我用的单片机是STM32F103VC,扫描ADC1的8个通道,用DMA1传输转换结果。DMA接收后的数据与实际ADC的结果不一致。
部分代码如下: void CSL_ADC_Init(void) { GPIO_InitTypeDef GPIO_InitStructure; ADC_InitTypeDef ADC_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOC|RCC_APB2Periph_ADC1,ENABLE); RCC_ADCCLKConfig(RCC_PCLK2_Div6); //设置ADC分频因子6 72M/6=12M,ADC最大时间不能超过14M GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN; //模拟输入引脚 GPIO_Init(GPIOA,&GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN; //模拟输入引脚 GPIO_Init(GPIOC,&GPIO_InitStructure); //ADC1初始化 ADC_DeInit(ADC1); //复位ADC1,将外设 ADC1 的全部寄存器重设为缺省值 ADC_InitStructure.ADC_Mode = ADC_Mode_Independent; //ADC工作模式:ADC1工作在独立模式 ADC_InitStructure.ADC_ScanConvMode = ENABLE; //模数转换工作在扫描模式 ADC_InitStructure.ADC_ContinuousConvMode = DISABLE; //模数转换工作在单次转换模式 ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;//转换由软件而不是外部触发启动 ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; //ADC数据右对齐 ADC_InitStructure.ADC_NbrOfChannel = 8; //顺序进行规则转换的ADC通道的数目 ADC_Init(ADC1,&ADC_InitStructure); //根据ADC_InitStruct中指定的参数初始化外设ADCx的寄存器 ADC_Cmd(ADC1,ENABLE); //使能指定的ADC1 //ADC1校准 ADC_ResetCalibration(ADC1); //使能复位校准 while(ADC_GetResetCalibrationStatus(ADC1)); //等待复位校准结束 ADC_StartCalibration(ADC1); //开启AD校准 while(ADC_GetCalibrationStatus(ADC1)); //等待校准结束 //配置每个通道的转换次序和采样时间 ADC_RegularChannelConfig(ADC1,ADC_Channel_1, 1,ADC_SampleTime_71Cycles5); //TC1 ADC_RegularChannelConfig(ADC1,ADC_Channel_2, 2,ADC_SampleTime_71Cycles5); //TC2 ADC_RegularChannelConfig(ADC1,ADC_Channel_3, 3,ADC_SampleTime_71Cycles5); //TC3 ADC_RegularChannelConfig(ADC1,ADC_Channel_4, 4,ADC_SampleTime_71Cycles5); //TC4 ADC_RegularChannelConfig(ADC1,ADC_Channel_5, 5,ADC_SampleTime_71Cycles5); //TC5 ADC_RegularChannelConfig(ADC1,ADC_Channel_6, 6,ADC_SampleTime_71Cycles5); //TC6 ADC_RegularChannelConfig(ADC1,ADC_Channel_10,7,ADC_SampleTime_71Cycles5); //Current1 ADC_RegularChannelConfig(ADC1,ADC_Channel_11,8,ADC_SampleTime_71Cycles5); //Current2 } void CSL_DMA_Init(void) { DMA_InitTypeDef DMA_InitStructure; RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1,ENABLE); //使能DMA传输 DMA_DeInit(DMA1_Channel1); //将DMA的通道1寄存器重设为缺省值 DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)(&ADC1->DR); //DMA外设ADC1转换结果基地址 DMA_InitStructure.DMA_MemoryBaseAddr = (u32)ADC1Result; //DMA内存基地址 ADC1Result 为数组 DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; //数据传输方向,从外设读取数据到内存 DMA_InitStructure.DMA_BufferSize = 32; //DMA通道的DMA缓存的大小 DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;//外设地址寄存器不变 DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //内存地址寄存器递增 DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Word; //数据宽度为32位 DMA_InitStructure.DMA_MemoryDataSize = DMA_PeripheralDataSize_Word; //数据宽度为32位 DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;//工作在正常缓存模式 DMA_InitStructure.DMA_Priority = DMA_Priority_Medium; //DMA1通道1拥有中优先级 DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; //DMA通道x没有设置为内存到内存传输 DMA_Init(DMA1_Channel1,&DMA_InitStructure); DMA_Cmd(DMA1_Channel1,ENABLE); } void APP_Measure_Temperature_Current(void) //扫描ADC1 8个通道,用DMA传输数据 100ms周期调用 { ADC_DMACmd(ADC1,ENABLE); //开启ADC1 DMA传输 ADC_SoftwareStartConvCmd(ADC1,ENABLE); //使能指定的ADC1的软件转换启动功能 DMA_Cmd(DMA1_Channel1, ENABLE); DMA_SetCurrDataCounter(DMA1_Channel1,32); while(!ADC_GetFlagStatus(ADC1,ADC_FLAG_EOC)); //等待转换结束 大约56us while(DMA_GetFlagStatus(DMA1_FLAG_TC1) != RESET) { DMA_ClearFlag(DMA1_FLAG_TC1); //清除通道1传输完成标志 break; } ADC_DMACmd(ADC1,DISABLE); //关闭ADC1 DMA传输 DMA_Cmd(DMA1_Channel1,DISABLE); ADC_SoftwareStartConvCmd(ADC1,DISABLE); //关闭指定的ADC1的软件转换启动功能 } 是配置问题,还是其他。请赐教,第一次使用DMA。 |
20个回答
给你个程序参考
#define AdcChannelNum 1 #define AdcDmaLengh (AdcFilterNum * AdcChannelNum) uint32_t ADC_ConvertedValue[AdcFilterNum][AdcChannelNum]; /* ADC1 init function */ static void MX_ADC1_Init(void) { ADC_ChannelConfTypeDef sConfig; /**Common config */ hadc1.Instance = ADC1; hadc1.Init.ScanConvMode = ADC_SCAN_DISABLE; hadc1.Init.ContinuousConvMode = ENABLE; hadc1.Init.DiscontinuousConvMode = DISABLE; hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START; hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT; hadc1.Init.NbrOfConversion = 1; if (HAL_ADC_Init(&hadc1) != HAL_OK) { _Error_Handler(__FILE__, __LINE__); } /**Configure Regular Channel */ sConfig.Channel = ADC_CHANNEL_0; sConfig.Rank = 1; sConfig.SamplingTime = ADC_SAMPLETIME_239CYCLES_5; if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK) { _Error_Handler(__FILE__, __LINE__); } } void Start_AdConvert(void) { HAL_ADCEx_Calibration_Start(&hadc1); HAL_Delay(100); HAL_ADC_Start_DMA(&hadc1, (ADC_ConvertedValue[0]), AdcDmaLengh); } |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
2255 浏览 1 评论
AD7686芯片不传输数据给STM32,但是手按住就会有数据。
2071 浏览 3 评论
4687 浏览 0 评论
如何解决MPU-9250与STM32通讯时,出现HAL_ERROR = 0x01U
2215 浏览 1 评论
hal库中i2c卡死在HAL_I2C_Master_Transmit
2757 浏览 1 评论
GMT+8, 2024-12-27 03:36 , Processed in 0.534959 second(s), Total 42, Slave 36 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
