电子发烧友论坛|
今天我已经尝试了好几次来运行MyPrabxV4.01-WiDOWS安装程序.EXE。它运行,但挂起,永远不会恢复。这是在Windows 10,版本1703,建立1563.608它挂起来,当它“安装,请等待安装程序安装MPLAB X IDE V4.01在您的计算机上”,它显示零进度条。Red X没有关闭应用程序(那里的开发团队的红旗)。我不得不用任务管理器来结束这个过程。
以上来自于百度翻译 以下为原文 I've tried several times today to run the MPLABX-v4.01-windows-installer.exe. It runs, but hangs and never recovers. This is on Windows 10, Version 1703, build 15063.608 It hangs when it gets to "Installing Please wait while Setup installs MPLAB X IDE v4.01 on your computer" It shows zero percent progress in the progress bar. Red X does not close the app (red flag for the development team there). I had to kill the process with Task Manager. |
4个回答
嗨,你下载的档案可能不正确吗?当做
以上来自于百度翻译 以下为原文 Hi, Could it be that your downloaded archive is not correct ? Regards |
可能和这个线程一样的问题:HTTP://www. McCHIP.COM/FUMMS/M1009615ASPX
以上来自于百度翻译 以下为原文 Maybe same problem as in this thread: http://www.microchip.com/forums/m1009615.aspx |
拥有与原版相同的问题,相同的版本和构建,64位Windows 10专业版。上面建议的线程似乎不相关,安装程序挂在安装屏幕的开始,没有显示任何进展。不太高兴刚刚买了一个ICD4,但仍然无法更新MPLAX X能够使用它。
以上来自于百度翻译 以下为原文 Having exactly the same problem as the original post, same version and build, 64bit Windows 10 Pro. The thread suggested above does not appear to be relevant, the installer hangs at the start of the Installing screen, no progress is shown. Any solutions yet? Not best pleased having just bought an ICD4, but still can't update MPLAB X to be able to use it. |
这个问题至少已经为我解决了。安装程序挂起是因为日志错误信息“找不到注册表项HKEY-LoalAlxMaultStudioMicrochip MPLAB IDE安装DIIR。将变量MPLAB8设置为“空值”。他们无法解释这一点,因为它们的各种试用IDE机器上没有这样的注册表项。在我的机器上安装的唯一的其他微芯片软件是MPLABX V3.61.Microchip支持的建议是创建一个具有管理员权限的新用户并从那里重新安装。这对我起了作用。
以上来自于百度翻译 以下为原文 This issue has been resolved for me at least. The installer hangs due to a logged error message "Could not find registry key HKEY_LOCAL_MACHINESOFTWAREMicrochipMPLAB IDE InstallDir. Setting variable mplab8installed to empty value". They were unable to explain this as no such registry key exists on their various trial IDE machines. The only other Microchip software installed since new on my machine was MPLABX v3.61. The suggestion from Microchip support was to create a new user with administrator rights and re-install from there. This worked for me. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1123浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 01:43 , Processed in 1.183433 second(s), Total 77, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2670
