电子发烧友论坛|
嘿,我用PSoC4设备来做键盘。直到我制造超过1000板,我目前面临无按键我得到按键输入的问题。这是不是在所有的板,但一些板anyboady可以帮助我吗?
以上来自于百度翻译 以下为原文 hey I am using PSoC4 device for capsense keyboard. till date i manufacture more than 1000 boards, presently i am facing problem that without key press i am getting as key press input . this is not in all board but in some boards anyboady can help me? |
3个回答
你需要选择假触摸板,并调整它。
这些板有高噪音吗? 这些董事会的一致性不好吗? 你能告诉我你如何把手指阈值、噪声阈值和迟滞? 同时,你需要澄清什么设备你,什么样的工作环境? 以上来自于百度翻译 以下为原文 You need to select the false touch board, and tuner it. Does these boards have a high noise? Does these boards have a poor consistency? Can you tell me how you set the finger threshold, noise threshold and hysteresis? At the same time, you need to clarify what device you do, and what the working environment? |
谢谢你的回复 1。电源连接USB端口时无噪声 2。我使用自动调谐模式,所以我没有手动调整它。 三。设备是CY8C4245AXI-83 4。这个问题我面临着1个或2个董事会在100个董事会。 5。工作环境正常。即使在温度为25度的实验台上 以上来自于百度翻译 以下为原文 thanks for the reply 1. power supply no noise as it is connected to USB port 2. I am using auto tune mode so i have not tune it manually 3. device is CY8C4245AXI-483 4. this problem i am facing in 1 or 2 board out of 100 boards. 5. working environment is normal. even on lab table with temp 25 degree |
嗨,Abhay,
有时由于制造公差,板与板的变化可能发生在厚度和材料的使用方面。 我建议检查这些板上的CopSink的CP。CP肯定会与过去的董事会有所不同,这也是它失败的原因。 第二可能有针短裤GND或开放,这可能导致这个问题。 当做 尼尚特 以上来自于百度翻译 以下为原文 Hi Abhay, Sometimes due to manufacturing tolerance, board to board variation can happen in terms of thickness and material use. I recommend to check the Cp of the CapSense on those boards. The Cp would certainly be different from the passed boards and that is the reason it would have failed. 2nd there could be Pin shorts to GND or Open which can lead to this issue. Regards Nishant |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7255 浏览 0 评论
2482 浏览 1 评论
2176 浏览 1 评论
4037 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2082 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7761浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6320浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
753浏览 2评论
726浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
8154浏览 2评论
/9
GMT+8, 2025-12-10 04:31 , Processed in 0.838095 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2170
