你好,
我想通过FX3上的GPIF端口来连接双通道ADC。ADC有一个输出时钟,它必须用来对输出数据进行采样。一个通道必须在这个时钟的上升沿和下降沿上的另一个信道采样。实现这一目标的最佳途径是什么?假设这个时钟运行在50MHz 最好的问候 以上来自于百度翻译 以下为原文 Hello, I would like to interface an dual channel ADC through the GPIF port on the FX3. The ADC has an output clock which must be used to sample the output data. One channel must be sampled in the rising edge of this clock and the other channel on the falling edge. What is the best way to implement this? Let's say that this clock is running at 50Mhz Best regards |
2个回答
从描述中,它听起来不像直接连接到FX3是最好的想法,但是如果这是真正想要的,你可以做的是找到一个外部PLL以ADC时钟作为输入,并产生一个2X的时钟。这样,FX3在100MHz相位上与原始时钟对齐。然后在FX3中只对数据进行正常采样,在软件解码CH1和CH2,因为它们将简单地交替,奇数样本将是CH1,甚至样本将是CH2等。
或者另一种方法是在FX3和ADC之间有一个FPGA或类似的东西。 编辑:也检查这个GPIF II DDR模式 安德烈 以上来自于百度翻译 以下为原文 From the description it doesnt sound like a direct connection to FX3 is the best idea, however if that is what is really desired what you could do is find an external PLL to take the ADC clock as input and produce a clock that is 2x of that. So that way the FX3 is running at 100Mhz phase aligned with the original clock. Then at the FX3 just sample the data normally and in software decode CH1 and CH2 because they simply will be alternating Odd samples will be Ch1, Even samples will be CH2 etc. Or the other way is to have an FPGA or something similar between the FX3 and the ADC. Edit: Also check out this post GPIF II DDR Mode -Andriy |
jsjdfsdf 发表于 2018-9-7 10:56 谢谢你的提示,但我更愿意去DDR方法。 PLL方法增加了更多的硬件,如果PLL中存在周跳,则它更容易使信道失去同步。 让我们看看我能在这个GPIF II DDR模式挖掘什么 DDR真的是DDR吗?这是否意味着你可以在100MHz每时钟周期占用2x32位?或者你需要把时钟频率降低到50MHz? 最好的问候, 马里奥 以上来自于百度翻译 以下为原文 Thanks for the tip but I would prefer to go to the DDR approach. The PLL approach adds more hardware and it seams more prone to get the channels out of sync if there is a cycle slip in the PLL. Let's see what I can dig on this GPIF II DDR Mode Is this DDR a true DDR? Does it mean that you can take 2x 32bit per clock cycle at 100MHz? Or do you need to lower the clock frequency to 50MHz? Best regards, Mário |
只有小组成员才能发言,加入小组>>
752个成员聚集在这个小组
加入小组2069 浏览 1 评论
1824 浏览 1 评论
3633 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1760 浏览 6 评论
1509 浏览 1 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
507浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
357浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
410浏览 2评论
357浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
854浏览 2评论
GMT+8, 2024-11-22 00:01 , Processed in 1.335374 second(s), Total 81, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
