电子发烧友论坛|
你好,
当我用我的电脑开始时,它有EZ-USB V1.3.3和Windows 7。然后迁移到Win 10,并继续使用VER 1.3.3。现在我只是试着升级到VER 1.3.4,这个错误出现了。 我尝试了一个干净的卸载,它似乎没有帮助它。每次运行安装EXE 1.3.4,当它试图运行ARM GCC安装程序时,都会给我上面的错误。我甚至在更新文件夹中找到了ARCGC.EXE,并试图在那里运行修复,同样的问题也出现了。 你有没有想过如何通过这个,并实际安装EZ USB FX3 SDK? 以上来自于百度翻译 以下为原文 Hello, When i started with my computer it had EZ USB ver 1.3.3 and Windows 7. I then migrated to Win 10 and kept using ver 1.3.3. Now i just tried upgrading to ver 1.3.4 and this error came up. I tried a clean uninstall and it appears nothing helps it. Every time i run the installation exe for 1.3.4 it gives me the above error when it tries to run the ARM GCC installer. I even found the ARM GCC.exe in the Updates folder and tried to run Repair there and this same issue shows up. Do you have any idea how to get past this and actually install the EZ USB FX3 SDK? |
2个回答
嗨,Andriy,
你是如何实现清洁卸载的? 它是通过FX3SDK登陆页面:HTTP://wwwyCysC./DooptTys/Studio/Studio/Studio/EZ-UB-FX3软件开发工具包还是使用CyPress更新管理器? 以上来自于百度翻译 以下为原文 Hi Andriy, How did you implement a clean uninstalling? Is it through FX3 SDK landing page : http://www.cypress.com/documentation/software-and-drivers/ez-u***-fx3-software-development-kit or using Cypress Update Manager? |
缘来伴一生 发表于 2018-9-5 18:52 首先,我试着直接从更新管理器做一个更新。失败了。然后我去程序文件,试图做一个干净的卸载,也失败了。然后我尝试安装1.3.4,我从你提到的网站,希望它会修复破碎的卸载,它似乎无法通过上述屏幕截图。那就是我现在所在的地方。程序文件说没有安装,但是当我尝试安装1.3.4时,它停止在GCC步骤并抛出错误。 以上来自于百度翻译 以下为原文 First i tried doing an update directly from the Update Manager. That failed. Then i went to program files, tried to do a clean uninstall and that failed as well. Then i tried just installing 1.3.4 that i got from the site you mention hoping it would fix the broken uninstall and it didnt seem to be able to go past the above screenshot. Thats where im at now. Program file says nothing is installed but when i try to install 1.3.4 it stops at the GCC step and throws the error. |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7567浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 09:14 , Processed in 1.150129 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2763
