大家好,我想建立一个安装有两个PIC32为基础的板(PIC32 MZ2048 FH064作为接口板和PIC32 MK1024GPE作为PWM发生器)。我想用I2C作为威刚交换总线(将参数写入SLAB板并读取它的状态)。主部分看起来很好,但是从不能到达回调函数。只有当我启用一般的调用地址时,它才能到达它,但是它开始对任何地址(不仅是0x00)作出反应,而且它总是“读取”请求(事件=DRVIII2CYBuffrSyavaveRead请求),即使我发送了0B90000,这肯定是“写入”。基本上,任何地址都给出相同的结果。错了吗?这里是从属板回调代码:ValueGetimePrimeSules({)TestLead(1);} StEnStAtSub(){TestAppI2I2CySLaveEy回调(DrvII2CYBuffryEngEvin事件,DRVIII2CYBuffr句柄Buffer-Hug,UntPrTrt上下文){if(事件=DRVIII2CYBuffrSyavaveRead请求){/ /查询通道GETPARA状态如果(事件==DRVIII2CYBuffrSyavaveWrreWestEnter请求){//SET参数sEntAsStUnEs();}和和声配置也附上。使用的软件:MPLABX V4.01和声2.04xC32 1.44。
以上来自于百度翻译 以下为原文 Hello everyone, I'm trying to build a setup with two PIC32 based boards (PIC32MZ2048FH064 as Interface board and PIC32MK1024GPE as PWM generator). I would like to use I2C as a data exchange bus (to write parameters to the slave board and to read it's status). Master part looks fine, but slave can't get to the callback function. I can reach it only when I enable General Call Address, but it starts to react on any address (not only 0x00), and it's always "read" request (event == DRV_I2C_BUFFER_SLAVE_READ_REQUESTED), even if I send 0b00000000, which is definitely "write". Basically, any address giving the same result. What can be wrong? Here is slave board callback code: void getParameters(){And HARMony config is also attached. Software used: MPLABX v4.01 Harmony 2.04 XC32 1.44 Attached Image(s) |
1个回答
问题已解决。端口系统服务已禁用。在启用和配置引脚作为SCL2/SDA2 -工作就像一个魅力。
以上来自于百度翻译 以下为原文 Problem solved. Port System Service was disabled. After enabling and configuring pins as SCL2/SDA2- works like a charm. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 02:24 , Processed in 0.611154 second(s), Total 75, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
533
