“Boyette,Carl”写道:>先生,> IOtech的FAQ页面说:“不,IOtech的产品目前都没有与HP VEE兼容。”
似乎我对可能的兼容性的想法>是错误的。>真诚地,> Carl由于很多原因我通常推荐LAN / HPIB网关over anylug-in卡。 解决这类问题,适用于任何PC等.Stan ------------------------------------ -------------------------------------- Stan Bischof安捷伦科技公司707-577-3994 stan_bischof @ agilent .COM ------------------------------------------------ -------------------------------------------------- ---------------------------------------------这是“vrf “maillist,由Majordomo管理。 要向该maillist发送消息,只需发送电子邮件至“vrf@lvld.agilent.com”。 订阅和取消订阅是通过地址“vrf-request@lvld.agilent.com”完成的。如果您需要详细信息,只需将包含“help”文本的消息发送到“vrf-request@lvld.agilent.com”.--- -------------------------------------------------- ---------------- 以上来自于谷歌翻译 以下为原文 "Boyette, Carl" wrote: > Sir, > IOtech's FAQ page states, "No, none of IOtech's products are currently > compatible with HP VEE." It would seem my thoughts on possible compatibility > are in error. > sincerely, > Carl For many reason I generally recommend the LAN/HPIB gateway over any plug-in card . gets around issues like this, works with any PC, etc. Stan -------------------------------------------------------------------------- Stan Bischof Agilent Technologies 707-577-3994 stan_bischof@agilent.com -------------------------------------------------------------------------- --------------------------------------------------------------------- This is the "vrf" maillist, managed by Majordomo. To send messages to this maillist, just email to "vrf@lvld.agilent.com". Subscriptions and unsubscriptions are done through the address "vrf-request@lvld.agilent.com". If you need details, just send a message containing the text "help" to "vrf-request@lvld.agilent.com". --------------------------------------------------------------------- |
5个回答
嗨Omer,2天我正在尝试安装IOtech Personal488 PCI GPIB卡,这给我带来了很多问题。
我还没有安装它。 但这是一张PCI卡。我不知道PCMCIA会做什么。你有这个PCI GPIB卡的经验吗?成功,Henk den Haan软件工程师卫星服务BVKatwijk aan zee .-----原始信息--- - 来自:owner-vrf@lvld.agilent.com [mailto:owner-vrf@lvld.agilent.com] OnBehalf Of omer.akbas@arcelik.comSent:2002年2月8日13:16致:vrf@lvld.agilent.comSubject :vrf PCMCIA-GPIB CardsDear All,我打算为我的笔记本电脑购买NI(昂贵)或IOtech(便宜)madePCMCIA-GPIB卡,它在W2000下运行VEE 6.01。 在选择一个之前,我们将感谢您的经验和/或建议.Omer AkbasArcelik ASIstanbulTurkey --------------------------------- ------------------------------------这是由Majordomo管理的“vrf”maillist。 要向该maillist发送消息,只需发送电子邮件至“vrf@lvld.agilent.com”。 订阅和取消订阅是通过地址“vrf-request@lvld.agilent.com”完成的。如果您需要详细信息,只需将包含“help”文本的消息发送到“vrf-request@lvld.agilent.com”.--- -------------------------------------------------- -------------------------------------------------- -----------------------------------这是由Majordomo管理的“vrf”maillist。 要向该maillist发送消息,只需发送电子邮件至“vrf@lvld.agilent.com”。 订阅和取消订阅是通过地址“vrf-request@lvld.agilent.com”完成的。如果您需要详细信息,只需将包含“help”文本的消息发送到“vrf-request@lvld.agilent.com”.--- -------------------------------------------------- ---------------- 以上来自于谷歌翻译 以下为原文 Hi Omer, For 2 days I'm trying to install an IOtech Personal488 PCI GPIB card, which gives me lot of problems. I still haven't got it installed. But this is a PCI card. I have no idea what the PCMCIA will do. Do you have any experience with this PCI GPIB card?? Success, Henk den Haan Software Engineer Satellite Services B.V. Katwijk aan zee. -----Original Message----- From: owner-vrf@lvld.agilent.com [mailto:owner-vrf@lvld.agilent.com]On Behalf Of omer.akbas@arcelik.com Sent: 08 February 2002 13:16 To: vrf@lvld.agilent.com Subject: vrf PCMCIA-GPIB Cards Dear All, I am planning to purchase either NI(expensive) or IOtech(cheap) made PCMCIA-GPIB card for my laptop which runs VEE 6.01 under W2000. Any experiences and/or recommendations will be appreciated before I select one. Omer Akbas Arcelik A.S. Istanbul Turkey --------------------------------------------------------------------- This is the "vrf" maillist, managed by Majordomo. To send messages to this maillist, just email to "vrf@lvld.agilent.com". Subscriptions and unsubscriptions are done through the address "vrf-request@lvld.agilent.com". If you need details, just send a message containing the text "help" to "vrf-request@lvld.agilent.com". --------------------------------------------------------------------- --------------------------------------------------------------------- This is the "vrf" maillist, managed by Majordomo. To send messages to this maillist, just email to "vrf@lvld.agilent.com". Subscriptions and unsubscriptions are done through the address "vrf-request@lvld.agilent.com". If you need details, just send a message containing the text "help" to "vrf-request@lvld.agilent.com". --------------------------------------------------------------------- |
嗨Carl,你有关于使用IOtech Personal488 PCI GPIB cardwithinVee 6.0的一些信息吗?我已经尝试用NI驱动程序和NI VISA安装它,但是我无法安装它!我可以使用IOtech驱动程序,但是
当我想在VEE中使用它时,接下来的问题是:为了测试,我已将HP34401A MultiMeter连接到GPIB卡。当我想在VEE中加载Panel驱动程序时,VEE会崩溃。 似乎从VEE到GPIB卡的通信是不正确的。注意,Henk den Haan软件工程师卫星服务BVKatwijk aan zeeNetherlands -----原始消息-----来自:owner-vrf@lvld.agilent.com [mailto :owner-vrf@lvld.agilent.com]系代表中Boyette,CarlSent:2002年13年2月8日:58To:“omer.akbas@arcelik.com'Cc:vrf@lvld.agilent.comSubject:RE:VRF PCMCIA-GPIB CardsSir ,我们目前使用NI和INES PCMCIA卡与WIN 98SE和VEE 5.0。两种类型的卡都完美无缺。 有一些固有的差异。 您可以拥有多个NI PCMCIA卡,最多4个,尽管我们一次安装的是2个,在一台机器上运行。 目前,每台机器只允许使用一张INES PCMCIA卡。 因此,如果您计划一次使用多条GPIB总线,请获取NI。 NI卡使用NI VISA和SIML库,而INES卡使用Agilent库。 如果我没记错的话,IOTech会使用NI库。 我猜测他们使用的是相似的,如果不是相同的芯片组,应该是一个几乎直接的替代品。 此外,还有一些网站比较哪些卡使用哪些图书馆,驱动程序等。我认为HTBasic有一个比较。真的,Carl BoyetteEngineer / ScientistElectromagnetic EffectsThe Boeing CompanyP.O。 专栏21233 MC 721E-M123Kennedy航天中心,FL 32815-0233Telephone 321.861.8195carl.b.boyette-iii@boeing.com-----Original消息-----从:omer.akbas@arcelik.com [邮寄地址: 发送时间:2002年2月8日星期五上午7:16发送:vrf@lvld.agilent.com主题:vrf PCMCIA-GPIB CardsDear All,我打算购买NI(昂贵)或IOtech(便宜) 我的笔记本电脑的madePCMCIA-GPIB卡在W2000下运行VEE 6.01。 在选择一个之前,我们将感谢您的经验和/或建议.Omer AkbasArcelik ASIstanbulTurkey --------------------------------- ------------------------------------这是由Majordomo管理的“vrf”maillist。 要向该maillist发送消息,只需发送电子邮件至“vrf@lvld.agilent.com”。 订阅和取消订阅是通过地址“vrf-request@lvld.agilent.com”完成的。如果您需要详细信息,只需将包含“help”文本的消息发送到“vrf-request@lvld.agilent.com”.--- -------------------------------------------------- -------------------------------------------------- -----------------------------------这是由Majordomo管理的“vrf”maillist。 要向该maillist发送消息,只需发送电子邮件至“vrf@lvld.agilent.com”。 订阅和取消订阅是通过地址“vrf-request@lvld.agilent.com”完成的。如果您需要详细信息,只需将包含“help”文本的消息发送到“vrf-request@lvld.agilent.com”.--- -------------------------------------------------- -------------------------------------------------- -----------------------------------这是由Majordomo管理的“vrf”maillist。 要向该maillist发送消息,只需发送电子邮件至“vrf@lvld.agilent.com”。 订阅和取消订阅是通过地址“vrf-request@lvld.agilent.com”完成的。如果您需要详细信息,只需将包含“help”文本的消息发送到“vrf-request@lvld.agilent.com”.--- -------------------------------------------------- ---------------- 以上来自于谷歌翻译 以下为原文 Hi Carl, Do you have some information of using IOtech Personal488 PCI GPIB card within Vee 6.0? I've already tried to install it with the NI drivers, and the NI VISA, but I can't install it! With the IOtech drivers I can, but when I want to use it in VEE next problem occurres: Just for testing I've connected a HP34401A MultiMeter to the GPIB card. When I want to load the Panel driver in VEE, VEE crashes. It seems that the communication from VEE to the GPIB card is not correct. Regards, Henk den Haan Software Engineer Satellite Services B.V. Katwijk aan zee Netherlands -----Original Message----- From: owner-vrf@lvld.agilent.com [mailto:owner-vrf@lvld.agilent.com]On Behalf Of Boyette, Carl Sent: 08 February 2002 13:58 To: [email=]'omer.akbas@arcelik.com[/email]' Cc: vrf@lvld.agilent.com Subject: RE: vrf PCMCIA-GPIB Cards Sir, We currently use both NI and INES PCMCIA cards with WIN 98SE and VEE 5.0. Both types of cards have worked flawlessly. There are some inherent differences. You can have multiple NI PCMCIA cards, up to 4, although the most we have installed at one time is 2, running on one machine. Currently, only one INES PCMCIA card is allowed per machine. So if you are planning on more than one GPIB bus at a time get NI. The NI cards use the NI VISA and SICL libraries while INES cards use the Agilent libraries. IOTech uses the NI libraries, if I recall correctly. I would surmise that they use a similar, if not the same, chipset and should be an almost direct replacement. Also, there are some sites that compare which cards use which libraries, drivers, etc. I think HTBasic has a comparison. sincerely, Carl Boyette Engineer/Scientist Electromagnetic Effects The Boeing Company P.O. Box 21233 MC 721E-M123 Kennedy Space Center, FL 32815-0233 Telephone 321.861.8195 carl.b.boyette-iii@boeing.com -----Original Message----- From: omer.akbas@arcelik.com [mailto:omer.akbas@arcelik.com] Sent: Friday, February 08, 2002 7:16 AM To: vrf@lvld.agilent.com Subject: vrf PCMCIA-GPIB Cards Dear All, I am planning to purchase either NI(expensive) or IOtech(cheap) made PCMCIA-GPIB card for my laptop which runs VEE 6.01 under W2000. Any experiences and/or recommendations will be appreciated before I select one. Omer Akbas Arcelik A.S. Istanbul Turkey --------------------------------------------------------------------- This is the "vrf" maillist, managed by Majordomo. To send messages to this maillist, just email to "vrf@lvld.agilent.com". Subscriptions and unsubscriptions are done through the address "vrf-request@lvld.agilent.com". If you need details, just send a message containing the text "help" to "vrf-request@lvld.agilent.com". --------------------------------------------------------------------- --------------------------------------------------------------------- This is the "vrf" maillist, managed by Majordomo. To send messages to this maillist, just email to "vrf@lvld.agilent.com". Subscriptions and unsubscriptions are done through the address "vrf-request@lvld.agilent.com". If you need details, just send a message containing the text "help" to "vrf-request@lvld.agilent.com". --------------------------------------------------------------------- --------------------------------------------------------------------- This is the "vrf" maillist, managed by Majordomo. To send messages to this maillist, just email to "vrf@lvld.agilent.com". Subscriptions and unsubscriptions are done through the address "vrf-request@lvld.agilent.com". If you need details, just send a message containing the text "help" to "vrf-request@lvld.agilent.com". --------------------------------------------------------------------- |
亲爱的所有人,我打算为我的笔记本电脑购买NI(昂贵)或IOtech(便宜)madePCMCIA-GPIB卡,它在W2000下运行VEE 6.01。
在选择一个之前,我们将感谢您的经验和/或建议.Omer AkbasArcelik ASIstanbulTurkey --------------------------------- ------------------------------------这是由Majordomo管理的“vrf”maillist。 要向该maillist发送消息,只需发送电子邮件至“vrf@lvld.agilent.com”。 订阅和取消订阅是通过地址“vrf-request@lvld.agilent.com”完成的。如果您需要详细信息,只需将包含“help”文本的消息发送到“vrf-request@lvld.agilent.com”.--- -------------------------------------------------- ---------------- 以上来自于谷歌翻译 以下为原文 Dear All, I am planning to purchase either NI(expensive) or IOtech(cheap) made PCMCIA-GPIB card for my laptop which runs VEE 6.01 under W2000. Any experiences and/or recommendations will be appreciated before I select one. Omer Akbas Arcelik A.S. Istanbul Turkey --------------------------------------------------------------------- This is the "vrf" maillist, managed by Majordomo. To send messages to this maillist, just email to "vrf@lvld.agilent.com". Subscriptions and unsubscriptions are done through the address "vrf-request@lvld.agilent.com". If you need details, just send a message containing the text "help" to "vrf-request@lvld.agilent.com". --------------------------------------------------------------------- |
先生,我们目前使用NI和INES PCMCIA卡与WIN 98SE和VEE 5.0.Both类型的卡完美无瑕。
有一些固有的差异。 您可以拥有多个NI PCMCIA卡,最多4个,尽管我们一次安装的是2个,在一台机器上运行。 目前,每台机器只允许使用一张INES PCMCIA卡。 因此,如果您计划一次使用多条GPIB总线,请获取NI。 NI卡使用NI VISA和SIML库,而INES卡使用Agilent库。 如果我没记错的话,IOTech会使用NI库。 我猜测他们使用的是相似的,如果不是相同的芯片组,应该是一个几乎直接的替代品。 此外,还有一些网站比较哪些卡使用哪些图书馆,驱动程序等。我认为HTBasic有一个比较。真的,Carl BoyetteEngineer / ScientistElectromagnetic EffectsThe Boeing CompanyP.O。 方框21233 MC 721E-M123肯尼迪航天中心,FL 32815-0233电话321.861.8195carl.b.boyette-iii@boeing.com -----原始信息-----来自:omer.akbas@arcelik.com [mailto: omer.akbas@arcelik.com]发送时间:周五2002年2月8日7时16分AMTo:vrf@lvld.agilent.comSubject:VRF PCMCIA-GPIB CardsDear所有,我打算购买任一NI(昂贵的)或IOTECH(便宜 我的笔记本电脑的madePCMCIA-GPIB卡在W2000下运行VEE 6.01。 在选择一个之前,我们将感谢您的经验和/或建议.Omer AkbasArcelik ASIstanbulTurkey --------------------------------- ------------------------------------这是由Majordomo管理的“vrf”maillist。 要向该maillist发送消息,只需发送电子邮件至“vrf@lvld.agilent.com”。 订阅和取消订阅是通过地址“vrf-request@lvld.agilent.com”完成的。如果您需要详细信息,只需将包含“help”文本的消息发送到“vrf-request@lvld.agilent.com”.--- -------------------------------------------------- -------------------------------------------------- -----------------------------------这是由Majordomo管理的“vrf”maillist。 要向该maillist发送消息,只需发送电子邮件至“vrf@lvld.agilent.com”。 订阅和取消订阅是通过地址“vrf-request@lvld.agilent.com”完成的。如果您需要详细信息,只需将包含“help”文本的消息发送到“vrf-request@lvld.agilent.com”.--- -------------------------------------------------- ---------------- 以上来自于谷歌翻译 以下为原文 Sir, We currently use both NI and INES PCMCIA cards with WIN 98SE and VEE 5.0. Both types of cards have worked flawlessly. There are some inherent differences. You can have multiple NI PCMCIA cards, up to 4, although the most we have installed at one time is 2, running on one machine. Currently, only one INES PCMCIA card is allowed per machine. So if you are planning on more than one GPIB bus at a time get NI. The NI cards use the NI VISA and SICL libraries while INES cards use the Agilent libraries. IOTech uses the NI libraries, if I recall correctly. I would surmise that they use a similar, if not the same, chipset and should be an almost direct replacement. Also, there are some sites that compare which cards use which libraries, drivers, etc. I think HTBasic has a comparison. sincerely, Carl Boyette Engineer/Scientist Electromagnetic Effects The Boeing Company P.O. Box 21233 MC 721E-M123 Kennedy Space Center, FL 32815-0233 Telephone 321.861.8195 carl.b.boyette-iii@boeing.com -----Original Message----- From: omer.akbas@arcelik.com [mailto:omer.akbas@arcelik.com] Sent: Friday, February 08, 2002 7:16 AM To: vrf@lvld.agilent.com Subject: vrf PCMCIA-GPIB Cards Dear All, I am planning to purchase either NI(expensive) or IOtech(cheap) made PCMCIA-GPIB card for my laptop which runs VEE 6.01 under W2000. Any experiences and/or recommendations will be appreciated before I select one. Omer Akbas Arcelik A.S. Istanbul Turkey --------------------------------------------------------------------- This is the "vrf" maillist, managed by Majordomo. To send messages to this maillist, just email to "vrf@lvld.agilent.com". Subscriptions and unsubscriptions are done through the address "vrf-request@lvld.agilent.com". If you need details, just send a message containing the text "help" to "vrf-request@lvld.agilent.com". --------------------------------------------------------------------- --------------------------------------------------------------------- This is the "vrf" maillist, managed by Majordomo. To send messages to this maillist, just email to "vrf@lvld.agilent.com". Subscriptions and unsubscriptions are done through the address "vrf-request@lvld.agilent.com". If you need details, just send a message containing the text "help" to "vrf-request@lvld.agilent.com". --------------------------------------------------------------------- |
先生,IOtech的FAQ页面说:“不,IOtech的产品目前都没有与HP VEE兼容。”
似乎我对可能的兼容性的想法是错误的。真的,卡尔-----原始消息-----来自:Henk den Haan [mailto:h.den.haan@satserv.nl]发送:2008年2月5日星期五 ,2002年8:22 AM:Boyette,CarlCc:vrf@lvld.agilent.com主题:RE:vrf PCMCIA-GPIB CardsHi Carl,您是否有关于使用IOtech Personal488 PCI GPIB cardwithinVee 6.0的一些信息?我已经尝试过安装它 使用NI驱动程序和NI VISA,但我无法安装它!我可以使用IOtech驱动程序,但是当我想在VEE中使用它时,问题就在于:我只是为了测试而已将HP34401A MultiMeter连接到GPIB卡 当我想在VEE中加载Panel驱动程序时,VEE会崩溃。 似乎从VEE到GPIB卡的通信是不正确的。注意,Henk den Haan软件工程师卫星服务BVKatwijk aan zeeNetherlands -----原始消息-----来自:owner-vrf@lvld.agilent.com [mailto :owner-vrf@lvld.agilent.com]系代表中Boyette,CarlSent:2002年13年2月8日:58To:“omer.akbas@arcelik.com'Cc:vrf@lvld.agilent.comSubject:RE:VRF PCMCIA-GPIB CardsSir ,我们目前使用NI和INES PCMCIA卡与WIN 98SE和VEE 5.0。两种类型的卡都完美无缺。 有一些固有的差异。 您可以拥有多个NI PCMCIA卡,最多4个,尽管我们一次安装的是2个,在一台机器上运行。 目前,每台机器只允许使用一张INES PCMCIA卡。 因此,如果您计划一次使用多条GPIB总线,请获取NI。 NI卡使用NI VISA和SIML库,而INES卡使用Agilent库。 如果我没记错的话,IOTech会使用NI库。 我猜测他们使用的是相似的,如果不是相同的芯片组,应该是一个几乎直接的替代品。 此外,还有一些网站比较哪些卡使用哪些图书馆,驱动程序等。我认为HTBasic有一个比较。真的,Carl BoyetteEngineer / ScientistElectromagnetic EffectsThe Boeing CompanyP.O。 专栏21233 MC 721E-M123Kennedy航天中心,FL 32815-0233Telephone 321.861.8195carl.b.boyette-iii@boeing.com-----Original消息-----从:omer.akbas@arcelik.com [邮寄地址: 发送时间:2002年2月8日星期五上午7:16发送:vrf@lvld.agilent.com主题:vrf PCMCIA-GPIB CardsDear All,我打算购买NI(昂贵)或IOtech(便宜) 我的笔记本电脑的madePCMCIA-GPIB卡在W2000下运行VEE 6.01。 在选择一个之前,我们将感谢您的经验和/或建议.Omer AkbasArcelik ASIstanbulTurkey --------------------------------- ------------------------------------这是由Majordomo管理的“vrf”maillist。 要向该maillist发送消息,只需发送电子邮件至“vrf@lvld.agilent.com”。 订阅和取消订阅是通过地址“vrf-request@lvld.agilent.com”完成的。如果您需要详细信息,只需将包含“help”文本的消息发送到“vrf-request@lvld.agilent.com”.--- -------------------------------------------------- -------------------------------------------------- -----------------------------------这是由Majordomo管理的“vrf”maillist。 要向该maillist发送消息,只需发送电子邮件至“vrf@lvld.agilent.com”。 订阅和取消订阅是通过地址“vrf-request@lvld.agilent.com”完成的。如果您需要详细信息,只需将包含“help”文本的消息发送到“vrf-request@lvld.agilent.com”.--- -------------------------------------------------- -------------------------------------------------- -----------------------------------这是由Majordomo管理的“vrf”maillist。 要向该maillist发送消息,只需发送电子邮件至“vrf@lvld.agilent.com”。 订阅和取消订阅是通过地址“vrf-request@lvld.agilent.com”完成的。如果您需要详细信息,只需将包含“help”文本的消息发送到“vrf-request@lvld.agilent.com”.--- -------------------------------------------------- ---------------- 以上来自于谷歌翻译 以下为原文 Sir, IOtech's FAQ page states, "No, none of IOtech's products are currently compatible with HP VEE." It would seem my thoughts on possible compatibility are in error. sincerely, Carl -----Original Message----- From: Henk den Haan [mailto:h.den.haan@satserv.nl] Sent: Friday, February 08, 2002 8:22 AM To: Boyette, Carl Cc: vrf@lvld.agilent.com Subject: RE: vrf PCMCIA-GPIB Cards Hi Carl, Do you have some information of using IOtech Personal488 PCI GPIB card within Vee 6.0? I've already tried to install it with the NI drivers, and the NI VISA, but I can't install it! With the IOtech drivers I can, but when I want to use it in VEE next problem occurres: Just for testing I've connected a HP34401A MultiMeter to the GPIB card. When I want to load the Panel driver in VEE, VEE crashes. It seems that the communication from VEE to the GPIB card is not correct. Regards, Henk den Haan Software Engineer Satellite Services B.V. Katwijk aan zee Netherlands -----Original Message----- From: owner-vrf@lvld.agilent.com [mailto:owner-vrf@lvld.agilent.com]On Behalf Of Boyette, Carl Sent: 08 February 2002 13:58 To: [email=]'omer.akbas@arcelik.com[/email]' Cc: vrf@lvld.agilent.com Subject: RE: vrf PCMCIA-GPIB Cards Sir, We currently use both NI and INES PCMCIA cards with WIN 98SE and VEE 5.0. Both types of cards have worked flawlessly. There are some inherent differences. You can have multiple NI PCMCIA cards, up to 4, although the most we have installed at one time is 2, running on one machine. Currently, only one INES PCMCIA card is allowed per machine. So if you are planning on more than one GPIB bus at a time get NI. The NI cards use the NI VISA and SICL libraries while INES cards use the Agilent libraries. IOTech uses the NI libraries, if I recall correctly. I would surmise that they use a similar, if not the same, chipset and should be an almost direct replacement. Also, there are some sites that compare which cards use which libraries, drivers, etc. I think HTBasic has a comparison. sincerely, Carl Boyette Engineer/Scientist Electromagnetic Effects The Boeing Company P.O. Box 21233 MC 721E-M123 Kennedy Space Center, FL 32815-0233 Telephone 321.861.8195 carl.b.boyette-iii@boeing.com -----Original Message----- From: omer.akbas@arcelik.com [mailto:omer.akbas@arcelik.com] Sent: Friday, February 08, 2002 7:16 AM To: vrf@lvld.agilent.com Subject: vrf PCMCIA-GPIB Cards Dear All, I am planning to purchase either NI(expensive) or IOtech(cheap) made PCMCIA-GPIB card for my laptop which runs VEE 6.01 under W2000. Any experiences and/or recommendations will be appreciated before I select one. Omer Akbas Arcelik A.S. Istanbul Turkey --------------------------------------------------------------------- This is the "vrf" maillist, managed by Majordomo. To send messages to this maillist, just email to "vrf@lvld.agilent.com". Subscriptions and unsubscriptions are done through the address "vrf-request@lvld.agilent.com". If you need details, just send a message containing the text "help" to "vrf-request@lvld.agilent.com". --------------------------------------------------------------------- --------------------------------------------------------------------- This is the "vrf" maillist, managed by Majordomo. To send messages to this maillist, just email to "vrf@lvld.agilent.com". Subscriptions and unsubscriptions are done through the address "vrf-request@lvld.agilent.com". If you need details, just send a message containing the text "help" to "vrf-request@lvld.agilent.com". --------------------------------------------------------------------- --------------------------------------------------------------------- This is the "vrf" maillist, managed by Majordomo. To send messages to this maillist, just email to "vrf@lvld.agilent.com". Subscriptions and unsubscriptions are done through the address "vrf-request@lvld.agilent.com". If you need details, just send a message containing the text "help" to "vrf-request@lvld.agilent.com". --------------------------------------------------------------------- |
只有小组成员才能发言,加入小组>>
1221 浏览 0 评论
2346 浏览 1 评论
2155 浏览 1 评论
2021 浏览 5 评论
2900 浏览 3 评论
964浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
700浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
801浏览 0评论
1223浏览 0评论
GMT+8, 2024-11-22 13:50 , Processed in 1.524518 second(s), Total 87, Slave 70 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
