于百度翻译 以下为原文 Can someone try to see if the can rx interrupt gets on reception with a tx packet with byte0 at 0b10000000? dspi33f |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 04:30 , Processed in 0.749975 second(s), Total 77, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2142
