配置SPI功能,一旦配置:
后就进入了硬件错误,也就是进入这个函数: , 具体来说就是在配置第二个复用功能时进入的硬件错误,我把后面两个复用功能配置屏蔽掉就可以正常跑起来,不进入硬件错误,,, 这是神马情况???想知道有木有小伙伴遇到相同的情况?????欢迎各种指导。。。 继续阅读原创汇总: STM32F030探索套件开发日志,中文教程,使用问答80篇 |
9个回答
请注意void GPIO_PinAFConfig(GPIO_TypeDef* GPIOx, uint16_t GPIO_PinSource, uint8_t GPIO_AF);是GPIO_PinSource哦,上语句应改为GPIO_PinAFConfig(GPIOB, GPIO_PinSource13, GPIO_AF_0);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource14, GPIO_AF_0); GPIO_PinAFConfig(GPIOB, GPIO_PinSource15, GPIO_AF_0);你可以看一下头文件里面的GPIO_Pin 和 GPIO_PinSource定义是不一样的 |
我也遇到过这个问题,检查了好久才搞明白,自己太脑残了
是呀,这就是要仔细阅读库文件了
是呀,这就是要仔细阅读库文件了
/*--------------------------------------------*/ #define GPIO_PinSource0 ((uint8_t)0x00) #define GPIO_PinSource1 ((uint8_t)0x01) #define GPIO_PinSource10 ((uint8_t)0x0A) #define GPIO_PinSource11 ((uint8_t)0x0B) #define GPIO_PinSource12 ((uint8_t)0x0C) #define GPIO_PinSource13 ((uint8_t)0x0D) #define GPIO_PinSource14 ((uint8_t)0x0E) #define GPIO_PinSource15 ((uint8_t)0x0F) #define GPIO_PinSource2 ((uint8_t)0x02) #define GPIO_PinSource3 ((uint8_t)0x03) #define GPIO_PinSource4 ((uint8_t)0x04) #define GPIO_PinSource5 ((uint8_t)0x05) #define GPIO_PinSource6 ((uint8_t)0x06) #define GPIO_PinSource7 ((uint8_t)0x07) #define GPIO_PinSource8 ((uint8_t)0x08) #define GPIO_PinSource9 ((uint8_t)0x09) /*--------------------------------------------*/ #define GPIO_Pin_0 ((uint16_t)0x0001) #define GPIO_Pin_1 ((uint16_t)0x0002) #define GPIO_Pin_10 ((uint16_t)0x0400) #define GPIO_Pin_11 ((uint16_t)0x0800) #define GPIO_Pin_12 ((uint16_t)0x1000) #define GPIO_Pin_13 ((uint16_t)0x2000) #define GPIO_Pin_14 ((uint16_t)0x4000) #define GPIO_Pin_15 ((uint16_t)0x8000) #define GPIO_Pin_2 ((uint16_t)0x0004) #define GPIO_Pin_3 ((uint16_t)0x0008) #define GPIO_Pin_4 ((uint16_t)0x0010) #define GPIO_Pin_5 ((uint16_t)0x0020) #define GPIO_Pin_6 ((uint16_t)0x0040) #define GPIO_Pin_7 ((uint16_t)0x0080) #define GPIO_Pin_8 ((uint16_t)0x0100) #define GPIO_Pin_9 ((uint16_t)0x0200) #define GPIO_Pin_All ((uint16_t)0xFFFF) /*--------------------------------------------*/ |
楼上几位解释正确。
以后先看看例程,常用外设都有官方例程的
回复第 2 楼 于2014-01-20 23:34:57发表:
请注意void GPIO_PinAFConfig(GPIO_TypeDef* GPIOx, uint16_t GPIO_PinSource, uint8_t GPIO_AF);是GPIO_PinSource哦,上语句应改为GPIO_PinAFConfig(GPIOB, GPIO_PinSource13, GPIO_AF_0); GPIO_PinAFConfig(GPIOB, GPIO_PinSource14, GPIO_AF_0); GPIO_PinAFConfig(GPIOB, GPIO_PinSource15, GPIO_AF_0);你可以看一下头文件里面的GPIO_Pin 和 GPIO_PinSource定义是不一样的 奥。。。原来是酱紫,,,太脑残了。。。 |
look啊啊啊 啊
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
STM32配合可编程加密芯片SMEC88ST的防抄板加密方案设计
950 浏览 0 评论
2360 浏览 1 评论
AD7686芯片不传输数据给STM32,但是手按住就会有数据。
2159 浏览 3 评论
4791 浏览 0 评论
如何解决MPU-9250与STM32通讯时,出现HAL_ERROR = 0x01U
2306 浏览 1 评论
GMT+8, 2024-12-30 07:47 , Processed in 0.844849 second(s), Total 87, Slave 71 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
