电子发烧友论坛|
大家好,我想在我的电脑上安装MPLAB X IDE V5.00。PC正在运行Windows 10企业2016 LTSB 64位。当我尝试安装它时,安装工作很好,直到它进入安装后的步骤。当它到达时,出现一个错误,如您在附件中所看到的,它说:错误运行c:MeNaBaseMPLABCOMP-V3.32.0WiDOWS安装程序.exe——jReBooin“c:NeXialStudio/sys /Java/jRe1.8O0144/BI//Java.exe”。由此产生的错误问题是,我可以运行MPLAB X来执行我的代码和所有。但是连接到我的ICD3绝对是不可能的。我在Windows的设备管理器中手动安装了ICD3的驱动程序,所以Windows本身看到ICD3,它很好,但是从MPLAB X IDE(或IPE)来看,设备不存在,不可能连接到它。我尝试在不同的地方安装程序(程序文件、文档和直接在N中)。EW文件夹C:NeWiScript程序,如果我试图安装它的文件夹是受保护的。我试着将程序作为管理员从非管理员帐户运行,也直接从管理员帐户运行它。我在工作时在3台不同的计算机上尝试过(2个Windows 10, 1 Windows 7)。同样的错误。我还尝试安装版本3.65,它给出完全相同的错误和版本2,它给出了另一个错误(见附件),但是在安装后的步骤中再次:错误更名c:/程序文件(x86)/Microchip /MPLABX/MCHPWINUBDEVICE64.EXTOC:/Windows /系统32 / MCHPWINUSBDeFiels6.exe(系统和32之间没有空间,但论坛不会让我用它)。我也尝试运行命令行。错误直接显示在命令提示符中。它不显示任何错误,但不改变任何东西,ICD3仍然无法从MPLAB获得。另一方面,我尝试了T。o安装在我的PC在家里的Windows 10家庭64位,它完美地工作,没有错误所有罚款ICD3可访问。所以我想这是与配置的Windows我有。我不知道,有人经历过这个问题之前,或有一个想法如何解决它?还有可能手动运行所有的后步安装,这样我就可以手动工作了吗?谢谢,
以上来自于百度翻译 以下为原文 Hi everyone, I am trying to install the MPLAB X IDE v5.00 on my PC at work. The PC is running windows 10 enterprise 2016 LTSB 64 bit. When I try to install it the installation works fine until it gets to the post-install steps. When it gets there an error appears, as you can see in the file attached, it says: Error running C:new_programMPLABCOMM-v3.32.03-windows-installer.exe --jrebinary "C:new_program/sys/java/jre1.8.0_144/bin//java.exe". The resulting problems of that error is that I can run MPLAB X do my code and all but it is absolutely impossible to connect to the ICD3 I have. I installed manually the driver of the ICD3 in the device manager in windows so windows itself see the ICD3 it's fine but from the MPLAB X IDE (or IPE) the device does not exist, impossible to connect to it. I tried installing the program at various place (Program files, document and directly in a new folder C:new_program) in case the folder I tried to install it in was protected. I tried running the program as an administrator from a non admin account and also running it directly from an admin account. I tried it on 3 different computers at work (2 windows 10, 1 windows 7). It always gives the same error. I also tried installing the version 3.65 which gives exactly the same error and the version 2.00 which gives another error (see attachments) but again in the post install step: Error renaming C:/Program Files(x86)/Microchip/MPLABX/mchpwinu***device64.exe to C:/Windows/System 32/mchpwinu***device64.exe (with no space between system and 32 but the forum will not let me post with it) I also tried to run the command line the error is showing directly in the command prompt it does not show any error but does not change anything, ICD3 still unavailable from MPLAB. On the other hand I tried to install it on my PC at home on windows 10 home 64 bits it worked perfectly no errors all fine ICD3 accessible. So I'm thinking it has to do with the configuration of windows I have. I am out of idea, did anyone experienced that issue before or have an idea how to resolve it? Also is it possible to run all the post-step install manually so that I can maybe get it working manually? Thanks, Attached Image(s) |
2个回答
我认为你必须加入你的工作IT部门,你没有这个安装所需的权限。最坏的情况是,它可以登录到你的PC,只有一个特殊的登录,只有他们可以访问更多的权利。这不是我们的地方,建议绕过你的IT部门保护你的公司网络的方式。你的工作职责是写PIC软件吗?
以上来自于百度翻译 以下为原文 I think you must involve your work IT department, you do not have the permissions required for this install. Worst case IT could log onto your PC with a special logon only they have access to with more rights. As you have proved it works fine on your home PC that the IT department has no control over. It is not our place to suggest some way of bypassing the protections your IT department has put in place to protect the company network. Is your job function at work writing PIC software ? |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1121浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
872浏览 1评论
473浏览 0评论
/9
GMT+8, 2025-12-1 18:53 , Processed in 0.428449 second(s), Total 42, Slave 35 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4217
