我用的单片机是STM32F103VC,扫描ADC1的8个通道,用DMA1传输转换结果。DMA接收后的数据与实际ADC的结果不一致。
部分代码如下: void CSL_ADC_Init(void) { GPIO_InitTypeDef GPIO_InitStructure; ADC_InitTypeDef ADC_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOC|RCC_APB2Periph_ADC1,ENABLE); RCC_ADCCLKConfig(RCC_PCLK2_Div6); //设置ADC分频因子6 72M/6=12M,ADC最大时间不能超过14M GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN; //模拟输入引脚 GPIO_Init(GPIOA,&GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN; //模拟输入引脚 GPIO_Init(GPIOC,&GPIO_InitStructure); //ADC1初始化 ADC_DeInit(ADC1); //复位ADC1,将外设 ADC1 的全部寄存器重设为缺省值 ADC_InitStructure.ADC_Mode = ADC_Mode_Independent; //ADC工作模式:ADC1工作在独立模式 ADC_InitStructure.ADC_ScanConvMode = ENABLE; //模数转换工作在扫描模式 ADC_InitStructure.ADC_ContinuousConvMode = DISABLE; //模数转换工作在单次转换模式 ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;//转换由软件而不是外部触发启动 ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; //ADC数据右对齐 ADC_InitStructure.ADC_NbrOfChannel = 8; //顺序进行规则转换的ADC通道的数目 ADC_Init(ADC1,&ADC_InitStructure); //根据ADC_InitStruct中指定的参数初始化外设ADCx的寄存器 ADC_Cmd(ADC1,ENABLE); //使能指定的ADC1 //ADC1校准 ADC_ResetCalibration(ADC1); //使能复位校准 while(ADC_GetResetCalibrationStatus(ADC1)); //等待复位校准结束 ADC_StartCalibration(ADC1); //开启AD校准 while(ADC_GetCalibrationStatus(ADC1)); //等待校准结束 //配置每个通道的转换次序和采样时间 ADC_RegularChannelConfig(ADC1,ADC_Channel_1, 1,ADC_SampleTime_71Cycles5); //TC1 ADC_RegularChannelConfig(ADC1,ADC_Channel_2, 2,ADC_SampleTime_71Cycles5); //TC2 ADC_RegularChannelConfig(ADC1,ADC_Channel_3, 3,ADC_SampleTime_71Cycles5); //TC3 ADC_RegularChannelConfig(ADC1,ADC_Channel_4, 4,ADC_SampleTime_71Cycles5); //TC4 ADC_RegularChannelConfig(ADC1,ADC_Channel_5, 5,ADC_SampleTime_71Cycles5); //TC5 ADC_RegularChannelConfig(ADC1,ADC_Channel_6, 6,ADC_SampleTime_71Cycles5); //TC6 ADC_RegularChannelConfig(ADC1,ADC_Channel_10,7,ADC_SampleTime_71Cycles5); //Current1 ADC_RegularChannelConfig(ADC1,ADC_Channel_11,8,ADC_SampleTime_71Cycles5); //Current2 } void CSL_DMA_Init(void) { DMA_InitTypeDef DMA_InitStructure; RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1,ENABLE); //使能DMA传输 DMA_DeInit(DMA1_Channel1); //将DMA的通道1寄存器重设为缺省值 DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)(&ADC1->DR); //DMA外设ADC1转换结果基地址 DMA_InitStructure.DMA_MemoryBaseAddr = (u32)ADC1Result; //DMA内存基地址 ADC1Result 为数组 DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; //数据传输方向,从外设读取数据到内存 DMA_InitStructure.DMA_BufferSize = 32; //DMA通道的DMA缓存的大小 DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;//外设地址寄存器不变 DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //内存地址寄存器递增 DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Word; //数据宽度为32位 DMA_InitStructure.DMA_MemoryDataSize = DMA_PeripheralDataSize_Word; //数据宽度为32位 DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;//工作在正常缓存模式 DMA_InitStructure.DMA_Priority = DMA_Priority_Medium; //DMA1通道1拥有中优先级 DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; //DMA通道x没有设置为内存到内存传输 DMA_Init(DMA1_Channel1,&DMA_InitStructure); DMA_Cmd(DMA1_Channel1,ENABLE); } void APP_Measure_Temperature_Current(void) //扫描ADC1 8个通道,用DMA传输数据 100ms周期调用 { ADC_DMACmd(ADC1,ENABLE); //开启ADC1 DMA传输 ADC_SoftwareStartConvCmd(ADC1,ENABLE); //使能指定的ADC1的软件转换启动功能 DMA_Cmd(DMA1_Channel1, ENABLE); DMA_SetCurrDataCounter(DMA1_Channel1,32); while(!ADC_GetFlagStatus(ADC1,ADC_FLAG_EOC)); //等待转换结束 大约56us while(DMA_GetFlagStatus(DMA1_FLAG_TC1) != RESET) { DMA_ClearFlag(DMA1_FLAG_TC1); //清除通道1传输完成标志 break; } ADC_DMACmd(ADC1,DISABLE); //关闭ADC1 DMA传输 DMA_Cmd(DMA1_Channel1,DISABLE); ADC_SoftwareStartConvCmd(ADC1,DISABLE); //关闭指定的ADC1的软件转换启动功能 } 是配置问题,还是其他。请赐教,第一次使用DMA。 |
20个回答
楼主能否描述一下数据是怎么样的不对,我们一般使用DMA中断方式处理。配置上看是一样的。可以只测试一路ADC,保证采集正确后,再增加其他路。
看不出来什么问题 请教一下楼主用的vref是多少 采集的信号量超过vref了没有 还有就是可以直接将采集信号连接到地或者上限 看看数值对不对 还有也可以试试将采样时间设置到最大 这样也可以增加采样的稳定性
只测试一路的话,数据也不对。DMA_InitStructure.DMA_BufferSize DMA_InitStructure.DMA_PeripheralDataSize DMA_InitStructure.DMA_MemoryDataSize 这三个该怎么设置, ADC转换结果寄存器是32位的. |
DMA_InitStructure.DMA_BufferSize = 缓冲区的大小;
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; DMA_InitStructure.DMA_MemoryDataSize = DMA_PeripheralDataSize_HalfWord; |
TOPCB 发表于 2018-8-24 12:08 为什么是DMA_PeripheralDataSize_HalfWord,ADC转换结果寄存器是32位的,应该是DMA_PeripheralDataSize_Word的吧,如果只转一路的话,DMA_InitStructure.DMA_BufferSize 为4个字节吗? |
Cube走起。。。初始化配置一般直接OK!!!
你缓冲区怎么定义的?要定义为16位的。
我现在只试验传一路ADC配置如下: DMA_InitTypeDef DMA_InitStructure; RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1,ENABLE); //使能DMA传输 DMA_DeInit(DMA1_Channel1); //将DMA的通道1寄存器重设为缺省值 DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)(&ADC1->DR); //DMA外设ADC1转换结果基地址 DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&ADCConvertedValue;//(u32)DMA1Buf; //DMA内存基地址 DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; //数据传输方向,从外设读取数据到内存 DMA_InitStructure.DMA_BufferSize = 1; //DMA通道的DMA缓存的大小 DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;//外设地址寄存器不变 DMA_InitStructure.DMA_MemoryInc = DMA_PeripheralInc_Disable;//DMA_MemoryInc_Enable; //内存地址寄存器递增 DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;//DMA_PeripheralDataSize_Word; //数据宽度为32位 DMA_InitStructure.DMA_MemoryDataSize = DMA_PeripheralDataSize_HalfWord;//DMA_PeripheralDataSize_Word; //数据宽度为32位 DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;//工作在正常缓存模式 DMA_InitStructure.DMA_Priority = DMA_Priority_Medium; //DMA1通道1拥有中优先级 DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; //DMA通道x没有设置为内存到内存传输 DMA_Init(DMA1_Channel1,&DMA_InitStructure); 有问题吗 |
ADCConvertedValue,这个是怎么定义的。
如下定义 :__IO u16 ADCConvertedValue; |
看配置差不多,值应该是多少,采集到的是多少。
AD转换结果为0x04ef, DMA传输后得到的结果为0x00ef, 高8位被丢掉了。 |
控制部分是这样做的,需要每100ms转换一次,并用DMA传输 ADC_DMACmd(ADC1,ENABLE); //开启ADC1 DMA传输 ADC_SoftwareStartConvCmd(ADC1,ENABLE); //使能指定的ADC1的软件转换启动功能 while(!ADC_GetFlagStatus(ADC1,ADC_FLAG_EOC)); //等待转换结束 大约56us while(DMA_GetFlagStatus(DMA1_FLAG_TC1) != RESET) { DMA_ClearFlag(DMA1_FLAG_TC1); //清除通道1传输完成标志 break; } ADC_DMACmd(ADC1,DISABLE); //关闭ADC1 DMA传输 |
楼主,方便把你的代码共享一下吗?我找个板子测试一下。
也可以仿真的情况下,看一下寄存器的值和DMA取到的值是不是一致。我使用很长时间DMA中断,发生的问题基本是因为自己配置错误导致。 |
楼主既然一次扫描8个通道4次,就不应该将这里设成禁止: ADC_InitStructure.ADC_ContinuousConvMode = DISABLE; 这样的话ADC只转换8个通道一次就结束,DMA不知道,它会硬要凑足32个数据,后面的数据必定对不上号 要么设成ENABLE,要么32改成8 还有字长应该设成: DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull; |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
2234 浏览 1 评论
AD7686芯片不传输数据给STM32,但是手按住就会有数据。
2053 浏览 3 评论
4664 浏览 0 评论
如何解决MPU-9250与STM32通讯时,出现HAL_ERROR = 0x01U
2197 浏览 1 评论
hal库中i2c卡死在HAL_I2C_Master_Transmit
2734 浏览 1 评论
GMT+8, 2024-12-26 15:18 , Processed in 1.048640 second(s), Total 77, Slave 71 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
